into dns
asishlla
I have some errors here:
http://intodns.com/joomlastyle.net
how can i fix it? like:
"ERROR: Some of your DNS servers do not have A records at all. I could not find any A records for the following DNS servers:
pleasedropthishost13855.joomlastyle.biz
You must have A records for all of your nameservers. "
zEitEr
SeLLeRoNe
Peter Laws
friends i have a few questions,i need one of you Log in to Messenger to make a deal with me foe this questions..
thank you
This is werid, when I do a whois on your domain, it shows the correct:
Results returned from whois.godaddy.com:
Whois query for joomlastyle.net...
Domain servers in listed order:
      NS1.JOOMLASTYLE.NET
      NS2.JOOMLASTYLE.NET
Did you recently change your nameservers at your Registrar (GoDaddy)?
But then I did a WHOIS using another site, and got:
Results returned from whois.internic.net:
   Name Server: NS1.JOOMLASTYLE.NET
   Name Server: PLEASEDROPTHISHOST13855.JOOMLASTYLE.BIZ
I would suggest reconfiguring your Nameservers at GoDaddy and ensure they are pointed to the correct servers. If it is listing ns1 and ns2 correctly, delete them from GoDaddy's interface then re-add them quickly.
If it still doesn't work, you will have to contact GoDaddy's support with the information I gave you, it sounds like their systems did not sync correctly with internic.
Hi propcgamer ,
My Nameservers at GoDaddy are pointed to the correct servers!
I did not recently change my nameservers at Registrar (GoDaddy) i've just renew the domain.
whrer is the file zone locate in my server? maybe neef to change there?
I checked what your nameservers are reporting, those are correct.
I would open a support ticket with GoDaddy, it seems like the nameserver changes for your domain did not propergate to internic correctly.
To answer your other question, you should be able to look at your zone file by going to the "DNS Administration" in the directadmin panel.
Ok,
in etc/named.conf i see there to lines :
include "/etc/rndc.key";
zone "host-78-129-175-65.rsclientdns.com" { type master; file "/var/named/host-78-129-175-65.rsclientdns.com.db"; };
zone "domain.com" { type master; file "/var/named/domain.com.db"; };
why (domain.com)? why (rsclientdns.com)?
whos that?
I would imagine domain.com is a leftover domain that was created possibly for testing?
"host-78-129-175-65.rsclientdns.com" looks like it used to be the reverse dns entry for your server. That was setup by your server provider.
Those two entrys are not causing the issue you are having though.
Ok, this is my ticket to GoDaddy:
I did a whois on my domain, it shows the correct:
NS1.JOOMLASTYLE.NET
NS2.JOOMLASTYLE.NET
it sounds like your systems did not sync correctly with internic.
now i have problem with my (list of Resellers users on my server)
can you check please?
hope that help !!
i've attached photo
Hello,this is what Goddady said:
We have refreshed the nameservers associated with your domain and the correct records should be reporting on all networks once DNS re-propagates. You may also want to check your zone file at these nameservers to make sure that they are configured properly and not using a NS record that has not also been applied to your domain in your Domain Manager.
What i need to do now?
thank you
Ok, well since we verified your NS records are correct on your server (you posted a screenshot further up).
It looks like they did sync the nameservers for your domain, now they report:
      NS1.JOOMLASTYLE.NET
      NS2.JOOMLASTYLE.NET
When you login to the godaddy web-site, do you see the "PLEASEDROPTHISHOST13855.JOOMLASTYLE.BIZ" listed under nameservers for your account?
If you do, please remove it.
If you don't, please reply to that godaddy ticket and say that the nameservers ns1 and ns2 now seem to be reporting correctly, but it is also reporting "PLEASEDROPTHISHOST13855.JOOMLASTYLE.BIZ", I do not see this nameserver listed in my godaddy control panel, can you please remove it as a nameserver for my domain? It is not listed in the zone file at the ns1 and ns2 nameservers.
The "ERROR: No reverse DNS (PTR) entries." error?
What is the hostname of your server? (In DA, its under "Administrator Settings").
Step 1: In DirectAdmin, goto DNS Administration for the joomlastyle.net domain.
Add an A record for "server" pointing to "78.129.175.65"
Step 2: Open a support ticket with your server provider, ask them to:
Please create a Reverse DNS (PTR) record for 78.129.175.65 to point to server.joomlastyle.net
Once they do that, you will have to wait 4-24 hours for the DNS to propergate.
that mean the server will be down 4-24 hours? with all sites hosted on?
Ok man
i've attached photo for what you ask me to do at step 1
is that right in photo?
That's not correct. Delete the "joomlastyle.net" entry (the one your are pointing to in the picture).
Add an entry called "server" A "78.129.175.65" (without quotes of course)
