Arieh
It's definitely supported by LE, the python client works fine indeed. But the project now doesn't use the python lib at all, instead a php lib is being used. The bug is located either in that lib or in the implementation. It's only a matter of troubleshooting which Wouter said he will do later. Of course if someone else has the time and knowledge to dig in to it earlier, they are more than welcome to do so
