Enable SSL on port 2222
sparek
I must be missing something.
How do you enable SSL on port 2222 for Directadmin?
I've already got a certificate, key, and ca bundle. I don't need to generate one.
But I can't for the life of me figure out what options to set in the directadmin.conf to turn this on. A lot of the documentation I see seems to be from 2009.
Shouldn't it just be a matter of telling Directadmin where the pertinent certificate files are and telling it to use ssl and restart?
What's the difference between SSL and ssl in /usr/local/directadmin/conf/directadmin.conf?
I guess that was my confusion.
It actually didn't work for me until I set SSL=1 directly in the directadmin.conf file.
SSL does not show up when running /usr/local/directadmin/directadmin c
That's what kind of threw me.
I wasn't sure if manually modifying the directadmin.conf file was the recommended way of making these changes.
