Woke up to failed httpd email notifications
check whats going on
journalctl -xe
Doesn't help much, next try:
/var/log/httpd/error_log
ok still need more info:
/var/log/httpd/domains/somedomain.com.error.log
Well it appears to be an SSL issue:
/usr/local/directadmin/data/users/someuser/httpd.conf
cat /etc/httpd/conf/ssl.crt/server.ca
where did it go?
Find backup, restored the /etc/httpd/conf/ssl.crt/server.ca file.
systemctl start httpd.service
Success!
Check logs to see what happened shortly before httpd start fail:
/var/log/directadmin/system.log
Not sure if that was the caused /etc/httpd/conf/ssl.crt/server.ca to become blank.
Any ideas what it could be?
Im running on Centos7 64
Apache 2.4.23 with SNI and HTTP2 enabled
everything else is up to date.
journalctl -xe
server.org systemd[1]: httpd.service: main process exited, code=exited, status=1/FAILURE
server.org kill[5219]: kill: cannot find process ""
server.org systemd[1]: httpd.service: control process exited, code=exited status=1
server.org systemd[1]: Failed to start The Apache HTTP Server.
-- Subject: Unit httpd.service has failed
-- Defined-By: systemd
-- Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel
-- Unit httpd.service has failed.
AH00016: Configuration Failed
[Wed Jun 07 10:23:08.001930 2017] [ssl:emerg] [pid 5425:tid 139933368420416] AH02311: Fatal error initialising mod_ssl, exiting. See /var/log/httpd/domains/somedomain.com.error.log for more information
AH01895: Unable to configure verify locations for client authentication
SSL Library Error: error:0B084009:x509 certificate routines:X509_load_cert_crl_file:PEM lib
<VirtualHost 1.22.333.4:443>
SSLEngine on
SSLCertificateFile /usr/local/directadmin/data/users/someuser/domains/somedomain.com.cert
SSLCertificateKeyFile /usr/local/directadmin/data/users/someuser/domains/somedomain.com.key
SSLCACertificateFile /etc/httpd/conf/ssl.crt/server.ca [COLOR="#FF0000"]<---(hmmm thats odd)[/COLOR]
-----BEGIN CERTIFICATE-----
-----END CERTIFICATE-----
Success!
2017:06:07-00:10:29: LetsEncrypt(8797): /usr/local/directadmin/scripts/letsencrypt.sh renew 'server.org' 4096 /usr/local/directadmin/conf/ca.san_config /var/www/html
2017:06:07-00:12:44: LetsEncrypt(8797): exit code: 0
