please try:
/usr/local/directadmin/scripts/set_permissions.sh da_files
and
/usr/local/directadmin/scripts/set_permissions.sh etc_configs
Best regards
Please post the output for:
ls -l /etc | grep bind
Best regards
Why do you have a custom template? If there is no reason why, just delete that file and DA will use the standard template.
Best regards
No, if you want to use DMARC you may want to use this guide: https://help.directadmin.com/item.php?id=596
Best regards
