Stop letsencrypt error messages
ViAdCk
When a domain isn't pointing to the server anymore, and letsencrypt is unable to renew the certificate, directadmin sends a warning message every day to the admin user which is getting a bit annoying. Does anyone know if it's possible to disable these messages? Even after deleting this domain from the server the message still comes in everyday.
You can disable auto-renew at user level, it's on SSL manager page for the desired domain.
If you deleted a domain from your server and still receive reminders on cert renewal then they most likely are sent from let's encrypt directly.
The messages are sent inside the directadmin internal ticket system.
One of the domains has been deleted from the server which means I can't disable the renewal but directadmin is still sending the daily reminders.
If you forgot to do that part (disable auto-renew at user level) and also if you deleted the domain then you can't handle this out of DA anymore, should be a future request as some domainowners sell their domains and/or moving not telling timely to serveradmin then this could happens.
So a overview wich domains has a LETsencrypt active and are still actrive domain on the server but also you can there tick wich not used anywmore to delete the LE renewal.
If domains are moved somewhere else yup then maybe only the message should be stored not that many times and not emailed such oft also, don't know if you then could stop LE for trying/sending if no other new LE CERT on the new location is running for that domain?
