Restore is unable to recognize the backup file from an NFS share
IT_Architect
I did an admin backup of a domain on an old server, copied it to an NFS share, but when I attempt to restore it to the new server from that NFS share, it won't let me. I can add the path to the folder from within DA in "Step 1: From Where", go to "Step 2: Select IP" and enter the IP, and then go to "Step 3: Select File(s)", but there will be no files that show, even though one of the files at that location is a backup file.
Have you tried changing the folder permissions?
I copied it to the server now to get the restore going, but I'll bet you're correct. Root gets there but maybe Admin doesn't. I'll have to check that.
