scsi
- Aug 19, 2008
The "Search Thread" functionality doesn't work yet, I get these errors on top of the page and the search results look random to the search term.
Code:Warning: preg_replace() [function.preg-replace]: Compilation failed: this version of PCRE is not compiled with PCRE_UTF8 support at offset 0 in [path]/vb/search/searchtools.php on line 816 Warning: preg_replace() [function.preg-replace]: Compilation failed: this version of PCRE is not compiled with PCRE_UTF8 support at offset 0 in [path]/vb/search/searchtools.php on line 816 Warning: preg_replace() [function.preg-replace]: Compilation failed: this version of PCRE is not compiled with PCRE_UTF8 support at offset 0 in [path]/vb/search/searchtools.php on line 816 Warning: preg_replace() [function.preg-replace]: Compilation failed: this version of PCRE is not compiled with PCRE_UTF8 support at offset 0 in [path]/vb/search/searchtools.php on line 816 Warning: preg_replace() [function.preg-replace]: Compilation failed: this version of PCRE is not compiled with PCRE_UTF8 support at offset 0 in [path]/vb/search/searchtools.php on line 816 Warning: preg_replace() [function.preg-replace]: Compilation failed: this version of PCRE is not compiled with PCRE_UTF8 support at offset 0 in [path]/vb/search/searchtools.php on line 816 Warning: preg_replace() [function.preg-replace]: Compilation failed: this version of PCRE is not compiled with PCRE_UTF8 support at offset 0 in [path]/vb/search/searchtools.php on line 816
Not sure what version of php they are running, but they need to disable warnings in their php.ini
