Why is /etc/httpd/conf/ssl.crt/server.ca empty? (httpd fail to start)
LowRadio
Woke up to failed httpd email notifications
check whats going on
journalctl -xe
server.org systemd[1]: httpd.service: main process exited, code=exited, status=1/FAILURE
server.org kill[5219]: kill: cannot find process ""
server.org systemd[1]: httpd.service: control process exited, code=exited status=1
server.org systemd[1]: Failed to start The Apache HTTP Server.
-- Subject: Unit httpd.service has failed
-- Defined-By: systemd
-- Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel
-- Unit httpd.service has failed.
Doesn't help much, next try:
/var/log/httpd/error_log
AH00016: Configuration Failed
[Wed Jun 07 10:23:08.001930 2017] [ssl:emerg] [pid 5425:tid 139933368420416] AH02311: Fatal error initialising mod_ssl, exiting. See /var/log/httpd/domains/somedomain.com.error.log for more information
ok still need more info:
AH01895: Unable to configure verify locations for client authentication
SSL Library Error: error:0B084009:x509 certificate routines:X509_load_cert_crl_file:PEM lib
Well it appears to be an SSL issue:
/usr/local/directadmin/data/users/someuser/httpd.conf
<VirtualHost 1.22.333.4:443>
        SSLEngine on
        SSLCertificateFile /usr/local/directadmin/data/users/someuser/domains/somedomain.com.cert
        SSLCertificateKeyFile /usr/local/directadmin/data/users/someuser/domains/somedomain.com.key
        SSLCACertificateFile /etc/httpd/conf/ssl.crt/server.ca   [COLOR="#FF0000"]<---(hmmm thats odd)[/COLOR]
cat /etc/httpd/conf/ssl.crt/server.ca
-----BEGIN CERTIFICATE-----
-----END CERTIFICATE-----
where did it go?
Find backup, restored the /etc/httpd/conf/ssl.crt/server.ca file.
systemctl start httpd.service
Success!
Check logs to see what happened shortly before httpd start fail:
/var/log/directadmin/system.log
2017:06:07-00:10:29: LetsEncrypt(8797): /usr/local/directadmin/scripts/letsencrypt.sh renew 'server.org' 4096 /usr/local/directadmin/conf/ca.san_config /var/www/html
2017:06:07-00:12:44: LetsEncrypt(8797): exit code: 0
Not sure if that was the caused /etc/httpd/conf/ssl.crt/server.ca to become blank.
Any ideas what it could be?
Im running on Centos7 64
Apache 2.4.23 with SNI and HTTP2 enabled
everything else is up to date.
Is the script letsencrypt.sh updated? Did you try to run manually the letsencrypt.sh renew command from the logs? What results did you have?
letsencrypt.sh #VERSION=1.0.10
I think I did try to run it before restoring /etc/httpd/conf/ssl.crt/server.ca and it failed because apache would not start.
However, after I restored it, I did run letsencrypt.sh manually to update the hostserver cert (it was due for an update anyway) and it worked as it should.
I don't have a /var/log/letsencrypt.log any idea where I could find more detailed logs?
The lines from /var/log/directadmin/system.log included a command
actually I was refering to it, and you already answered.
Do you have custom templates for virtual hosts of Apache? The line SSLCACertificateFile /etc/httpd/conf/ssl.crt/server.ca should not specify server.ca there.
Probably it is too late, but I would check last modification time of the file /etc/httpd/conf/ssl.crt/server.ca and then would check cron logs in order to find what was running at that time.
No custom template.
The line in /usr/local/directadmin/data/users/someuser/httpd.conf that pointed to SSLCACertificateFile /etc/httpd/conf/ssl.crt/server.ca was changed because in DA, USER section I switched from a letsencrypt cert to a localcert hoping the would fix the apache startup failure.
I added that to my post just to show how I found the corrupt ssl.crt/server.ca file.
Once apache was running I switched back to the letsencrypt cert.
I also tried to disable ssl for that user's domain but apache would fail anyway and give me a similar error but for the next domain on the list and so on.
yeah it is too late but server.crt.backup had a time stamp
-rw-------  1 root root 2151 Jun  7 00:12 server.crt.backup
I checked the cron logs and /var/log/messages. Can't see anything of importants.
Jun  7 00:06:18 gce run-parts(/etc/cron.hourly)[8720]: finished 0yum-hourly.cron
Jun  7 00:07:01 gce CROND[8737]: (root) CMD (/usr/local/directadmin/dataskq)
Jun  7 00:08:01 gce CROND[8768]: (root) CMD (/usr/local/directadmin/dataskq)
Jun  7 00:09:01 gce CROND[8782]: (root) CMD (/usr/local/directadmin/dataskq)
Jun  7 00:10:01 gce CROND[8796]: (root) CMD (echo 'action=tally&value=all' >> /usr/local/directadmin/data/task.queue)
Jun  7 00:10:01 gce CROND[8797]: (root) CMD (/usr/local/directadmin/dataskq)
Jun  7 00:11:01 gce CROND[10848]: (root) CMD (/usr/local/directadmin/dataskq)
Jun  7 00:12:01 gce CROND[10867]: (root) CMD (/usr/local/directadmin/dataskq)
Jun  7 00:13:01 gce CROND[11267]: (root) CMD (/usr/local/directadmin/dataskq)
I'm thinking its an issue with letsencrypt
https://letsencrypt.status.io/pages/history/55957a99e800baa4470002da
June 8, 2017 6:10PM MDT
June 9, 2017 12:10AM UTC
[Investigating] We are investigating a disruption to certificate issuance.
