[CloudLinux] PHP Selector for DirectAdmin
explosive
PL/EU
Cloud Linux Inc.
PHP Selector for DA http://ow.ly/jVFFD is almost done. Beta planned for the next week
Wow. I'm curious how it will work with CustomBuild.
I'm guessing that page will generate the configure file for custombuild then just build php with it. What I wonder if you could have more than 2 php versions.
Oh yes that makes sense, they can just maintain it themselves :)
We build our own PHP with fairly large number of extensions (of course you can add more extensions, and more php versions if you would like -- we have docs on our site).
No need to modify anything in httpd.conf -- the way it works is through some trickery with CageFS :)
User1 would have /usr/local/bin/php -- being php5.3 binary
while user2 would have it as php 5.4 binary ... etc... depending on user's choice
And of course they can run 'native' -- whatever was build by custombuild (that is the default)
I've recently purchased 2 CloudLinux licenses. Any updates on PHP Selector for DA?
