into dns
Hello dear genius,
I conducted the required amendments like you said.
What about the things in the color blue & orange?
Did you have them point the reverse record as "www.joomlastyle.net" or "server.joomlastyle.net", its showing as www. for me?
The things in color blue are just informational. The ones in orange are just warning you that if your server or network go down, no one would be able to resolve your dns.
this is his answer:
You can add Reverse DNS entries using the MyServers interface (available at https://myservers.rapidswitch.com).
1. Once logged in, click on "Reverse DNS" under "My Domains".
2. To add an entry, select the IP address you would like to add a PTR record for and enter the domain name into the text box beneath.
3. Click Add address mapping.
Creating PTR records do not affect your server. If you have any more questions or need help with this please let me know.
i've point the reverse record as "www.joomlastyle.net"
you mean (blue/orange) colors to ignore?
i have an option to add another one like (server.joomlastyle.net) what you say?
to add or change and and remove "www.joomlastyle.net" ?
Hi propcgamer,
Ihave 4 warning in csf ,u have attached photo..can you also help me how to fix it?
thank you
for php disable funciont do:
/usr/local/directadmin/custombuild/build secure_php
For suhosin patch check on this forum for update.script and install suhosin with that.
For NS you need two different ip with different class for solve that error, if you cant have ns1 and ns2 different like i sayd, so, u cant solve that specific error.
Regards
