setting up help DA
Try
chown named:named /var/named/gorihosting.com.db
then try restart named.
Regards
same error result
[root@server ~]# tail /var/log/directadmin/error.log
loading "gorihosting.com" from "/var/named/gorihosting.com.db.temp" class "IN"
zone gorihosting.com/IN: NS 'ns1.gorihosting.com' has no address records (A or AAAA)
zone gorihosting.com/IN: NS 'ns2.gorihosting.com' has no address records (A or AAAA)
zone gorihosting.com/IN: not loaded due to errors.
2011:12:02-04:42:20: Added record ns1.gorihosting.com. A 208.94.244.194 to satisfy gorihosting.com. NS ns1.gorihosting.com.
2011:12:02-04:42:20: Added record ns2.gorihosting.com. A 208.94.244.194 to satisfy gorihosting.com. NS ns2.gorihosting.com.
2011:12:02-06:03:53: ConfigFile::writeFile(/usr/local/directadmin/data/users/admin/ftp.passwd) : Timestamp from when it was read is different, overwriting anyway
2011:12:02-06:03:53: Added record ns1.gorihosting.com. A 208.94.244.194 to satisfy gorihosting.com. NS ns1.gorihosting.com.
2011:12:02-06:03:53: Added record ns2.gorihosting.com. A 208.94.244.194 to satisfy gorihosting.com. NS ns2.gorihosting.com.
in Directadmin panel , this might a lil help
admin » DNS Administration » Entry for gorihosting.com
ftp	A	208.94.244.194
localhost	A	127.0.0.1
mail	A	208.94.244.194
ns1.gorihosting.com.	A	208.94.244.195
ns2.gorihosting.com.	A	208.94.244.196
pop	A	208.94.244.194
smtp	A	208.94.244.194
www	A	208.94.244.194
mail	MX	10
gorihosting.com.	TXT	"v=spf1 a mx ip4:208.94.244.194 ~all"
localhost	AAAA	::1
Try remove from DA Panel the DNS for this zone and re-add (always from DA Panel) (not the reset as you did before).
Regards
Regards
removed
and readded it again,
restart named
restart directadmin
tried also restarting using DA panel's restart option. still no dice.
In DA's DNS entries I guess it shows the correct content but why it the error log reports as it doesn't know it??
No, i mean remove all the zone.
Regards
from DA
admin » gorihosting.com » DNS Settings
I tried deleting all but this give me:
Cannot Delete those NS records
Details
Deleting them will leave you with 0. You must have more than 0 NS records or named may not start.
Add the new NS records first.
I tried to leave "FTP" and delete all still give me same result. other way around?
You dont have to delete it you just have to repair it.
Type:
/usr/sbin/rndc reload
Then:
tail -25 /var/log/messages
Then you will see what the zone error is so you can fix it.
Then you can manually edit /var/named/gorihosting.com.db and fix the error.
Type:
Then:
Thanks for jumping in, these are the results im lost to repair .db here:
[root@server home]# tail -25 /var/log/messages
Dec  2 12:10:23 server named[23767]: error (network unreachable) resolving 'dlv.                                   isc.org/DNSKEY/IN': 2001:4f8:0:2::20#53
Dec  2 12:10:23 server named[23767]: error (network unreachable) resolving 'dlv.                                   isc.org/DNSKEY/IN': 2001:500:60::29#53
Dec  2 12:10:23 server named[23767]: error (network unreachable) resolving 'dlv.                                   isc.org/DNSKEY/IN': 2001:500:71::29#53
Dec  2 12:10:23 server named[23767]: error (network unreachable) resolving 'ns2.                                   isc.ultradns.net/AAAA/IN': 2001:503:231d::2:30#53
Dec  2 12:10:23 server named[23767]: error (network unreachable) resolving 'ns.i                                   sc.afilias-nst.info/A/IN': 2001:500:6::79#53
Dec  2 12:10:23 server named[23767]: error (network unreachable) resolving 'pdns                                   4.ultradns.org/A/IN': 2001:500:e::1#53
Dec  2 12:10:23 server named[23767]: error (network unreachable) resolving 'pdns                                   5.ultradns.info/AAAA/IN': 2001:500:1a::1#53
Dec  2 12:10:23 server named[23767]: error (network unreachable) resolving 'pdns                                   6.ultradns.co.uk/AAAA/IN': 2001:500:2f::f#53
Dec  2 12:10:23 server named[23767]: error (network unreachable) resolving 'pdns                                   5.ultradns.info/AAAA/IN': 2001:500:19::1#53
Dec  2 12:10:23 server named[23767]: error (network unreachable) resolving 'pdns                                   6.ultradns.co.uk/A/IN': 2001:502:4612::1#53
Dec  2 12:14:28 server proftpd[5434]: 208.94.244.194 (::ffff:151.16.96.241[::fff                                   f:151.16.96.241]) - FTP session opened.
Dec  2 12:14:29 server proftpd[5434]: 208.94.244.194 (::ffff:151.16.96.241[::fff                                   f:151.16.96.241]) - FTP session closed.
Dec  2 12:52:37 server named[23767]: received control channel command 'reload'
Dec  2 12:52:37 server named[23767]: loading configuration from '/etc/named.conf                                   '
Dec  2 12:52:37 server named[23767]: reading built-in trusted keys from file '/e                                   tc/named.iscdlv.key'
Dec  2 12:52:37 server named[23767]: using default UDP/IPv4 port range: [1024, 6                                   5535]
Dec  2 12:52:37 server named[23767]: using default UDP/IPv6 port range: [1024, 6                                   5535]
Dec  2 12:52:37 server named[23767]: using built-in trusted-keys for view _defau                                   lt
Dec  2 12:52:37 server named[23767]: using built-in trusted-keys for view _meta
Dec  2 12:52:37 server named[23767]: set up managed-keys.bind meta-zone
Dec  2 12:52:37 server named[23767]: the working directory is not writable
Dec  2 12:52:37 server named[23767]: zone managed-keys.bind/IN/_meta: (other) re                                   moved
Dec  2 12:52:37 server named[23767]: reloading configuration succeeded
Dec  2 12:52:37 server named[23767]: zone managed-keys.bind/IN/_meta: loaded ser                                   ial 355
Dec  2 12:52:37 server named[23767]: reloading zones succeeded
i see an error on resolve, so maybe is in
/etc/resolv.conf
one error
and one here:
For this should work
chmod 750 /var/named
ok scsi have for sure more experience then me, so, it should be fine.
scsi: does named have to be listening on external ip aswell? On the netstat he posted before seemed that named was listening just on localhost.
telnet on port 53 is now working so you should be ok now...
That looks to be fine now.
I dont see any errors.
Thanks guys, just my concern now why directadmin error log still shows this?
[root@server /]# tail /var/log/directadmin/error.log
2011:12:02-11:13:05: Socket write error: fd is connected to a pipe or socket whose reading end is closed.  When this  happens the writing process will also receive a SIG_PIPE signal.  (Thus, the write return value is seen only if  the program catches, blocks or ignores this signal.)
My guess is the log entries are old and not of the current time. You must of fixed the problem now.
You could just do:
echo > /var/log/directadmin/error.log
Then see if the errors come back at any time in the log.
Your nameservers are working fine and resolving fine.
He must of fixed the netstat thing before I checked it because it was resolving fine.
This error can be ignored...its a typical error on freebsd servers. I dont know what OS you are running, but I have the problem on all my freebsd nameservers. It has to do the the way the source code of named is in /usr/src
You could just do:
after echo and checked log, shows clear now.
I used centos 6, forgot to mention.
Guys after almost a week of trial finally!,, THank you so much!
