Blacklisting/blocking IP's
ryand
If you use a custom skin you have to add them manually to the skin.
I am trying to find where I would edit the skin thats currently running and I can't even find that.. not that I would know how to put it in there even if I found it :( kinda new to Directadmin
I would just look at http://directadmin.com/demo.html and see how yours is different.
You could also make sure you have bruteforce enabled first.
This command should tell you if it is enabled or not:
/usr/local/directadmin/directadmin c | grep -i bruteforce
1 = enabled
0 = disabled
|*if HAVE_BLOCK_SH="1"|
This might mean you have to have a block_ip.sh file in order for it to show.
You might have to check http://directadmin.com/versions.php and put in keyword brute to find out how to set it up. Also search the forums for bruteforce or block_ip.sh
I dont use the bruteforce stuff at all.
1 = enabled
0 = disabled
well it appears I do have it.
bruteforce=1
What do you use instead of this utility to block people that appear to be phishing for compromised accounts? I have a certain ip that has hit my server 1400 times so far and every username is different.
I use http://configserver.com/cp/csf.html it also have a DirectAdmin plugin. It works very well for us.
Thank you very much. I have used plesk since 2003 and just recently switched to DirectAdmin so I am still trying to figure out all of the tips and tweaks. I used to use an add-on called ASL for plesk and I have found they recently came out with a version thats compatible for DA but not for the custom compiled version. They are working on a beta for that however.
This tool you suggested is a great one in the mean time!
