init scripts on debian
soulshepard
I installed a debian (7) box with directadmin and it seems all init script installed with directadmin contain the command "status"
when performing a command /etc/init.d/directadmin status it replies with :
/etc/init.d/directadmin: line 74: status: command not found
:73 status)
:74 status $PROGNAME
it also does this with http
/etc/init.d/httpd status
/etc/init.d/httpd: line 111: status: command not found
Do more people have this and is there a solution for the internal status command.
You probably are missing a function script. My guess is /lib/lsb/init-functions isnt being linked in correctly.
ok, but its a default install.. and have more problems with this install very strange..
btw I compared these two from centos and debian and inboth nothing is reffered to status
scsi thanks for the hint:
it seems all init scripts installed by the directadmin custom build for debian are missing the the include path to the correct function file : /lib/lsb/init-functions (if this is the default for debian)
for centos it seems: /etc/rc.d/init.d/functions
to summarize: (copy and pasted)
It's specific to whatever distribution you're running. Debian and Ubuntu have /lib/lsb/init-functions; SuSE has /etc/rc.status; none of them are compatible with the others. In fact, some distributions don't use /etc/init.d at all, or use it in an incompatible way (Slackware and Arch occur to me off the top of my head; there are others).
so in the installer I must assume be a mistake for the custombuild 2.0
when I add this to the directadmin init script then it works (these sections are copied from centos
__pids_var_run() {
        local base=${1##*/}
        local pid_file=${2:-/var/run/$base.pid}
        pid=
        if [ -f "$pid_file" ] ; then
                local line p
                read line < "$pid_file"
                for p in $line ; do
                        [ -z "${p//[0-9]/}" -a -d "/proc/$p" ] && pid="$pid $p"
                done
                if [ -n "$pid" ]; then
                        return 0
                fi
                return 1 # "Program is dead and /var/run pid file exists"
        fi
        return 3 # "Program is not running"
# Output PIDs of matching processes, found using pidof
__pids_pidof() {
        pidof -c -o $$ -o $PPID -o %PPID -x "$1" || \
                pidof -c -o $$ -o $PPID -o %PPID -x "${1##*/}"
status() {
        local base pid pid_file=
        # Test syntax.
        if [ "$#" = 0 ] ; then
                echo $"Usage: status [-p pidfile] {program}"
                return 1
        fi
        if [ "$1" = "-p" ]; then
                pid_file=$2
                shift 2
        fi
        base=${1##*/}
        # First try "pidof"
        __pids_var_run "$1" "$pid_file"
        RC=$?
        if [ -z "$pid_file" -a -z "$pid" ]; then
                pid="$(__pids_pidof "$1")"
        fi
                echo $"${base} (pid $pid) is running..."
                return 0
        fi
        case "$RC" in
                0)
                        return 0
                1)
                        echo $"${base} dead but pid file exists"
                        return 1
        esac
        # See if /var/lock/subsys/${base} exists
        if [ -f /var/lock/subsys/${base} ]; then
                echo $"${base} dead but subsys locked"
                return 2
        fi
        echo $"${base} is stopped"
        return 3
[/code]
the real fix would be to add the correct path for the distributions and in this case debian to the directadmin based init scripts it is there in older versions of directadmin but not this debian.
I created on debian the following file: /lib/lsb/init-functions.d/directadminfix
cat > /lib/lsb/init-functions.d/directadminfix << EOF1
__pids_var_run() {
        local base=${1##*/}
        pid=
                local line p
                for p in $line ; do
                done
                        return 0
                fi
        fi
__pids_pidof() {
status() {
        # Test syntax.
                return 1
        fi
                pid_file=$2
                shift 2
        fi
        base=${1##*/}
        # First try "pidof"
        RC=$?
        fi
                return 0
        fi
        case "$RC" in
                0)
                        return 0
                1)
                        return 1
        esac
                return 2
        fi
        return 3
EOF1
now the function status and sub functions of __pids_var_run & __pids_pidof required by the centos status are added
and we need to include the functions in the wrong install scripts on the top below the #!/bin/..
debian:
# Source function library.
. /lib/lsb/init-functions
the following init scripts seem to be wrong from the install (that uses the status functions)
(I made a list with)
for i in `grep -lir "status)"`; do sh /etc/init.d/$i status; done | grep -i "status: command not found"
./mysqld: line 51: status: command not found
./dovecot: line 68: status: command not found
./freshclam: line 44: status: command not found
./da-popb4smtp: line 62: status: command not found
./clamd: line 44: status: command not found
./proftpd: line 57: status: command not found
./pure-ftpd: line 49: status: command not found
./httpd: line 113: status: command not found
./directadmin: line 77: status: command not found
./exim: line 66: status: command not found
I added
to all these files..
cd /etc/init.d
for i in "mysqld dovecot freshclam da-popb4smtp clamd proftpd pure-ftpd directadmin exim"; do sed -i 's/#!\/bin\/sh/#!\/bin\/sh\n\n# Source function library.\n. \/lib\/lsb\/init-functions\n/' /etc/init.d/$i; done
sed -i 's/#!\/bin\/bash/#!\/bin\/bash\n\n# Source function library.\n. \/lib\/lsb\/init-functions\n/' /etc/init.d/httpd
and check again:
for i in `grep -lir "status)"`; do ./$i status; done | grep -i "status: command not found"
-su: ./skeleton: Permission denied
you could add it also to the skeleton file to have newly created entries also corrected..
In regards to the "status" call, I've just checked our test box and it throws the same error, so you're system is "normal" and likely matches everyone elses... that function was just never checked or implemented.
Personally, I always run
ps ax | grep directadmin
to see what's running.
Hi guys.
It all started with issue with proftpd after I had to reboot the server.
Now all services are up, besides proftpd:
root@s1:/etc# service proftpd start
/etc/init.d/proftpd: line 19: /etc/rc.d/init.d/functions: No such file or directory
I can't start it from GUI as well.
What is more interesting, I can not do anything with other services:
root@s1:/etc# service httpd status
Building from custombuild 2.0 does not change anything.
Could you please help me?
OS: Debian 7 x64
