1) Check if it's compiled in:
/usr/sbin/proftpd -l
we're looking for mod_tls.c
[root@cp ~]# /usr/sbin/proftpd -l
Compiled-in modules:
mod_core.c
mod_xfer.c
mod_auth_unix.c
mod_auth_file.c
mod_auth.c
mod_ls.c
mod_log.c
mod_site.c
mod_delay.c
mod_facts.c
mod_ident.c
mod_ratio.c
mod_readme.c
mod_sftp.c
mod_tls.c
mod_cap.c
mod_lang.c
2) Check:
/etc/proftpd.conf
and compare with:
/usr/local/directadmin/data/templates/proftpd.conf
eg:
diff /etc/proftpd.conf /usr/local/directadmin/data/templates/proftpd.conf
(ignore the |SERVER_IP| token difference, but ensure you use the TLSProtocl change we discussed)
[root@cp ~]# diff /etc/proftpd.conf /usr/local/directadmin/data/templates/proftpd.conf
21,22c21,22
< LogFormat userlog "%u %b"
< #ExtendedLog /var/log/proftpd/74.124.206.98.bytes WRITE,READ userlog
> LogFormat userlog "%u %b %m %a"
> ExtendedLog /var/log/proftpd/|SERVER_IP|.bytes WRITE,READ userlog
25a26
> AuthOrder mod_auth_file.c
39a41,42
> TLSCipherSuite HIGH:MEDIUM:+TLSv1:!SSLv2:+SSLv3
42a46
> PassivePorts 35000 35999
72a77,82
> <IfModule mod_tls.c>
> TLSEngine on
> TLSLog /var/log/proftpd/proftpd.tls.log
> TLSRSACertificateFile /etc/exim.cert
> TLSRSACertificateKeyFile /etc/exim.key
> </IfModule>
76,78d85
3) check /var/log/proftpd/proftpd.tls.log for more clues.
[root@cp ~]# tail -n 40 /var/log/proftpd/proftpd.tls.log
Jun 07 18:15:04 mod_tls/2.4.2[436]: using default OpenSSL verification locations (see $SSL_CERT_DIR environment variable)
Jun 07 18:15:04 mod_tls/2.4.2[439]: using default OpenSSL verification locations (see $SSL_CERT_DIR environment variable)
Jun 07 18:25:04 mod_tls/2.4.2[734]: using default OpenSSL verification locations (see $SSL_CERT_DIR environment variable)
Jun 07 18:25:04 mod_tls/2.4.2[735]: using default OpenSSL verification locations (see $SSL_CERT_DIR environment variable)
Jun 07 18:35:03 mod_tls/2.4.2[1016]: using default OpenSSL verification locations (see $SSL_CERT_DIR environment variable)
Jun 07 18:35:03 mod_tls/2.4.2[1018]: using default OpenSSL verification locations (see $SSL_CERT_DIR environment variable)
Jun 07 18:45:11 mod_tls/2.4.2[1341]: using default OpenSSL verification locations (see $SSL_CERT_DIR environment variable)
Jun 07 18:45:12 mod_tls/2.4.2[1338]: using default OpenSSL verification locations (see $SSL_CERT_DIR environment variable)
Jun 07 18:55:04 mod_tls/2.4.2[1583]: using default OpenSSL verification locations (see $SSL_CERT_DIR environment variable)
Jun 07 18:55:04 mod_tls/2.4.2[1585]: using default OpenSSL verification locations (see $SSL_CERT_DIR environment variable)
Jun 07 19:05:04 mod_tls/2.4.2[1828]: using default OpenSSL verification locations (see $SSL_CERT_DIR environment variable)
Jun 07 19:05:04 mod_tls/2.4.2[1831]: using default OpenSSL verification locations (see $SSL_CERT_DIR environment variable)
Jun 07 19:15:04 mod_tls/2.4.2[2150]: using default OpenSSL verification locations (see $SSL_CERT_DIR environment variable)
Jun 07 19:15:04 mod_tls/2.4.2[2153]: using default OpenSSL verification locations (see $SSL_CERT_DIR environment variable)
Jun 07 19:25:06 mod_tls/2.4.2[2470]: using default OpenSSL verification locations (see $SSL_CERT_DIR environment variable)
Jun 07 19:25:06 mod_tls/2.4.2[2472]: using default OpenSSL verification locations (see $SSL_CERT_DIR environment variable)
Jun 07 19:31:11 mod_tls/2.4.2[2672]: using default OpenSSL verification locations (see $SSL_CERT_DIR environment variable)
Jun 07 19:32:07 mod_tls/2.4.2[2685]: using default OpenSSL verification locations (see $SSL_CERT_DIR environment variable)
Jun 07 19:32:07 mod_tls/2.4.2[2684]: using default OpenSSL verification locations (see $SSL_CERT_DIR environment variable)
Jun 07 19:35:04 mod_tls/2.4.2[2793]: using default OpenSSL verification locations (see $SSL_CERT_DIR environment variable)
Jun 07 19:35:04 mod_tls/2.4.2[2796]: using default OpenSSL verification locations (see $SSL_CERT_DIR environment variable)
Jun 07 19:45:05 mod_tls/2.4.2[3177]: using default OpenSSL verification locations (see $SSL_CERT_DIR environment variable)
Jun 07 19:45:05 mod_tls/2.4.2[3175]: using default OpenSSL verification locations (see $SSL_CERT_DIR environment variable)
Jun 07 19:55:04 mod_tls/2.4.2[3510]: using default OpenSSL verification locations (see $SSL_CERT_DIR environment variable)
Jun 07 19:55:04 mod_tls/2.4.2[3511]: using default OpenSSL verification locations (see $SSL_CERT_DIR environment variable)
Jun 07 20:05:03 mod_tls/2.4.2[3786]: using default OpenSSL verification locations (see $SSL_CERT_DIR environment variable)
Jun 07 20:05:03 mod_tls/2.4.2[3787]: using default OpenSSL verification locations (see $SSL_CERT_DIR environment variable)
Jun 07 20:13:49 mod_tls/2.4.2[4101]: using default OpenSSL verification locations (see $SSL_CERT_DIR environment variable)
Jun 07 20:13:49 mod_tls/2.4.2[4103]: using default OpenSSL verification locations (see $SSL_CERT_DIR environment variable)
Jun 07 20:15:05 mod_tls/2.4.2[4232]: using default OpenSSL verification locations (see $SSL_CERT_DIR environment variable)
Jun 07 20:15:05 mod_tls/2.4.2[4234]: using default OpenSSL verification locations (see $SSL_CERT_DIR environment variable)
Jun 07 20:25:11 mod_tls/2.4.2[4544]: using default OpenSSL verification locations (see $SSL_CERT_DIR environment variable)
Jun 07 20:25:11 mod_tls/2.4.2[4545]: using default OpenSSL verification locations (see $SSL_CERT_DIR environment variable)
Jun 07 20:33:28 mod_tls/2.4.2[4805]: using default OpenSSL verification locations (see $SSL_CERT_DIR environment variable)
Jun 07 20:35:04 mod_tls/2.4.2[4888]: using default OpenSSL verification locations (see $SSL_CERT_DIR environment variable)
Jun 07 20:35:04 mod_tls/2.4.2[4885]: using default OpenSSL verification locations (see $SSL_CERT_DIR environment variable)
Jun 07 20:45:06 mod_tls/2.4.2[5187]: using default OpenSSL verification locations (see $SSL_CERT_DIR environment variable)
Jun 07 20:45:06 mod_tls/2.4.2[5189]: using default OpenSSL verification locations (see $SSL_CERT_DIR environment variable)
Jun 07 20:55:03 mod_tls/2.4.2[5462]: using default OpenSSL verification locations (see $SSL_CERT_DIR environment variable)
Jun 07 20:55:03 mod_tls/2.4.2[5461]: using default OpenSSL verification locations (see $SSL_CERT_DIR environment variable)
