webapps not working again
dmacleo
I give up on this I guess, nginx on DA is really not ready.
all webapps are a 502 error again after doing php update.
I can do a ./build rewrite_confs and get them working then hand edit the user nginx conf files as all rewrite rules (friendly urls, added modules like flv and mp4, etc) get overwritten.
anytime I add or remove a domain I need to deal with this.
sad as nginx works much better when getting slammed with users on sites.
oh well, I am done.
not worth the continuous hassles that cpanel/ispconfig panels don't have with nginx setups.
We did not tell anywhere that nginx for DA is stable. It's still alpha. Your issue seems to be related to PHP-FPM, please post the contents of /usr/local/php5*/etc/php-fpm.conf. I think you have low request_terminate_timeout set there. Please also check /usr/local/php5*/var/log/php-fpm.log and /var/log/nginx/error_log. Thank you.
can't now as I swapped to apache and deleted nginx/php-fpm stuff.
and we've already gone through those.
oh well, I am done.
Please run
ls -l /usr/local/php54/sockets/webapps.sock
. If you do NOT get
srw-rw---- 1 webapps nginx 0 Date / Time /usr/local/php54/sockets/webapps.sock
then you need to run
chown webapps:nginx /usr/local/php54/sockets/webapps.sock
. You need to run these with nginx and not apache.
already did all tha, thanks though.
made no difference for me.
installed cpanel saturday.
I was able to get it to work on the first try. If you are willing to give it another go we can continue to troubleshoot.
