Murat
- Jan 3, 2017
CSF Messenger with reCAPTCHA doesn't work with DA server. I tried Unblock CSF module with WHMCS, and it didn't work too.
Is it just me or everyone have same issue? It seems it's impossible to unblock IP's with recaptha or script. Because it cannot access to DA server.
EDIT:
After trying everything, I found out it was the perl issue.
You need to install some perl modules to make it work. Just run this command in ssh:
yum install perl-libwww-perl net-tools perl-LWP-Protocol-https -y
and it will be fixed after you restart csf+lfd.
Problem solved.
EDIT:
Problem solved.
