- Feb 27, 2003
We're please to announce the Release Candidate of DirectAdmin 1.47.0.
Update: RC 3 - Jan 8, 2015.
You can see all changes here:
directadmin.com/versions.php?version=1.470000
This is a major release with many new features, and many bug-fixes.
New Features:
Bugfixes:
RC 2 updates:
RC 3 updates:
For anyone who is able to test these changes, they're available in the pre-release section.
Note that BlockCracking/EasySpamFigher do require SpamBlocker exim.conf 4.3.2. or higher.
Please report any issues to this thread.
If you test a particular change and it works correctly, please let us know here as well, so we also know what does work.
New Features:
- BlockCracking/EasySpamFigher/SpamBlocker-4.3.2: Ready for BETA testing
- Ability to remove INBOX from the IMAP folder names
- DA can manage the outbound E-Mail IPs for a given domain/IP.
- BFM can scan apache logs for WordPress wp-login.php attacks (off by default)
- Message System: Option to clear all messages for given subject/date
- ajax=1 enabled by default
- user_can_set_email_limit=1 enabled by default
- add_userdb_quota=1 default for new installs
Bugfixes:
- Depreciated: connect_timeout. Replaced with handshake_timeout and request_timeout.
- Security: mysql upload/restore to use custom .my.cnf.
- ~/Maildir properly excluded from home.tar.gz without "E-Mail Data" checkbox.
- Better bytes sending in DA code.
RC 2 updates:
- Huge "Table class" performance boost
- Security improvement for copying files
- Can now see php/cgi/ssl domain settings on Show Users page.
- Apache mod_security templates changes for CustomBuild 2.0 (BETA)
RC 3 updates:
- Fixed table quicksort segfault from RC2.
- Certificate Requests to no longer have challengePassword
- Relating to table optimization, removed old way of hiding true cell value using empty href trick, allowing for vastly smaller bytes size.
