- Feb 27, 2003
I've updated the pre-release binaries with some fixes to php3_release, php4_release:
https://www.directadmin.com/features.php?id=2276
To clarify, this lets Users pick one of those 4 to use with their website, assuming the default is used:
php_version_selector=1
You can set the old method php_version_selector=2, so they get to pick any 2 live versions (for example: file.php for 5.6, and file.php72 for 7.2 live on their site), allow 2 at a time, where those 2 live versions can be chosen from any of the new 4 instances from the options.conf.
It does not mean a User can have 4 live versions at the same time.. so they cannot have .php, .php71, .php70, .php72 all working at the same time on their website.
There might be some confusion there
Pre-release
If you have a DA server and know your UID/LID, you don't need to know the UID password, you can just use the channel=beta method:
https://help.directadmin.com/item.php?id=408
Pre-release has other changes
Note that this has significant changes to MySQL too:
https://www.directadmin.com/features.php?id=2274
so keep that in mind if you're planning on updating the binaries.
mod_ruid2 with php-fpm
I believe permissions were updated a while ago to allow mod_ruid2 with php-fpm.. so I believe mod_php can be used for one instance with mod_ruid2, and php-fpm for others, for example.
I've just tested now, and CB2 didn't complain with those settings. (Martynas would be the final word on that, but I seem to recall it being allowed for a while now)
Pre-release
