Permission issues with Wordpress and default DirectAdmin install
Magistar
My wordpress installs are having some issues on my new DirectAdmin server.
There are two problemes
-I cannot install/update unless I set all folders to 777 (instead of 755)
-Plugins like W3 totalcache are generating folders under the username "apache" instead of appropriate the directadmin user.
I have seen these exact issue at my previous host where I have a reseller DirectAdmin package. At that host switching to Php 5.4 solved these issues completely. Unfortantely my "own" DirectAdmin install is already using Php 5.4 by default.
I guess this is related to a php setting. But I have not been able to found out what/why.
Is there anyone that has experienced the same issue and knows how to solve it?
regards
regards
edit: I found something called mod_rui2. Never heard of it. Is there a downside to using this (http://forum.directadmin.com/showthread.php?t=37467)?
You 'only' need to 777 the cache-folder, and the 'uploads' folder down in wp-content. Nothing else.
I have a few WP installations on my vps and they seem to run without any issues this way.
mod_ruid2,
I've had it running for a very short while and I didn't need to 777 any folder anymore.
But due to other (unrelated) issues I had to revert to a backup before mod_ruid was activated and didn't reinstall it yet.
mod_ruid2,
I have seen some issues with updating wordpress without 777 everywhere. Since I want my users to be able upgrade their wordpress I need to fix that :(.
What sort of issues did mod_ruid cause? Then I know what to look for.
I strongly suggest mod_ruid2 to solve the problem. Install CustomBuild to make everything easy :D.
Search these forums.
You should use Custombuild 2 and either mod_php+mod_ruid2 or php-cgi (php-fcgi, php-fpm, suphp). The forums have enough information on any of them, so please search function.
