php 5.6 mod-php and php 7.0 ?
alipour66m
#PHP Settings
php1_release=5.6
php1_mode=mod_php
php2_release=no
php2_mode=php-fpm
opcache=no
htscanner=no
php_ini=no
php_timezone=Asia/Tehran
php_ini_type=production
ioncube=yes
zend=yes
suhosin=no
x_mail_header=yes
I need to use php 7.x for some accounts
what is best config for me?
php1_release=5.6
php1_mode=mod_php
what confing for second php (7.x) is suitable?
and how to build it correctly?
First decide what you exactly want.
Then run for example:
./build set php1_mode mod_php
./build set php2_mode php-fpm
./build set php1_release 5.6
./build set php2_release 7.0
You could check options.conf to see if set everything right
vi options.conf
then recompile PHP
./build php n
./build rewrite_confs
No, You just have to restart Apache, but that is already done with the ./build rewrite_confs command
I'd suggest using PHP-FPM for both modes whenever it's possible,
php1_release=7.0
php1_mode=php-fpm
php2_release=5.6
php2_mode=php-fpm
Yes, I suggest setting PHP 7.0 as the default, so you will need to update existing domains settings to PHP 5.6.
Even if you decide to use PHP 5.6 I would not suggest using mod_php and PHP-FPM at the same time.
You can do it only in shell console. There is no directadmin interface for it.
Change php 5.6 to 7.2
php1_release=7.0
php1_mode=php-fpm
php2_release=5.6
php2_mode=php-fpm
Thank You, But NOW my php settings is :
PHP Settings
php1_release=5.6
php1_mode=mod_php
php2_release=7.2
php2_mode=php-fpm
opcache=no
htscanner=no
php_ini=no
ioncube=yes
zend=yes
suhosin=no
x_mail_header=yes
Can i change it to the following?
php1_release=7.2
php1_mode=php-fpm
php2_release=5.6
php2_mode=php-fpm
