Change PHP version for user?
saosangmo
Hanoi
I have updated to DA 1.43.3 with 2 PHP versions but I can not find where to change PHP versions for my user.
could you help me?
thanks
You can do that in "Domain setup" (user level), but only if you run CustomBuild 2.0.
I installed php5.5 with mod_ruid2 and php 5.3 with suphp.
I set First PHP to 5.3 but php 5.5 ran as default
Sorry, my english isn't good!
1. upgrade your CustomBuild to 2.0
2. in options.conf
you will see"
php1_release=5.4
php2_release=no
php1_mode=mod_php
php2_mode=php-fpm
change it, to
php1_release=5.4
php2_release=5.3
php1_mode=mod_php
php2_mode=suphp
for exmple
I have the same problem, did you manage to get this working? I have set:
php1_release=5.5
php2_release=5.4
php1_mode=suphp (also tried mod_php)
php2_mode=suphp
and it appears in the domain administration as:
PHP Version Selector | Handler | Extension
First PHP | 5.5 suphp | php
Second PHP| 5.4 suphp | php54
If i switch them round, or even set both to 5.4, but php is always running as 5.5 for the domain.
Second PHP if i have selected it but don't use for the website, The server will load more cpu or mempry or not?
With PHP-FPM you will have pools for all users both for php1 and php2 (at the same time). Unused pools will use little RAM.
