- Feb 27, 2003
We're pleased to announce the DirectAdmin 1.53.0 Release Candidate:
Version 1.53.0 RC1
The full list of changes (there are many) are here:
https://www.directadmin.com/versions.php?version=1.530000
The changes range from new features, bugfixes, to finishing up the last of the json for the new skin (which is now in public testing)
Noteworthy changes:
A few of the bugfixes
To test these binaries now, please grab them from the pre-release area:
https://help.directadmin.com/item.php?id=408
They will still show DA version 1.52.1, but the "./directadmin o" compile date should show "Feb 27 2018" or newer.
If you find any issues, for now, please report them here, rather than everyone flooding us with the same issue in the email or ticket systems
Version 1.53.0 RC1
Noteworthy changes:
- SPF default went from ~all and is now -all
- Ability to set the /home directory in the packages
- Show multiple remote Show All Users list in the local Show All Users page (not yet cached, so it can be slow for large remote lists)
- Separate brutecount into brutecount and brute_dos_count
- check exim paniclog every minute (may need tweaking based on future feedback)
- Ability to send POST data to plugin via stdin
- Direct crons lists from crontab output instead of conf file.
- Can block special characters for domains to force the use of punycode with newer version of named.
- Global TTL setting, easily changed
- Can change DKIM selector
- better css for long dns entries (no more <br>)
- Domain rename missed the .combined cert
- Changed process kill method prior to User removal
- MariaDB: 'authentication_string' doesn't have a default value
- XFS check at install time to automatically use_xfs_quota=0|1[/url]
- Linked AAAA IPs were not being added to pointer DNS on restore
