How to enable quota display under Roundcube webmail
unihostbrasil
São Paulo - Brazil
To enable email quota display under Roundcube:
1) Enable DOVECOT quota support (/etc/dovecot.conf):
mail_plugins = $mail_plugins quota
protocol imap {
  mail_plugins = $mail_plugins imap_quota
plugin {
  quota = maildir
2) Enable DA quota option and convert all existing password files to use the quota parameter: http://www.directadmin.com/features.php?id=1461
3) Check if Roundcube is correctly configured (/var/www/html/roundcube/config/config.inc.php)
$rcmail_config['quota_zero_as_unlimited'] = true;
4) Remember to set the pop account quota to something greater than 0 under control panel, otherwise the Roundcube will show 0% for usage.
5) You can define an default quota for new accounts (/usr/local/directadmin/conf/directadmin.conf)
default_pop_quota=500
We are using this setup for a year in all of our CentOS servers successfully.
hi,
i have a server with directadmin and i'm interested to enable quota plugin...
my server have this configuration
Centos 6.0
DA 1.41.1
Dovecot 2.1.7
I try the howto written up, but does not work...
the code into the /etc/dovecot.conf is to be written at the end of file?
thank you
i try to digit into shell, but i receive an error...
[root@www cron.daily]# sh sync_quota_DA_IMAP.sh
'ync_quota_DA_IMAP.sh: line 2: syntax error near unexpected token `do
sync_quota_DA_IMAP.sh: line 2: `for username in `ls /usr/local/directadmin/data/'sers 2>/dev/null`; do
thank you
Check if you did copy correctly.
Regards
ok, i check and i copy the entire text in sync_quota_DA_IMAP.sh
i copied 31 lines in notepad++, then i upload via sftp with filezilla, then chmod 700 with filezilla.
then i open putty (root) and:
thank you very much
Ok,
here my copy, try this:
#!/bin/bash
for username in `ls /usr/local/directadmin/data/users 2>/dev/null`; do
        for domain in `cat /usr/local/directadmin/data/users/$username/domains.list 2>/dev/null`; do
                for userquota in `cat /etc/virtual/$domain/quota 2>/dev/null`; do
                        USER=`echo $userquota 2>/dev/null | cut -d: -f1 2>/dev/null`
                        QUOTA=`echo $userquota 2>/dev/null | cut -d: -f2 2>/dev/null`S
                        # Force quota recalculation
                        RECALC="-1024 -1"
                        MDPATH=/home/$username/imap/$domain/$USER/Maildir
                        if [ ! -d "$MDPATH" ]; then
                                mkdir $MDPATH
                                chown $username:mail $MDPATH
                                chmod 770 $MDPATH
                        fi
                        echo -e "$QUOTA\n$RECALC" > $MDPATH/maildirsize
                        chown -R $username:mail $MDPATH/maildirsize
                        chmod 660 $MDPATH/maildirsize
                done;
        done;
done;
Regards
On your pasted error:
Seems there is a starting ' before "for"??
Regards
i tried with you correction, but the error is the same...
i attach a picture....
thank you :)
Scusa, ho letto adesso la firma... ma sei italiano? forse capisco di più se posso scrivere in italiano...
grazie
Si sono italiano ma è meglio scrivere quantomeno la doppia riga anche in inglese così che tutti possano capire. Controllo che quando incolli non vada qualche parola/pezzo di riga a capo.
Yes im italian, but is much better write both language so everyone can understand. Check when you paste if some word/piece of sentence command take a new line
Se vuoi posso anche farlo io ma lo faccio come servizio a pagamento.
If you want i can do the work for you but is a payd service
Saluti
Regards
ok, grazie mille. volevo provarci da solo, visto che dovrebbe essere semplice...
ho controllato ed è tutto ok con notepad++
non ho provato con mine... cosa è?
ok, thank you. I wanted to try it out, this should be simple...
I checked and everything is ok with notepad++
I have not tried it with mine ... What is it?
Prova con nano direttamente in shell
Try use nano directly in shell
Regards
ok, i made it!!! :)
i used nano and i wrote the code posted in the first post... now i hope that is updated daily...
thank you very much!!!
Was the problem perhaps that user aleaden uploaded from windows but didn't set upload as ascii? That will cause improper line endings which can cause problems.
I got the scripts working and the mail quota files are being populated.
but now, there is a difference between roundcube quota and directadmin quota...
see below print-screens to show the results...
any advice on that difference?
The quota is synchronized (50MB), but the calculation of used space may vary slightly between webmail and DA, don't worry.
