Best method to enable HSTS in Custom HTTPD Configurations?
zmippie
I have this in the first block of my (nginx) "Custom HTTPD Configurations" for the hostname domain:
|*if SSL_TEMPLATE="0"|
	listen xxx.xxx.xxx.xxx:80;
	return 301 https://$server_name$request_uri;
|*endif|
It is to redirect all traffic on port 80 to 443/https. This worked exactly as expected until yesterday, when I upgraded DA to 1.5 and enabled LetsEncrypt. I now get the following error:
nginx: [emerg] a duplicate listen xxx.xxx.xxx.xxx:80 in
/usr/local/directadmin/data/users/admin1/nginx.conf:16
So I removed the "listen" line, and all is well. I see that there's a "server" block in nginx-vhosts.conf which matches the same conditions. So I'm wondering: was it there before 1.5, or is this new? What *is* the best way to redirect to https in a HSTS setup in DirectAdmin? (I have the require HSTS options added through CUSTOM3 using |*if SSL_TEMPLATE="1"|).
It's not new. To enable HSTS you need an additional line in headers too, so the following should be enough:
|*else|
	add_header Strict-Transport-Security max-age=15768000;
|*endif|
Thanks guys. Yes, I have the headers and a number of related options for perfect forward secrecy. I was just wondering if this is the right way to do it. But judging from your examples, I guess it is. Thanks!
Still not sure why the "listen:80" error suddenly crops up now.
You don't have to include the listen:80 part. I used the top box (CUSTOM) and entered this;
	# Redirect everything to HTTPS           #
        location / {
|*endif|
And it works perfectly. I use the CUSTOM3 box for custom ssl settings;
	# Custom SSL Configuration               #
        include /etc/nginx/custom_settings/custom_ssl_settings.conf;
|*endif|
That's indeed a neat way to reuse your config for multiple domains. Thanks!
On a related note: I searched the web thoroughly, but I couldn't find a way to dump the entire nginx contexts configuration with all includes expanded. Is this at all possible?
I found this tread and HTTP Strict Transport Security ( HSTS )
I'm trying to combine them and use Global custom include templates for apache/nginx.
So my /usr/local/directadmin/data/templates/custom/cust_httpd.CUSTOM.post looks like this:
# Custom HSTS Configuration #
Header always set Strict-Transport-Security "max-age=31536000; includeSubDomains"
|*endif|
But when I rewrite configs, nothing is added.
/usr/local/directadmin/dataskq d
/etc/init.d/httpd restart
I must be doing something wrong. :confused:
Note: Indeed my A rating goes to A+ on SSL labs, when I add hsts manually.
OK, I see. Just tested on my end:
1. created not empty:
/usr/local/directadmin/data/templates/custom/cust_httpd.CUSTOM.1.post
/usr/local/directadmin/data/templates/custom/cust_httpd.CUSTOM.1.pre
/usr/local/directadmin/data/templates/custom/cust_httpd.CUSTOM.pre
2. regenerated virtualhosts with
./build rewrite_confs
No line from the cust_httpd.CUSTOM* were added.
No line was shown on CMD_CUSTOM_HTTPD page in Directadmin.
So I guess either the help page is missing something or the feature is not working at all.
Go and download a pre-release binary from the client area if you bought a license from Directadmin directly, or wait for a official release.
Ok, it seems I have to wait for the official release then. I have a lifetime license, but bought from my webhoster.
Hello i try to use this in custom3 and did not redirect, please advise
location / {
|*endif|
nginx or apache?
Make sure you are using nginx for the command you are using.
If you are using apache the following lines work for me (in CUSTOM3):
RewriteEngine On
RewriteCond %{HTTPS} off
RewriteRule (.*) https://%{HTTP_HOST}%{REQUEST_URI} [R=301,L]
location / {
|*endif|
|*else|
|*endif|
Sorry for old-post up, but where I need to add it? if I have nginx_apache php-fpm ?
I know that was an old question.. to help others, If you use nginx, you can see this (only need to copy paste): https://docs.directadmin.com/webser...tml#how-to-install-the-pagespeed-nginx-module
Then you can run ./build rewrite_confs
For apache, it is different that you need to use .htaccess: https://docs.directadmin.com/webser...to-force-redirecting-to-https-for-all-domains
For nginx_apache reverse proxy, I use the nginx block and it works (found the header)
To test your website whether it has security header, use the following code:
curl -s -D- https://domaion.com | grep -i Strict
It should output the following hsts header (if not something is wrong)
strict-transport-security: max-age=31536000
