vancanneyt
- Dec 13, 2012
I'm on CentOS 6.7, Apache 2.4, OpenSSL 1.0.1e. So SNI should be supported. Enabled it in directadmin.conf (enable_ssl_sni=1), rewrote configs with ./build rewrite_confs and restarted DirectAdmin. SSL certificate page on user level still gives same error 'Cannot Execute Your Request - You can only add a certificate if you own the ip you are using'SSL rules haven't changed, but you can enable SNI if your OS supports it (most new ones do)
http://www.directadmin.com/features.php?id=1100
Update: okay, after some digging i had to enable ssl in domain administration as well, then a rewrite_confs to get it working
