[PLUGIN] CustomBuild 2.0
For CB 2.0 - the answer is yes, latest is 932, but latest version of plugin is 1.0.14.
Hi, i can just get 2.0.0-RC7 rev: 928, guess i am on the wrong updateserver.
Please how can i set the updateserver and which one i must choose for the v932?
All mirrors are usually updated in 24-hours, however, the main one is files1.directadmin.com, from which all the other mirrors are synced :)
Hello
Warning :
It's not recommended to use apache with mod_ruid2 & suPHP enabled. It's a redundant and slow combination.
options.conf
#Advanced Settings
autoconf=yes
automake=yes
libtool=yes
curl=yes
#Expert Settings (!)
zlib=no
new_zlib=no
new_xml2=yes
new_pcre=no
new_suphp=no
old_apr_util=no
mysql_force_compile=
mysql_force_compile=no
rev 924 small skin issue, in the active/inactive instructions display you can click inactive and both turn blue.
That is just a demo button to show the coloring :) I could simply replace it with an image, if you'd like it not to be clickable (active).
that may be a good idea, just to avoid confusion.
thinking as a newbie I could see someone thinking it turned all of CB on or off.
rare chance but an image would fix all that.
Installed custom build 2.0 and plugin, I can run all the commands via terminal but can't change anything below is a screen shot.
Running centos 6.5 64bit
Php 5.5.16
DirectAdmin 1.45.4
Please read the red box at the top-left corner :) It seems you have not succeeded to upgrade to CustomBuild 2.0, and you're still running CustomBuild 1.x ("./build version" would show the current version for you). How to upgrade: http://forum.directadmin.com/showthread.php?t=44743.
Wow I totally disregarded that version in the top of the red box. I was certain I had installed the v2.0 however it appears I must have copied the custombuild 1.x line. Thanks all fixed!
after updating to 2.0.0-RC7 (rev: 1027) under build software BUILD ALL is only option.
no ability to build specific items.
