DirectSlave/GO 3 - public beta
roman_m
Ukraine, Kyiv
Original DirectSlave thread: https://forum.directadmin.com/threa...ove-zones-on-slave-without-directadmin.43924/
UPDATE: DirectSlave Updated to version 3.5.1
→ FIXED - DirectAdmin 1.69 compatibility for /CMD_API_DNS_ADMIN:
· Proper handling of action=delete when parameters are sent in POST body (form-urlencoded), not only in query string.
· Backward compatible with older DirectAdmin versions that send action/select0 in the URL.
· Added robust request parsing fallback for cases where DA omits Content-Type.
→ Improved rawsave handling:
· dns_write_post.sh added (see /scripts) · Zonefile content is taken directly from request body and passed to dns_write_post.sh.
· Prevents losing POST body after form parsing.
· Delete now supports multiple domains in a single request (select0..selectN).
· Domain deletion is idempotent in DNS-less/dev setups (no false failures when zone artifacts are missing).
DirectSlave 3.4.2-Advanced
→ BUGFIX: pid file was not written when running under Linux systemd (reported by frog9394, forum thread )
+ SIGHUP now handled correctly. On SIGHUP DirectSlave reopens log files and reload configured SSL/TLS certificates (if any)
+ Automatic update notification added. No autodownload/autoinstall available.
+ Added systemd service file - /usr/local/directslave/etc/systemd/directslave.service
· pprof debugger is still listening on http://127.0.0.1:2223/
Warning: Debug version with pprof debugger enabled.
· pprof debugger is listening on http://127.0.0.1:2223/ (localhost only)
If you aquire high memory usage (>50Mb) of directslave binary throug the time, please do
curl http://127.0.0.1:2223/debug/pprof/heap > heap.dump
and send me a heap.dump file to [email protected]
Please update -- https://directslave.com/download/Latest.tar.gz
MD5: e2b24d9954f19e56a24b67f281d40a10
(see https://directslave.com/download)
All versions in one place -- https://directslave.com/
Web interface demo available -- https://directslave.com:2224 demo:demo123
For updating, see this post http://forum.directadmin.com/showthread.php?t=54992&page=2&p=289070#post289070
Hi everybody!
A long time ago in a galaxy far far away ...
I was released a DirectSlave software. Many of forum users helped me a lot to debug and improve DS and bring this software to really corporate production level.
But now, it's time for something new!
So, I proudly introduce you a new DirectSlave/GO (GO - because it's writen in GoLang and setup is easy as 1.. 2.. 3.. GO!):
+ Binary!
+ Rock solid
+ Statically linked
+ Cross-platform
+ TLS 1.2 and HTTP/2 onboard
+ /CMD_EMAIL_POP support
+ Less memory footprint (can be used on tiny virtual instances with < 512Mb RAM)
+ Less CPU usage
+ A lot of improvements in speed
+ No more dependencies / perl modules
+ Setup is easy as 1.. 2.. 3.. GO!
+ Available for Linux i386/x32_64/arm & FreeBSD i386/amd64 (all in single archive distribution).
Download it here -- https://regme.in/download/directslave-3.0.2-beta-all.tar.gz
First time installing: see README
Updating from 2.x: see UPDATING
Also, feel free to contact me.
Have a nice expirience with brand new DirectSlave/GO!
1.. 2.. 3.. GO!
Just installed it on Ubuntu 16.04.
run /usr/local/directslave/bin/directslave --check everything is OK
After create test.com domain on DA for testing, only /etc/named/secondary/named.conf file created, there is no test.com.db zone file.
error.log
2017/07/07 19:16:51 DEBUG: &{Method:POST URL:/CMD_API_DNS_ADMIN?action=rawsave&domain=test.com Proto:HTTP/1.0 ProtoMajor:1 ProtoMinor:0 Header:map[Authorization:[Basic YWRtaW46R2lARHV5NzI3NQ==] Content-Length:[867]] Body:0xc420019f40 GetBody:<nil> ContentLength:867 TransferEncoding:[] Close:true Host: Form:map[action:[rawsave] domain:[test.com]] PostForm:map[] MultipartForm:<nil> Trailer:map[] RemoteAddr:104.207.135.112:52941 RequestURI:/CMD_API_DNS_ADMIN?action=rawsave&domain=test.com TLS:<nil> Cancel:<nil> Response:<nil> ctx:0xc4200e7980}
2017/07/07 19:16:51 DEBUG: &{Method:POST URL:/CMD_API_DNS_ADMIN?action=rawsave&domain=test.com Proto:HTTP/1.0 ProtoMajor:1 ProtoMinor:0 Header:map[Authorization:[Basic YWRtaW46R2lARHV5NzI3NQ==] Content-Length:[1356]] Body:0xc4201803c0 GetBody:<nil> ContentLength:1356 TransferEncoding:[] Close:true Host: Form:map[domain:[test.com] action:[rawsave]] PostForm:map[] MultipartForm:<nil> Trailer:map[] RemoteAddr:104.207.135.112:60540 RequestURI:/CMD_API_DNS_ADMIN?action=rawsave&domain=test.com TLS:<nil> Cancel:<nil> Response:<nil> ctx:0xc4200e7e90}
2017/07/07 19:16:57 exit status 1
action.log
2017/07/07 19:16:50 Authorization passed for admin from 104.207.135.112
2017/07/07 19:16:50 Checking test.com from 104.207.135.112
2017/07/07 19:16:50 Domain test.com not exists
2017/07/07 19:16:51 Authorization passed for admin from 104.207.135.112
2017/07/07 19:16:51 Domain test.com added with primary 104.207.135.112
2017/07/07 19:16:51 Reloaded test.com from master 104.207.135.112
2017/07/07 19:16:57 RNDC queue triggered with 2 events
2017/07/07 19:16:57 RNDC output:
access.log
2017/07/07 19:16:50 [104.207.135.112] "GET /CMD_API_DNS_ADMIN?action=exists&domain=test.com HTTP/1.0"
2017/07/07 19:16:51 [104.207.135.112] "POST /CMD_API_DNS_ADMIN?action=rawsave&domain=test.com HTTP/1.0"
CentOS 7:
Trying to run directslave --password, but I am getting:
DEBUG: Running as root (0), dropping privileges to 25:25
panic: runtime error: invalid memory address or nil pointer dereference
[signal SIGSEGV: segmentation violation code=0x1 addr=0x0 pc=0x596ca4]
goroutine 1 [running]:
log.(*Logger).Output(0x0, 0x2, 0xc4200422d0, 0x41, 0x0, 0x0)
/usr/local/go/src/log/log.go:149 +0x54
log.(*Logger).Fatal(0x0, 0xc4200379a0, 0x1, 0x1)
/usr/local/go/src/log/log.go:188 +0x6a
main.UpdatePasswordFile()
/export/store/Project/home/golang/directslave/directslave.go:860 +0x247
main.RunWithOption(0x7fffa6eff793, 0xa)
/export/store/Project/home/golang/directslave/directslave.go:283 +0x22f
main.main()
/export/store/Project/home/golang/directslave/directslave.go:98 +0xfd
CentOS 7:
main.main()
path to rndc was wrong, changed the path to rndc and it's working now
error.log
action.log
access.log
I am not sure if this will help, but I added allow-transfer and allow-notify in /etc/bind/named.conf.options (directadmin server) and pointed to the IP address of the slave.
allow-transfer { 1.2.3.4; };
allow-notify { 1.2.3.4; };
notify yes;
Is your named-workdir /etc/named/secondary ? Make sure bind/named has access to directory /etc/named/secondary/.
notify yes;
I update DA config and re-check the bind permission OK, but still no .db zone file in named-workdir.
Thanks, I'll create centos 7 install to test. Did you use "yum install bind9" to install bind your centos ?
I did:
yum install bind
firewall-cmd --permanent --zone=public --add-port=2222/tcp
firewall-cmd --permanent --zone=public --add-port=53/udp
firewall-cmd --reload
chown -R named:named /usr/local/directslave
chown -R named:named /var/named
I put the slaves in /var/named directory
named_workdir   /var/named/slaves
named_conf      /var/named/directslave.inc
rndc_path       /usr/sbin/rndc
Change named_workdir (in directslave.conf) to: /var/cache/bind
Restart directslave (and bind9)
See file: /etc/apparmor.d/usr.sbin.named
  # /etc/bind should be read-only for bind
  # /var/lib/bind is for dynamically updated zone (and journal) files.
  # /var/cache/bind is for slave/stub data, since we're not the origin of it.
  # See /usr/share/doc/bind9/README.Debian.gz
  /etc/bind/* r,
  /var/lib/bind/** rw,
  /var/lib/bind/ rw,
  /var/cache/bind/** lrw,
  /var/cache/bind/ rw,
How to make directslave auto start after reboot in Ubuntu ?
There are several ways. I have not tested it yet with directslave and already erased the ubuntu test system.
A: crontab
You can use crontab, by adding @reboot /usr/local/directslave --run
1. crontab -e
2. @reboot /usr/local/directslave --run
B: /etc/rc.local
You can edit /etc/rc.local file and add /usr/local/directslave --run
c: Upstart or systemd
I believe Ubuntu 16.04 use systemd, please look at the example script at https://wiki.ubuntu.com/SystemdForUpstartUsers
The location of the new service file should be in /etc/systemd/system or /lib/systemd/system
Finally getting some time to work on implementing this. Quick, lazy question on the slave server, does anybody have any recommendations on a cheap, reliable (cloud) provider in the US that they like? I have an AWS account, but their hosting services seem to get pricey quickly, IIRC. I've worked with a lot of budget, shared hosts over the years, but most don't allow much/any shell access....
Check lowendbox.com, companies post their offers on that website. You can see the user experiences/reviews on each deal.
I'm trying to install DirectSlave on centos 7.
Everything is working i guess.
Except my *.db files look weird and not like they are on the server with directadmin.
This is how my *.db files right now, this can't be right?
^@^@^@^B^@^@^@^AY�^U-^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@n^@^A^@^F^@^@^@^@8@^@^@^@^A^@^T^Oaquariummanager^Bnl^@^@D^Cns1^Hhostplus^Bnl^@
hostmaster^Oaquariummanager^Bnl^@x:��^@^@8@^@^@^N^P^@^Ru^@^@^AQ�^@^@^@N^@^A^@^B^@^@^@^@^A,^@^@^@^B^@^T^Oaquariummanager^Bnl^@^@^Q^Cns1^Hhostplus^Bnl^@^@^Q^Cns2^Hhostplus^Bnl^@^@^@$^Dmail^Oaquariummanager^Bnl^@^@^@^@1^@^A^@^A^@^@^@^@^A,^@^@^@^A^@^W^Baa^Oaquariummanager^Bnl^@^@^D%a�^C^@^@^@
I've 3 other domains setup and al look somewhat similar.
Does anybody have this same problem and how did they fix it?
There is also no error or what so ever.
