Random high server load
chelssi
I'm having problems with randomly high server load .
The server go up until 10-15 and then it begins to go down slowly until 0.30, suddenly grow up until sort of 10 and again the same. This is happening about every 7-10 minutes.
I don't know which can be the problem, I've optimized php, mysql, apache, nginx... but continue happening, this is one of the reports that I receive.
I have 2 vcores with 7GB of RAM - apache_nginx | php-fpm 7.2 | opcache | memcached | sphinx
Thank you for your help.
Warning: The system load average is 13.54
9/6/2019, 23:12:05
This is an automated message notifying you that the 5 minute load average on your system is 13.54.
This has exceeded the 10 threshold.
One Minute      - 13.23
Five Minutes    - 13.54
Fifteen Minutes - 13.81
top - 23:12:02 up 3 days, 13:19,  2 users,  load average: 13.23, 13.54, 13.81
Tasks: 283 total,   2 running, 281 sleeping,   0 stopped,   0 zombie
%Cpu(s): 31.2 us, 12.5 sy,  0.0 ni, 53.1 id,  3.1 wa,  0.0 hi,  0.0 si,  0.0 st
KiB Mem :  6806976 total,   171152 free,  3747736 used,  2888088 buff/cache
KiB Swap:  2621436 total,  2333712 free,   287724 used.  2516320 avail Mem
  PID USER      PR  NI    VIRT    RES    SHR S  %CPU %MEM     TIME+ COMMAND
 1134 nginx     20   0  293768 214440   4380 S  31.2  3.2  26:23.67 nginx: worker process
13992 apache    20   0 2423408  22180   4164 S  18.8  0.3   1:01.82 /usr/sbin/httpd -DFOREGROUND
 1135 nginx     20   0  293768 214476   4416 R  12.5  3.2  27:07.71 nginx: worker process
11951 admin     20   0  360188  25660   8640 S  12.5  0.4   0:14.18 php-fpm: pool admin
15895 root      20   0   58564   2224   1476 R   6.2  0.0   0:00.01 /usr/bin/top -c -b -n 1
    1 root      20   0  191276   3012   1748 S   0.0  0.0   0:53.88 /usr/lib/systemd/systemd --switched-root --system --deserialize 22
    2 root      20   0       0      0      0 S   0.0  0.0   0:00.35 [kthreadd]
    3 root      20   0       0      0      0 S   0.0  0.0   1:03.96 [ksoftirqd/0]
    5 root       0 -20       0      0      0 S   0.0  0.0   0:00.00 [kworker/0:0H]
    7 root      rt   0       0      0      0 S   0.0  0.0   0:01.11 [migration/0]
    8 root      20   0       0      0      0 S   0.0  0.0   0:00.00 [rcu_bh]
    9 root      20   0       0      0      0 S   0.0  0.0   7:38.12 [rcu_sched]
   10 root       0 -20       0      0      0 S   0.0  0.0   0:00.00 [lru-add-drain]
   11 root      rt   0       0      0      0 S   0.0  0.0   0:01.69 [watchdog/0]
   12 root      rt   0       0      0      0 S   0.0  0.0   0:01.49 [watchdog/1]
   13 root      rt   0       0      0      0 S   0.0  0.0   0:00.96 [migration/1]
   14 root      20   0       0      0      0 S   0.0  0.0   1:11.90 [ksoftirqd/1]
   16 root       0 -20       0      0      0 S   0.0  0.0   0:00.00 [kworker/1:0H]
   18 root      20   0       0      0      0 S   0.0  0.0   0:00.00 [kdevtmpfs]
   19 root       0 -20       0      0      0 S   0.0  0.0   0:00.00 [netns]
   20 root      20   0       0      0      0 S   0.0  0.0   0:00.38 [khungtaskd]
   21 root       0 -20       0      0      0 S   0.0  0.0   0:00.00 [writeback]
   22 root       0 -20       0      0      0 S   0.0  0.0   0:00.00 [kintegrityd]
I/O Information:
Total DISK READ :     647.52 K/s | Total DISK WRITE :    1262.66 K/s
Actual DISK READ:      32.38 K/s | Actual DISK WRITE:       2.21 M/s
  TID  PRIO  USER     DISK READ  DISK WRITE  SWAPIN      IO    COMMAND
11658 be/4 admin     615.14 K/s   64.75 K/s  0.00 % 48.77 % php-fpm: pool admin
23865 be/4 mysql       0.00 B/s   64.75 K/s  0.00 % 19.56 % mysqld
11958 be/4 admin      32.38 K/s    0.00 B/s  0.00 %  0.97 % php-fpm: pool admin
23833 be/4 mysql       0.00 B/s  388.51 K/s  0.00 %  0.38 % mysqld
25048 be/4 mysql       0.00 B/s   32.38 K/s  0.00 %  0.00 % mysqld
14122 be/4 apache      0.00 B/s  679.89 K/s  0.00 %  0.00 % httpd -DFOREGROUND
14181 be/4 admin       0.00 B/s   32.38 K/s  0.00 %  0.00 % php-fpm: pool admin
    1 be/4 root        0.00 B/s    0.00 B/s  0.00 %  0.00 % systemd --switched-root --system --deserialize 22
    2 be/4 root        0.00 B/s    0.00 B/s  0.00 %  0.00 % [kthreadd]
    3 be/4 root        0.00 B/s    0.00 B/s  0.00 %  0.00 % [ksoftirqd/0]
    5 be/0 root        0.00 B/s    0.00 B/s  0.00 %  0.00 % [kworker/0:0H]
    7 rt/4 root        0.00 B/s    0.00 B/s  0.00 %  0.00 % [migration/0]
    8 be/4 root        0.00 B/s    0.00 B/s  0.00 %  0.00 % [rcu_bh]
    9 be/4 root        0.00 B/s    0.00 B/s  0.00 %  0.00 % [rcu_sched]
   10 be/0 root        0.00 B/s    0.00 B/s  0.00 %  0.00 % [lru-add-drain]
   11 rt/4 root        0.00 B/s    0.00 B/s  0.00 %  0.00 % [watchdog/0]
   12 rt/4 root        0.00 B/s    0.00 B/s  0.00 %  0.00 % [watchdog/1]
   13 rt/4 root        0.00 B/s    0.00 B/s  0.00 %  0.00 % [migration/1]
   14 be/4 root        0.00 B/s    0.00 B/s  0.00 %  0.00 % [ksoftirqd/1]
30381 be/4 memcache    0.00 B/s    0.00 B/s  0.00 %  0.00 % memcached -u memcached -p 11211 -m 128 -c 512 -l 127.0.0.1, -U 0
   16 be/0 root        0.00 B/s    0.00 B/s  0.00 %  0.00 % [kworker/1:0H]
   18 be/4 root        0.00 B/s    0.00 B/s  0.00 %  0.00 % [kdevtmpfs]
   19 be/0 root        0.00 B/s    0.00 B/s  0.00 %  0.00 % [netns]
   20 be/4 root        0.00 B/s    0.00 B/s  0.00 %  0.00 % [khungtaskd]
   21 be/0 root        0.00 B/s    0.00 B/s  0.00 %  0.00 % [writeback]
   22 be/0 root        0.00 B/s    0.00 B/s  0.00 %  0.00 % [kintegrityd]
   23 be/0 root        0.00 B/s    0.00 B/s  0.00 %  0.00 % [bioset]
/usr/sbin/ss output:
Netid  State      Recv-Q Send-Q Local Address:Port               Peer Address:Port
u_str  ESTAB      0      0         * 26362019              * 26362021
u_str  ESTAB      0      0      /var/run/dovecot/anvil 23402870              * 23402867
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 14657282              * 14657280
u_str  ESTAB      0      0         * 24006795              * 24006504
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 23247458              * 23247456
u_str  ESTAB      0      0         * 19031                 * 19032
u_str  ESTAB      0      0      /var/run/dovecot/login/login 26035663              * 26034447
u_str  ESTAB      0      0         * 26329141              * 26329143
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 25643265              * 25643262
u_str  ESTAB      0      0         * 25293053              * 25293054
u_str  ESTAB      0      0      /var/run/dovecot/config 25286361              * 25286358
u_str  ESTAB      0      0         * 23317861              * 23317468
u_str  ESTAB      0      0         * 25293841              * 25293843
u_str  ESTAB      0      0         * 25708488              * 25709005
u_str  ESTAB      0      0         * 25640709              * 25640712
u_str  ESTAB      0      0         * 25640538              * 25641538
u_str  ESTAB      0      0         * 10022173              * 10023259
u_str  ESTAB      0      0      /run/systemd/journal/stdout 19032                 * 19031
u_str  ESTAB      0      0         * 25709670              * 25709671
u_str  ESTAB      0      0         * 21081351              * 21081353
u_str  ESTAB      0      0         * 10022167              * 10023253
u_str  ESTAB      0      0         * 25630132              * 25630822
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 25286360              * 25286359
u_str  ESTAB      0      0         * 25228578              * 25228579
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 24742471              * 24742470
u_str  ESTAB      0      0         * 25709204              * 25709205
u_str  ESTAB      0      0      /var/run/dovecot/config 25708476              * 25708996
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 10023260              * 10023192
u_str  ESTAB      0      0      /var/run/dovecot/anvil 25641538              * 25640538
u_str  ESTAB      0      0         * 25047403              * 25048286
u_str  ESTAB      0      0         * 23329338              * 23329340
u_str  ESTAB      0      0         * 23247456              * 23247458
u_str  ESTAB      0      0         * 25641997              * 25641999
u_str  ESTAB      0      0         * 21081352              * 21081354
u_str  ESTAB      0      0         * 10022164              * 10022215
u_str  ESTAB      0      0      /var/run/dovecot/login/login 26362021              * 26362019
u_str  ESTAB      0      0      /var/run/dovecot/config 26329142              * 26329140
u_str  ESTAB      0      0      /var/run/dovecot/config 25630131              * 25630130
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 21231430              * 21231429
u_str  ESTAB      0      0      /var/run/dovecot/login/login 10023403              * 10022270
u_str  ESTAB      0      0      /var/run/dovecot/anvil 10023321              * 10023312
u_str  ESTAB      0      0      /run/systemd/journal/stdout 14885                 * 14884
u_str  ESTAB      0      0         * 25709209              * 25709733
u_str  ESTAB      0      0         * 25709013              * 25708502
u_str  ESTAB      0      0      /var/run/dovecot/config 17026728              * 17026726
u_str  ESTAB      0      0      /var/run/dovecot/config 25708474              * 25708989
u_str  ESTAB      0      0      /var/run/dovecot/config 24763774              * 24763089
u_str  ESTAB      0      0      /var/run/dovecot/config 10022223              * 10022172
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 25709148              * 25709147
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 23432079              * 23432078
u_str  ESTAB      0      0         * 12939922              * 12939921
u_str  ESTAB      0      0      /var/run/dovecot/config 10022216              * 10022166
u_str  ESTAB      0      0         * 25709708              * 25709710
u_str  ESTAB      0      0      /var/run/dovecot/anvil 23317468              * 23317861
u_str  ESTAB      0      0         * 10023312              * 10023321
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 26362033              * 26362031
u_str  ESTAB      0      0         * 26240065              * 26239774
u_str  ESTAB      0      0      /var/run/dovecot/login/login 25642167              * 25642165
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 25293833              * 25293831
u_str  ESTAB      0      0      /var/run/dovecot/anvil 24816047              * 24815107
u_str  ESTAB      0      0         * 24597205              * 24597225
u_str  ESTAB      0      0         * 10022170              * 10022221
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 10023252              * 10022165
u_str  ESTAB      0      0      /var/run/dovecot/config 25703249              * 25703894
u_str  ESTAB      0      0         * 25643266              * 25643269
u_str  ESTAB      0      0      /var/run/dovecot/config 25640516              * 25640513
u_str  ESTAB      0      0         * 25630130              * 25630131
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 23317467              * 23317860
u_str  ESTAB      0      0         * 10023219              * 10023282
u_str  ESTAB      0      0         * 25709203              * 25709725
u_str  ESTAB      0      0      /var/run/dovecot/config 10022221              * 10022170
u_str  ESTAB      0      0         * 26361288              * 26361289
u_str  ESTAB      0      0         * 26329144              * 26329147
u_str  ESTAB      0      0         * 25709114              * 25709113
u_str  ESTAB      0      0         * 25703894              * 25703249
u_str  ESTAB      0      0      /var/run/dovecot/config 25228580              * 25228577
u_str  ESTAB      0      0      /var/run/dovecot/config 24742472              * 24742469
u_str  ESTAB      0      0      /var/run/dovecot/login/login 10023398              * 10023308
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 25569525              * 25569523
u_str  ESTAB      0      0         * 25228594              * 25228595
u_str  ESTAB      0      0         * 14657280              * 14657282
u_str  ESTAB      0      0         * 23247455              * 23247457
u_str  ESTAB      0      0      /var/run/dovecot/config 21081353              * 21081351
u_str  ESTAB      0      0         * 10022165              * 10023252
u_str  ESTAB      0      0      /var/run/dovecot/anvil 26329147              * 26329144
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 25228579              * 25228578
u_str  ESTAB      0      0         * 24742469              * 24742472
u_str  ESTAB      0      0         * 23329342              * 23328711
u_str  ESTAB      0      0         * 12939927              * 12939928
u_str  ESTAB      0      0         * 10023199              * 10022232
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 26361243              * 26361973
u_str  ESTAB      0      0      /var/run/dovecot/login/login 25709005              * 25708488
u_str  ESTAB      0      0         * 25708990              * 25708473
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 25640712              * 25640709
u_str  ESTAB      0      0      /var/run/dovecot/config 23329340              * 23329338
u_str  ESTAB      0      0         * 10022171              * 10023258
u_str  ESTAB      0      0      /run/dbus/system_bus_socket 13949                 * 13948
u_str  ESTAB      0      0         * 23432036              * 23432037
u_str  ESTAB      0      0      /var/run/dovecot/config 10022215              * 10022164
u_str  ESTAB      0      0         * 25708894              * 25708895
u_str  ESTAB      0      0      /var/run/dovecot/anvil 25228584              * 25228581
u_str  ESTAB      0      0         * 23329339              * 23329341
u_str  ESTAB      0      0      /var/run/dovecot/config 14530558              * 14530555
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 26240064              * 26239772
u_str  ESTAB      0      0         * 25708997              * 25708477
u_str  ESTAB      0      0         * 25569523              * 25569525
u_str  ESTAB      0      0         * 25293831              * 25293833
u_str  ESTAB      0      0         * 26034451              * 26035666
u_str  ESTAB      0      0      /var/run/dovecot/login/login 25708537              * 25708525
u_str  ESTAB      0      0         * 24763089              * 24763774
u_str  ESTAB      0      0         * 24257145              * 24257144
u_str  ESTAB      0      0         * 25251863              * 25251864
u_str  ESTAB      0      0         * 25709113              * 25709114
u_str  ESTAB      0      0      /var/run/dovecot/config 25643227              * 25642160
u_str  ESTAB      0      0         * 25228577              * 25228580
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 23329341              * 23329339
u_str  ESTAB      0      0         * 21231429              * 21231430
u_str  ESTAB      0      0         * 14884                 * 14885
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 25709205              * 25709204
u_str  ESTAB      0      0         * 25708996              * 25708476
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 25293843              * 25293841
u_str  ESTAB      0      0         * 25708525              * 25708537
u_str  ESTAB      0      0         * 25708989              * 25708474
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 25048286              * 25047403
u_str  ESTAB      0      0         * 25047402              * 25047404
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 24763771              * 24763090
u_str  ESTAB      0      0         * 24257144              * 24257145
u_str  ESTAB      0      0         * 10022172              * 10022223
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 21081354              * 21081352
u_str  ESTAB      0      0         * 16382787              * 16382789
u_str  ESTAB      0      0         * 23317859              * 23317466
u_str  ESTAB      0      0      /var/run/dovecot/anvil 25709731              * 25709207
u_str  ESTAB      0      0      /var/run/dovecot/anvil 25708543              * 25708523
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 10023258              * 10022171
u_str  ESTAB      0      0         * 26361237              * 26361238
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 25703250              * 25703895
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 25630822              * 25630132
u_str  ESTAB      0      0         * 25291731              * 25291733
u_str  ESTAB      0      0      /var/run/dovecot/anvil 25286365              * 25286362
u_str  ESTAB      0      0      /var/run/dovecot/config 23317466              * 23317859
u_str  ESTAB      0      0      /var/run/dovecot/config 10022232              * 10023199
u_str  ESTAB      0      0         * 25293825              * 25293826
u_str  ESTAB      0      0      /var/run/dovecot/anvil 25640720              * 25640715
u_str  ESTAB      0      0         * 24763090              * 24763771
u_str  ESTAB      0      0      /var/run/dovecot/config 23247457              * 23247455
u_str  ESTAB      0      0         * 25251862              * 25251865
u_str  ESTAB      0      0         * 25228634              * 25229592
u_str  ESTAB      0      0         * 26329140              * 26329142
u_str  ESTAB      0      0         * 25708895              * 25708894
u_str  ESTAB      0      0         * 25643262              * 25643265
u_str  ESTAB      0      0         * 23247485              * 23247488
u_str  ESTAB      0      0      /run/systemd/journal/stdout 14680                 * 13577
u_str  ESTAB      0      0      /var/run/dovecot/login/login 25709733              * 25709209
u_str  ESTAB      0      0         * 25293826              * 25293825
u_str  ESTAB      0      0         * 25708486              * 25709004
u_str  ESTAB      0      0      /run/systemd/journal/stdout 24006504              * 24006795
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 10023259              * 10022173
u_str  ESTAB      0      0      /var/run/dovecot/config 26034450              * 26034448
u_str  ESTAB      0      0      /var/run/dovecot/config 25229592              * 25228634
u_str  ESTAB      0      0         * 25703895              * 25703250
u_str  ESTAB      0      0         * 25286362              * 25286365
u_str  ESTAB      0      0         * 26361973              * 26361243
u_str  ESTAB      0      0      /var/run/dovecot/anvil 26239774              * 26240065
u_str  ESTAB      0      0      /var/run/dovecot/config 24816045              * 24815105
u_str  ESTAB      0      0         * 16382788              * 16383292
u_str  ESTAB      0      0         * 10022175              * 10023261
u_str  ESTAB      0      0         * 26361289              * 26361288
u_str  ESTAB      0      0         * 26034448              * 26034450
u_str  ESTAB      0      0      /var/run/dovecot/config 25251865              * 25251862
u_str  ESTAB      0      0         * 25286358              * 25286361
u_str  ESTAB      0      0         * 25228581              * 25228584
u_str  ESTAB      0      0         * 24742470              * 24742471
u_str  ESTAB      0      0         * 23317860              * 23317467
u_str  ESTAB      0      0         * 12939928              * 12939927
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 10023282              * 10023219
u_str  ESTAB      0      0         * 25709207              * 25709731
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 25708502              * 25709013
u_str  ESTAB      0      0         * 25228595              * 25228594
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 10023254              * 10023185
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 25708473              * 25708990
u_str  ESTAB      0      0      /var/run/dovecot/config 25047404              * 25047402
u_str  ESTAB      0      0      /var/run/dovecot/config 10022225              * 10022174
u_str  ESTAB      0      0         * 26034449              * 26035664
u_str  ESTAB      0      0         * 23432037              * 23432036
u_str  ESTAB      0      0      /var/run/dovecot/config 16382789              * 16382787
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 26329143              * 26329141
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 25291733              * 25291731
u_str  ESTAB      0      0         * 25286359              * 25286360
u_str  ESTAB      0      0      /var/run/dovecot/config 25709725              * 25709203
u_str  ESTAB      0      0         * 24815107              * 24816047
u_str  ESTAB      0      0      /var/run/dovecot/anvil 25709004              * 25708486
u_str  ESTAB      0      0         * 25640715              * 25640720
u_str  ESTAB      0      0         * 24815105              * 24816045
u_str  ESTAB      0      0      /run/systemd/journal/stdout 24597225              * 24597205
u_str  ESTAB      0      0         * 10022174              * 10022225
u_str  ESTAB      0      0         * 13948                 * 13949
u_str  ESTAB      0      0         * 25709147              * 25709148
u_str  ESTAB      0      0         * 10022166              * 10022216
u_str  ESTAB      0      0         * 25293054              * 25293053
u_str  ESTAB      0      0         * 14530555              * 14530558
u_str  ESTAB      0      0         * 12939921              * 12939922
u_str  ESTAB      0      0         * 15320                 * 14043
u_str  ESTAB      0      0      /var/run/dovecot/config 26220463              * 26219479
u_str  ESTAB      0      0         * 25643291              * 25643294
u_str  ESTAB      0      0         * 25641995              * 25641998
u_str  ESTAB      0      0         * 24763743              * 24763755
u_str  ESTAB      0      0      /var/run/dovecot/anvil 14531587              * 14530559
u_str  ESTAB      0      0         * 25293026              * 25293027
u_str  ESTAB      0      0      /var/run/dovecot/login/login 10023405              * 10022276
u_str  ESTAB      0      0         * 23431146              * 23431147
u_str  ESTAB      0      0         * 23183590              * 23183589
u_str  ESTAB      0      0      /var/run/dovecot/config 21908831              * 21908829
u_str  ESTAB      0      0         * 10023185              * 10023254
u_str  ESTAB      0      0         * 24009829              * 24009828
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 10023253              * 10022167
u_str  ESTAB      0      0         * 25709593              * 25709592
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 14530557              * 14530556
u_str  ESTAB      0      0         * 25293023              * 25293024
u_str  ESTAB      0      0         * 25709647              * 25709646
u_str  ESTAB      0      0         * 25672278              * 25672714
u_str  ESTAB      0      0         * 25535508              * 25534749
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 25293034              * 25293033
u_str  ESTAB      0      0         * 25046897              * 25046898
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 14657262              * 14657260
u_str  ESTAB      0      0         * 25742692              * 25742694
u_str  ESTAB      0      0         * 25708523              * 25708543
u_str  ESTAB      0      0      /var/run/dovecot/login/login 25709039              * 25709036
u_str  ESTAB      0      0      /var/run/dovecot/login/login 25641999              * 25641997
u_str  ESTAB      0      0         * 20848129              * 20848131
u_str  ESTAB      0      0      /var/run/dovecot/anvil 24640659              * 24640655
u_str  ESTAB      0      0      /run/dbus/system_bus_socket 14708                 * 14589
u_str  ESTAB      0      0      /var/run/dovecot/anvil 25292851              * 25291652
u_str  ESTAB      0      0         * 25228635              * 25229593
u_str  ESTAB      0      0      /var/run/dovecot/config 23739853              * 23739851
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 23431107              * 23431105
u_str  ESTAB      0      0         * 25708838              * 25708295
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 25709679              * 25709184
u_str  ESTAB      0      0         * 25709036              * 25709039
u_str  ESTAB      0      0         * 25643287              * 25643289
u_str  ESTAB      0      0         * 25641992              * 25641994
u_str  ESTAB      0      0         * 25292883              * 25292882
u_str  ESTAB      0      0         * 10023218              * 10022246
u_str  ESTAB      0      0         * 23431105              * 23431107
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 23432052              * 23432050
u_str  ESTAB      0      0         * 20495                 * 19700
u_str  ESTAB      0      0      /var/run/dovecot/config 10022246              * 10023218
u_str  ESTAB      0      0         * 25709706              * 25709709
u_str  ESTAB      0      0         * 25709637              * 25709636
u_str  ESTAB      0      0      /var/run/dovecot/config 25643289              * 25643287
u_str  ESTAB      0      0         * 14530556              * 14530557
u_str  ESTAB      0      0         * 25643232              * 25643235
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 24640653              * 24640652
u_str  ESTAB      0      0         * 25709642              * 25709641
u_str  ESTAB      0      0      /var/run/dovecot/config 25672714              * 25672278
u_str  ESTAB      0      0         * 25228617              * 25228619
u_str  ESTAB      0      0      /var/run/dovecot/config 25046899              * 25046896
u_str  ESTAB      0      0         * 23432047              * 23432046
u_str  ESTAB      0      0      /var/run/dovecot/config 10022217              * 10023184
u_str  ESTAB      0      0         * 10022949              * 10022948
u_str  ESTAB      0      0         * 26219479              * 26220463
u_str  ESTAB      0      0      /var/run/dovecot/config 25742694              * 25742692
u_str  ESTAB      0      0         * 23432040              * 23432042
u_str  ESTAB      0      0         * 14530559              * 14531587
u_str  ESTAB      0      0         * 25293024              * 25293023
u_str  ESTAB      0      0      /var/run/dovecot/config 24640654              * 24640651
u_str  ESTAB      0      0         * 10022276              * 10023405
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 25709667              * 25709666
u_str  ESTAB      0      0         * 25291759              * 25291761
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 25228619              * 25228617
u_str  ESTAB      0      0         * 12939925              * 12939924
u_str  ESTAB      0      0         * 14657257              * 14657256
u_str  ESTAB      0      0      /var/run/dovecot/anvil 26361943              * 26361940
u_str  ESTAB      0      0      /var/run/dovecot/anvil 10023334              * 10022277
u_str  ESTAB      0      0      /var/run/dovecot/anvil 25672283              * 25672280
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 25229593              * 25228635
u_str  ESTAB      0      0         * 25046896              * 25046899
u_str  ESTAB      0      0         * 12939924              * 12939925
u_str  ESTAB      0      0      /var/run/dovecot/login/login 26220465              * 26219483
u_str  ESTAB      0      0         * 25709686              * 25709687
u_str  ESTAB      0      0         * 25709592              * 25709593
u_str  ESTAB      0      0         * 25643288              * 25643290
u_str  ESTAB      0      0         * 14657256              * 14657257
u_str  ESTAB      0      0         * 10023211              * 10022243
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 25293044              * 25293042
u_str  ESTAB      0      0         * 24640651              * 24640654
u_str  ESTAB      0      0         * 10022277              * 10023334
u_str  ESTAB      0      0         * 10023308              * 10023398
u_str  ESTAB      0      0         * 12357                 * 11599
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 25672715              * 25672279
u_str  ESTAB      0      0         * 10023184              * 10022217
u_str  ESTAB      0      0         * 10022948              * 10022949
u_str  ESTAB      0      0      /run/systemd/journal/stdout 15292                 * 15291
u_str  ESTAB      0      0      /var/run/dovecot/anvil 25709709              * 25709706
u_str  ESTAB      0      0      /var/run/dovecot/anvil 25641998              * 25641995
u_str  ESTAB      0      0      /var/run/dovecot/config 25474890              * 25474888
u_str  ESTAB      0      0         * 24763744              * 24763745
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 19730383              * 19731117
u_str  ESTAB      0      0      /run/systemd/journal/stdout 3820054               * 3819300
u_str  ESTAB      0      0         * 25293027              * 25293026
u_str  ESTAB      0      0      /var/run/dovecot/login/login 10023404              * 10022273
u_str  ESTAB      0      0         * 25672280              * 25672283
u_str  ESTAB      0      0         * 25292908              * 25292907
u_str  ESTAB      0      0      /var/run/dovecot/anvil 25046903              * 25046900
u_str  ESTAB      0      0         * 23432046              * 23432047
u_str  ESTAB      0      0         * 21908829              * 21908831
u_str  ESTAB      0      0         * 25708849              * 25708848
u_str  ESTAB      0      0         * 24009828              * 24009829
u_str  ESTAB      0      0         * 26219480              * 26220462
u_str  ESTAB      0      0         * 25742693              * 25742695
u_str  ESTAB      0      0         * 25474888              * 25474890
u_str  ESTAB      0      0      /var/run/dovecot/config 20848131              * 20848129
u_str  ESTAB      0      0         * 12940608              * 12940609
u_str  ESTAB      0      0         * 21908830              * 21908832
u_str  ESTAB      0      0      /var/run/dovecot/config 25708296              * 25708837
u_str  ESTAB      0      0      /run/dbus/system_bus_socket 14043                 * 15320
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 25742695              * 25742693
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 25709687              * 25709686
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 25709136              * 25709133
u_str  ESTAB      0      0         * 25709034              * 25709038
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 25641994              * 25641992
u_str  ESTAB      0      0         * 3819300               * 3820054
u_str  ESTAB      0      0      /var/run/dovecot/anvil 25643235              * 25643232
u_str  ESTAB      0      0         * 25229570              * 25228598
u_str  ESTAB      0      0         * 23739852              * 23739854
u_str  ESTAB      0      0         * 14657260              * 14657262
u_str  ESTAB      0      0         * 15291                 * 15292
u_str  ESTAB      0      0         * 25474889              * 25474891
u_str  ESTAB      0      0         * 25292882              * 25292883
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 24763745              * 24763744
u_str  ESTAB      0      0         * 24243352              * 24242547
u_str  ESTAB      0      0         * 20848130              * 20848132
u_str  ESTAB      0      0         * 10023212              * 10023279
u_str  ESTAB      0      0      /var/run/dovecot/anvil 10023332              * 10022274
u_str  ESTAB      0      0         * 14589                 * 14708
u_str  ESTAB      0      0         * 25535507              * 25534750
u_str  ESTAB      0      0         * 25293033              * 25293034
u_str  ESTAB      0      0         * 23739851              * 23739853
u_str  ESTAB      0      0         * 23183589              * 23183590
u_str  ESTAB      0      0         * 25709641              * 25709642
u_str  ESTAB      0      0         * 25641991              * 25641993
u_str  ESTAB      0      0      /run/systemd/journal/stdout 12940609              * 12940608
u_str  ESTAB      0      0      /var/run/dovecot/config 10022243              * 10023211
u_str  ESTAB      0      0         * 21870135              * 21870136
u_str  ESTAB      0      0      /run/systemd/journal/stdout 11599                 * 12357
u_str  ESTAB      0      0         * 25709646              * 25709647
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 25534749              * 25535508
u_str  ESTAB      0      0         * 25046900              * 25046903
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 21908832              * 21908830
u_str  ESTAB      0      0         * 26219483              * 26220465
u_str  ESTAB      0      0         * 25708848              * 25708849
u_str  ESTAB      0      0         * 25709133              * 25709136
u_str  ESTAB      0      0      /var/run/dovecot/login/login 25708535              * 25708519
u_str  ESTAB      0      0         * 25708887              * 25708890
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 25643290              * 25643288
u_str  ESTAB      0      0         * 24640655              * 24640659
u_str  ESTAB      0      0         * 10022273              * 10023404
u_str  ESTAB      0      0         * 25672279              * 25672715
u_str  ESTAB      0      0         * 25291652              * 25292851
u_str  ESTAB      0      0      /var/run/dovecot/anvil 23247488              * 23247485
u_str  ESTAB      0      0         * 25708837              * 25708296
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 26220462              * 26219480
u_str  ESTAB      0      0         * 25709120              * 25709122
u_str  ESTAB      0      0      /var/run/dovecot/anvil 25709038              * 25709034
u_str  ESTAB      0      0      /var/run/dovecot/anvil 25643294              * 25643291
u_str  ESTAB      0      0      /var/run/dovecot/config 25641993              * 25641991
u_str  ESTAB      0      0      /var/run/dovecot/anvil 24242547              * 24243352
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 25228598              * 25229570
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 25708295              * 25708838
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 25709122              * 25709120
u_str  ESTAB      0      0      /var/run/dovecot/config 24763755              * 24763743
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 20848132              * 20848130
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 10023279              * 10023212
u_str  ESTAB      0      0         * 24640652              * 24640653
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 21870136              * 21870135
u_str  ESTAB      0      0         * 10022274              * 10023332
u_str  ESTAB      0      0      /var/run/dovecot/config 25534750              * 25535507
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 25291761              * 25291759
u_str  ESTAB      0      0         * 25292907              * 25292908
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 25046898              * 25046897
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 23739854              * 23739852
u_str  ESTAB      0      0         * 23432050              * 23432052
u_str  ESTAB      0      0      /run/dbus/system_bus_socket 19700                 * 20495
u_str  ESTAB      0      0      /var/run/dovecot/config 25708511              * 25709012
u_str  ESTAB      0      0      /var/run/dovecot/login/login 25708999              * 25708480
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 25708900              * 25708898
u_str  ESTAB      0      0         * 23981671              * 23981674
u_str  ESTAB      0      0         * 10023188              * 10022220
u_str  ESTAB      0      0         * 22725369              * 22725370
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 25228602              * 25229578
u_str  ESTAB      0      0         * 23311773              * 23312624
u_str  ESTAB      0      0         * 17026726              * 17026728
u_str  ESTAB      0      0      /var/run/dovecot/anvil-auth-penalty 10022319              * 10023392
u_str  ESTAB      0      0         * 25709616              * 25709617
u_str  ESTAB      0      0      /var/run/dovecot/config 24763776              * 24763091
u_str  ESTAB      0      0      /var/run/dovecot/anvil 22698191              * 22698187
u_str  ESTAB      0      0         * 21231877              * 21231876
u_str  ESTAB      0      0         * 12939933              * 12939934
u_str  ESTAB      0      0      /var/run/dovecot/login/login 25642205              * 25643268
u_str  ESTAB      0      0         * 26362031              * 26362033
u_str  ESTAB      0      0         * 10022303              * 10023378
u_str  ESTAB      0      0         * 26239771              * 26239773
u_str  ESTAB      0      0         * 25229578              * 25228602
u_str  ESTAB      0      0         * 26361235              * 26361234
u_str  ESTAB      0      0         * 10023370              * 10023424
u_str  ESTAB      0      0      /var/run/dovecot/anvil 25708998              * 25708478
u_str  ESTAB      0      0      /var/run/dovecot/config 23981674              * 23981671
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 23432042              * 23432040
u_str  ESTAB      0      0         * 25643229              * 25642170
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 22725422              * 22726171
u_str  ESTAB      0      0         * 22725387              * 22725388
u_str  ESTAB      0      0         * 22725373              * 22725374
u_str  ESTAB      0      0         * 22726114              * 22726118
u_str  ESTAB      0      0      /var/run/dovecot/anvil 22723226              * 22724533
u_str  ESTAB      0      0         * 23311772              * 23311774
u_str  ESTAB      0      0         * 10023389              * 10022318
u_str  ESTAB      0      0         * 25292879              * 25292880
u_str  ESTAB      0      0      /var/run/dovecot/anvil 24763104              * 24763101
u_str  ESTAB      0      0      /var/run/dovecot/login/login 10023424              * 10023370
u_str  ESTAB      0      0         * 10023206              * 10023274
u_str  ESTAB      0      0         * 21870134              * 21870137
u_str  ESTAB      0      0         * 25699272              * 25699878
u_str  ESTAB      0      0         * 10023338              * 10023409
u_str  ESTAB      0      0         * 26361238              * 26361237
u_str  ESTAB      0      0      /var/run/dovecot/login/login 10023397              * 10023305
u_str  ESTAB      0      0      /var/run/dovecot/anvil 10023382              * 10023365
u_str  ESTAB      0      0      /var/run/dovecot/config 25699273              * 25699271
u_str  ESTAB      0      0         * 25292914              * 25292915
u_str  ESTAB      0      0      /var/run/dovecot/config 24242541              * 24243334
u_str  ESTAB      0      0         * 22726108              * 22726110
u_str  ESTAB      0      0         * 22724530              * 22723225
u_str  ESTAB      0      0         * 26361980              * 26361982
u_str  ESTAB      0      0      /var/run/dovecot/config 26361938              * 26361936
u_str  ESTAB      0      0         * 25640514              * 25641494
u_str  ESTAB      0      0         * 24763092              * 24763773
u_str  ESTAB      0      0         * 19731117              * 19730383
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 25641494              * 25640514
u_str  ESTAB      0      0      /var/run/dovecot/anvil 25699879              * 25699274
u_str  ESTAB      0      0         * 25642165              * 25642167
u_str  ESTAB      0      0         * 25291746              * 25291745
u_str  ESTAB      0      0         * 22726107              * 22726112
u_str  ESTAB      0      0      /var/run/dovecot/anvil 26035666              * 26034451
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 26035664              * 26034449
u_str  ESTAB      0      0      /var/run/dovecot/anvil 25229597              * 25229594
u_str  ESTAB      0      0         * 23432075              * 23432074
u_str  ESTAB      0      0      /var/run/dovecot/anvil 26362020              * 26362017
u_str  ESTAB      0      0      /var/run/dovecot/anvil 26361215              * 26361212
u_str  ESTAB      0      0         * 25709649              * 25709650
u_str  ESTAB      0      0      /var/run/dovecot/config 22699231              * 22698184
u_str  ESTAB      0      0         * 25708478              * 25708998
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 25708477              * 25708997
u_str  ESTAB      0      0      /var/run/dovecot/config 25708510              * 25709010
u_str  ESTAB      0      0         * 25291745              * 25291746
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 24243341              * 24243335
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 22724532              * 22724531
u_str  ESTAB      0      0         * 10023350              * 10023374
u_str  ESTAB      0      0      /var/run/dovecot/config 26239773              * 26239771
u_str  ESTAB      0      0         * 25709617              * 25709616
u_str  ESTAB      0      0         * 10023368              * 10023384
u_str  ESTAB      0      0         * 10023303              * 10023318
u_str  ESTAB      0      0      /var/run/dovecot/config 25709003              * 25709000
u_str  ESTAB      0      0         * 25708898              * 25708900
u_str  ESTAB      0      0         * 23981672              * 23981673
u_str  ESTAB      0      0      /var/run/dovecot/config 21870137              * 21870134
u_str  ESTAB      0      0      /var/run/dovecot/config 25642170              * 25643229
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 23402232              * 23402866
u_str  ESTAB      0      0         * 22726171              * 22725422
u_str  ESTAB      0      0      /var/run/dovecot/login/login 26034454              * 26034453
u_str  ESTAB      0      0         * 25228599              * 25228600
u_str  ESTAB      0      0         * 23432074              * 23432075
u_str  ESTAB      0      0         * 16991                 * 16992
u_str  ESTAB      0      0         * 26361234              * 26361235
u_str  ESTAB      0      0      /var/run/dovecot/login/login 26361945              * 26361214
u_str  ESTAB      0      0         * 23431151              * 23432108
u_str  ESTAB      0      0         * 22698187              * 22698191
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 25708485              * 25709001
u_str  ESTAB      0      0         * 25643268              * 25642205
u_str  ESTAB      0      0         * 23431994              * 23431998
u_str  ESTAB      0      0         * 14657277              * 14657276
u_str  ESTAB      0      0         * 12939931              * 12939930
u_str  ESTAB      0      0         * 25709011              * 25708501
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 25642171              * 25643230
u_str  ESTAB      0      0         * 23402866              * 23402232
u_str  ESTAB      0      0         * 10022268              * 10023329
u_str  ESTAB      0      0         * 26361936              * 26361938
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 24816046              * 24815106
u_str  ESTAB      0      0      /var/run/dovecot/login/login 10023422              * 10023367
u_str  ESTAB      0      0      /var/run/dovecot/anvil 10023319              * 10023306
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 10023274              * 10023206
u_str  ESTAB      0      0      /var/run/dovecot/config 19731118              * 19731116
u_str  ESTAB      0      0         * 25709010              * 25708510
u_str  ESTAB      0      0         * 25699274              * 25699879
u_str  ESTAB      0      0         * 25291749              * 25291750
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 25291729              * 25292886
u_str  ESTAB      0      0      /var/run/dovecot/config 23402231              * 23402865
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 22725374              * 22725373
u_str  ESTAB      0      0         * 25640513              * 25640516
u_str  ESTAB      0      0         * 26361214              * 26361945
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 22698186              * 22698185
u_str  ESTAB      0      0         * 25708480              * 25708999
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 23981673              * 23981672
u_str  ESTAB      0      0         * 23432072              * 23432071
u_str  ESTAB      0      0         * 10023365              * 10023382
u_str  ESTAB      0      0      /var/run/dovecot/config 10022220              * 10023188
u_str  ESTAB      0      0         * 25535509              * 25535513
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 22725388              * 22725387
u_str  ESTAB      0      0      /var/run/dovecot/anvil 22726118              * 22726114
u_str  ESTAB      0      0         * 26034453              * 26034454
u_str  ESTAB      0      0         * 25229594              * 25229597
u_str  ESTAB      0      0         * 25228600              * 25228599
u_str  ESTAB      0      0         * 10023392              * 10022319
u_str  ESTAB      0      0      /var/run/dovecot/config 26361210              * 26361208
u_str  ESTAB      0      0         * 24763101              * 24763104
u_str  ESTAB      0      0         * 22698185              * 22698186
u_str  ESTAB      0      0         * 25709636              * 25709637
u_str  ESTAB      0      0         * 23432078              * 23432079
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 25709096              * 25709094
u_str  ESTAB      0      0         * 25699271              * 25699273
u_str  ESTAB      0      0         * 25643230              * 25642171
u_str  ESTAB      0      0         * 25292915              * 25292914
u_str  ESTAB      0      0         * 22725370              * 22725369
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 22726110              * 22726108
u_str  ESTAB      0      0         * 22724533              * 22723226
u_str  ESTAB      0      0      /var/run/dovecot/anvil 10023341              * 10023336
u_str  ESTAB      0      0         * 24243334              * 24242541
u_str  ESTAB      0      0         * 23432071              * 23432072
u_str  ESTAB      0      0      /var/run/dovecot/config 23311774              * 23311772
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 26361211              * 26361209
u_str  ESTAB      0      0         * 25709650              * 25709649
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 24763773              * 24763092
u_str  ESTAB      0      0         * 22698184              * 22699231
u_str  ESTAB      0      0         * 12939934              * 12939933
u_str  ESTAB      0      0      /var/run/dovecot/anvil 10023384              * 10023368
u_str  ESTAB      0      0         * 25709001              * 25708485
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 10023257              * 10023189
u_str  ESTAB      0      0      /var/run/dovecot/anvil 25535513              * 25535509
u_str  ESTAB      0      0         * 24243335              * 24243341
u_str  ESTAB      0      0         * 22724531              * 22724532
u_str  ESTAB      0      0         * 26239772              * 26240064
u_str  ESTAB      0      0         * 26361209              * 26361211
u_str  ESTAB      0      0         * 26361937              * 26361939
u_str  ESTAB      0      0         * 25709619              * 25709620
u_str  ESTAB      0      0      /var/run/dovecot/anvil 10023318              * 10023303
u_str  ESTAB      0      0         * 10023189              * 10023257
u_str  ESTAB      0      0         * 25642160              * 25643227
u_str  ESTAB      0      0         * 23402865              * 23402231
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 26361939              * 26361937
u_str  ESTAB      0      0         * 10023305              * 10023397
u_str  ESTAB      0      0         * 25709000              * 25709003
u_str  ESTAB      0      0         * 19731116              * 19731118
u_str  ESTAB      0      0         * 14657276              * 14657277
u_str  ESTAB      0      0         * 12939930              * 12939931
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 25708501              * 25709011
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 25699878              * 25699272
u_str  ESTAB      0      0         * 23402867              * 23402870
u_str  ESTAB      0      0      /var/run/dovecot/config 22723225              * 22724530
u_str  ESTAB      0      0         * 10023336              * 10023341
u_str  ESTAB      0      0      /var/run/dovecot/anvil 10023329              * 10022268
u_str  ESTAB      0      0      /run/systemd/journal/stdout 16992                 * 16991
u_str  ESTAB      0      0         * 26361208              * 26361210
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 25709671              * 25709670
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 25474891              * 25474889
u_str  ESTAB      0      0         * 25292880              * 25292879
u_str  ESTAB      0      0      /var/run/dovecot/anvil 23431998              * 23431994
u_str  ESTAB      0      0         * 25292886              * 25291729
u_str  ESTAB      0      0         * 22725379              * 22725380
u_str  ESTAB      0      0      /var/run/dovecot/config 22726112              * 22726107
u_str  ESTAB      0      0      /var/run/dovecot/login/login 10023409              * 10023338
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 10022318              * 10023389
u_str  ESTAB      0      0         * 26361212              * 26361215
u_str  ESTAB      0      0         * 10023367              * 10023422
u_str  ESTAB      0      0         * 10023306              * 10023319
u_str  ESTAB      0      0         * 26034436              * 26035583
u_str  ESTAB      0      0      /var/run/dovecot/anvil 25723544              * 25723541
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 25291750              * 25291749
u_str  ESTAB      0      0         * 13577                 * 14680
u_str  ESTAB      0      0         * 25708884              * 25708885
u_str  ESTAB      0      0         * 25708357              * 25708360
u_str  ESTAB      0      0         * 10022179              * 10023264
u_str  ESTAB      0      0         * 14675                 * 14677
u_str  ESTAB      0      0         * 25569072              * 25569073
u_str  ESTAB      0      0      /var/run/dovecot/login/login 10023406              * 10022279
u_str  ESTAB      0      0      /var/run/dovecot/config 25640527              * 25641499
u_str  ESTAB      0      0         * 24763760              * 24763083
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 14607923              * 14607921
u_str  ESTAB      0      0         * 10023205              * 10022238
u_str  ESTAB      0      0      /var/run/dovecot/anvil 25641514              * 25641511
u_str  ESTAB      0      0      /var/run/dovecot/auth-userdb 22843159              * 22843158
u_str  ESTAB      0      0         * 22710206              * 22710207
u_str  ESTAB      0      0      /var/run/dovecot/login/login 10023400              * 10023314
u_str  ESTAB      0      0      /var/run/dovecot/config 25643264              * 25643261
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 25251864              * 25251863
u_str  ESTAB      0      0         * 25228614              * 25228613
u_str  ESTAB      0      0         * 23431095              * 23431096
u_str  ESTAB      0      0         * 22725380              * 22725379
u_str  ESTAB      0      0         * 10022279              * 10023406
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 25709705              * 25709703
u_str  ESTAB      0      0      /var/run/dovecot/anvil 24763099              * 24763777
u_str  ESTAB      0      0      /var/run/dovecot/anvil 23328711              * 23329342
u_str  ESTAB      0      0         * 10022271              * 10023331
u_str  ESTAB      0      0         * 25641511              * 25641514
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 25293058              * 25293057
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 25229525              * 25229524
u_str  ESTAB      0      0         * 22843158              * 22843159
u_str  ESTAB      0      0      /var/run/dovecot/login/login 10023401              * 10023317
u_str  ESTAB      0      0         * 25708353              * 25708356
u_str  ESTAB      0      0         * 24009006              * 24009005
u_str  ESTAB      0      0         * 19731461              * 19731464
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 10023266              * 10022181
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 14531125              * 14531121
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 25708885              * 25708884
u_str  ESTAB      0      0         * 25641500              * 25641502
u_str  ESTAB      0      0         * 23432085              * 23432086
u_str  ESTAB      0      0      /var/run/dovecot/config 14607922              * 14607920
u_str  ESTAB      0      0      /var/run/dovecot/config 26362016              * 26362013
u_str  ESTAB      0      0         * 26219481              * 26220464
u_str  ESTAB      0      0         * 26034447              * 26035663
u_str  ESTAB      0      0         * 25709094              * 25709096
u_str  ESTAB      0      0         * 10022270              * 10023403
u_str  ESTAB      0      0      /var/run/dovecot/anvil 10023322              * 10023315
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 26361982              * 26361980
u_str  ESTAB      0      0      /var/run/dovecot/config 25708356              * 25708353
u_str  ESTAB      0      0         * 25643261              * 25643264
u_str  ESTAB      0      0         * 10022181              * 10023266
u_str  ESTAB      0      0      /run/systemd/journal/stdout 14677                 * 14675
u_str  ESTAB      0      0      /var/run/dovecot/anvil 25708301              * 25708297
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 26362015              * 26362014
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 26035583              * 26034436
u_str  ESTAB      0      0         * 25723540              * 25724507
u_str  ESTAB      0      0         * 13345                 * 13344
u_str  ESTAB      0      0         * 25708519              * 25708535
u_str  ESTAB      0      0         * 10022305              * 10023418
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 25293888              * 25293066
u_str  ESTAB      0      0         * 25251866              * 25251870
u_str  ESTAB      0      0      /run/dbus/system_bus_socket 14709                 * 13586
u_str  ESTAB      0      0         * 25293057              * 25293058
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 23432086              * 23432085
u_str  ESTAB      0      0         * 14607921              * 14607923
u_str  ESTAB      0      0         * 10023203              * 10022236
u_str  ESTAB      0      0      /var/run/dovecot/anvil 26035662              * 26034445
u_str  ESTAB      0      0         * 25709012              * 25708511
u_str  ESTAB      0      0         * 25229523              * 25229526
u_str  ESTAB      0      0         * 24009836              * 24009835
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 10023269              * 10022183
u_str  ESTAB      0      0         * 25569073              * 25569072
u_str  ESTAB      0      0         * 25293066              * 25293888
u_str  ESTAB      0      0      /var/run/dovecot/anvil 25251870              * 25251866
u_str  ESTAB      0      0      /run/systemd/journal/stdout 22042                 * 22041
u_str  ESTAB      0      0         * 13586                 * 14709
u_str  ESTAB      0      0         * 25709702              * 25709704
u_str  ESTAB      0      0         * 21231876              * 21231877
u_str  ESTAB      0      0         * 14607920              * 14607922
u_str  ESTAB      0      0         * 14162                 * 14163
u_str  ESTAB      0      0      /var/run/dovecot/config 25724506              * 25723539
u_str  ESTAB      0      0         * 25229527              * 25229531
u_str  ESTAB      0      0         * 10023315              * 10023322
u_str  ESTAB      0      0      /var/run/dovecot/anvil 25708541              * 25708517
u_str  ESTAB      0      0      /var/run/dovecot/config 25708886              * 25708883
u_str  ESTAB      0      0         * 25708354              * 25708355
u_str  ESTAB      0      0      /var/run/dovecot/config 22710208              * 22710205
u_str  ESTAB      0      0      /var/run/dovecot/config 10022233              * 10022182
u_str  ESTAB      0      0         * 14706                 * 14707
u_str  ESTAB      0      0         * 25228613              * 25228614
u_str  ESTAB      0      0      /var/run/dovecot/config 23431071              * 23431992
u_str  ESTAB      0      0      /var/run/dovecot/anvil 10023374              * 10023350
u_str  ESTAB      0      0      /var/run/dovecot/config 25709704              * 25709702
u_str  ESTAB      0      0      /run/dbus/system_bus_socket 14163                 * 14162
u_str  ESTAB      0      0         * 26362014              * 26362015
u_str  ESTAB      0      0         * 26034435              * 26035584
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 10023261              * 10022175
u_str  ESTAB      0      0         * 26361940              * 26361943
u_str  ESTAB      0      0         * 25708883              * 25708886
u_str  ESTAB      0      0         * 25708346              * 25708852
u_str  ESTAB      0      0         * 23311775              * 23311779
u_str  ESTAB      0      0         * 14531120              * 14531123
u_str  ESTAB      0      0         * 10022072              * 10021873
u_str  ESTAB      0      0      /var/run/dovecot/anvil 25708890              * 25708887
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 25641502              * 25641500
u_str  ESTAB      0      0      /var/run/dovecot/config 25292833              * 25291641
u_str  ESTAB      0      0         * 14657185              * 14657186
u_str  ESTAB      0      0         * 26362017              * 26362020
u_str  ESTAB      0      0      /var/run/dovecot/config 26035584              * 26034435
u_str  ESTAB      0      0         * 25723543              * 25723545
u_str  ESTAB      0      0         * 25293885              * 25293886
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 22710207              * 22710206
u_str  ESTAB      0      0         * 10023325              * 10023402
u_str  ESTAB      0      0      /var/run/dovecot/config 10022224              * 10023191
u_str  ESTAB      0      0         * 10022182              * 10022233
u_str  ESTAB      0      0         * 25709666              * 25709667
u_str  ESTAB      0      0         * 24531294              * 24531297
u_str  ESTAB      0      0      /var/run/dovecot/anvil 14531131              * 14531128
u_str  ESTAB      0      0         * 25709620              * 25709619
u_str  ESTAB      0      0      /var/run/dovecot/anvil 25642166              * 25642163
u_str  ESTAB      0      0         * 25641499              * 25640527
u_str  ESTAB      0      0      /var/run/dovecot/config 10022238              * 10023205
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 25724507              * 25723540
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 14657192              * 14657189
u_str  ESTAB      0      0         * 22710205              * 22710208
u_str  ESTAB      0      0         * 17026727              * 17026729
u_str  ESTAB      0      0      /var/run/dovecot/login/login 10023408              * 10022285
u_str  ESTAB      0      0      /var/run/dovecot/config 10022228              * 10022178
u_str  ESTAB      0      0         * 14707                 * 14706
u_str  ESTAB      0      0         * 23431993              * 23431073
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 25642162              * 25642161
u_str  ESTAB      0      0      /var/run/dovecot/anvil 10023388              * 10022315
u_str  ESTAB      0      0      /var/run/dovecot/login/login 25723545              * 25723543
u_str  ESTAB      0      0         * 25229524              * 25229525
u_str  ESTAB      0      0      /var/run/dovecot/login/login 10023402              * 10023325
u_str  ESTAB      0      0      /var/run/dovecot/anvil 25708360              * 25708357
u_str  ESTAB      0      0      /var/run/dovecot/anvil 10023378              * 10022303
u_str  ESTAB      0      0      /var/run/dovecot/anvil 10023340              * 10022283
u_str  ESTAB      0      0         * 10022183              * 10023269
u_str  ESTAB      0      0         * 25640708              * 25640711
u_str  ESTAB      0      0         * 23431992              * 23431071
u_str  ESTAB      0      0         * 22725418              * 22725419
u_str  ESTAB      0      0      /run/systemd/journal/stdout 10021873              * 10022072
u_str  ESTAB      0      0         * 25708297              * 25708301
u_str  ESTAB      0      0         * 25291641              * 25292833
u_str  ESTAB      0      0      /var/run/dovecot/anvil 23311779              * 23311775
u_str  ESTAB      0      0         * 10022315              * 10023388
u_str  ESTAB      0      0         * 10023200              * 10023268
u_str  ESTAB      0      0         * 26034445              * 26035662
u_str  ESTAB      0      0         * 25723541              * 25723544
u_str  ESTAB      0      0         * 25293042              * 25293044
u_str  ESTAB      0      0         * 24531295              * 24531296
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 23312624              * 23311773
u_str  ESTAB      0      0         * 10023317              * 10023401
u_str  ESTAB      0      0         * 25708517              * 25708541
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 25708355              * 25708354
u_str  ESTAB      0      0      /var/run/dovecot/anvil 25643269              * 25643266
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 23432108              * 23431151
u_str  ESTAB      0      0         * 10022283              * 10023340
u_str  ESTAB      0      0      /var/run/dovecot/login/login 25709710              * 25709708
u_str  ESTAB      0      0         * 24763091              * 24763776
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 23431073              * 23431993
u_str  ESTAB      0      0      /var/run/dovecot/login/login 10023414              * 10023352
u_str  ESTAB      0      0         * 25642161              * 25642162
u_str  ESTAB      0      0         * 24763777              * 24763099
u_str  ESTAB      0      0      /var/run/dovecot/anvil 14607927              * 14607924
u_str  ESTAB      0      0         * 10022317              * 10023427
u_str  ESTAB      0      0      /var/run/dovecot/config 10022236              * 10023203
u_str  ESTAB      0      0         * 25293886              * 25293885
u_str  ESTAB      0      0         * 24009835              * 24009836
u_str  ESTAB      0      0      /var/run/dovecot/anvil 10023326              * 10023323
u_str  ESTAB      0      0         * 10023191              * 10022224
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 25708852              * 25708346
u_str  ESTAB      0      0         * 24009005              * 24009006
u_str  ESTAB      0      0      /var/run/dovecot/anvil 19731464              * 19731461
u_str  ESTAB      0      0         * 10022178              * 10022228
u_str  ESTAB      0      0         * 23431147              * 23431146
u_str  ESTAB      0      0         * 22725419              * 22725418
u_str  ESTAB      0      0      /var/run/dovecot/anvil 24763083              * 24763760
u_str  ESTAB      0      0      /var/run/dovecot/login/login 10023427              * 10022317
u_str  ESTAB      0      0      /var/run/dovecot/anvil 10023331              * 10022271
u_str  ESTAB      0      0         * 10023204              * 10023272
u_str  ESTAB      0      0         * 25723539              * 25724506
u_str  ESTAB      0      0      /var/run/dovecot/anvil 25229531              * 25229527
u_str  ESTAB      0      0         * 14657189              * 14657192
u_str  ESTAB      0      0         * 10023314              * 10023400
u_str  ESTAB      0      0         * 10022285              * 10023408
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 10023264              * 10022179
u_str  ESTAB      0      0      /var/run/dovecot/config 25640711              * 25640708
u_str  ESTAB      0      0      /var/run/dovecot/config 14531123              * 14531120
u_str  ESTAB      0      0         * 22041                 * 22042
u_str  ESTAB      0      0      /run/systemd/journal/stdout 14805                 * 13681
u_str  ESTAB      0      0         * 25642163              * 25642166
u_str  ESTAB      0      0         * 25291642              * 25292835
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 16383292              * 16382788
u_str  ESTAB      0      0         * 14657186              * 14657185
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 10023272              * 10023204
u_str  ESTAB      0      0      /var/run/dovecot/config 25229526              * 25229523
u_str  ESTAB      0      0      /var/run/dovecot/config 24531297              * 24531294
u_str  ESTAB      0      0         * 10023192              * 10023260
u_str  ESTAB      0      0         * 24815106              * 24816046
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 17026729              * 17026727
u_str  ESTAB      0      0      /var/run/dovecot/config 10022230              * 10022180
u_str  ESTAB      0      0         * 23431096              * 23431095
u_str  ESTAB      0      0         * 14531128              * 14531131
u_str  ESTAB      0      0         * 10023352              * 10023414
u_str  ESTAB      0      0         * 13681                 * 14805
u_str  ESTAB      0      0         * 14607924              * 14607927
u_str  ESTAB      0      0         * 26362013              * 26362016
u_str  ESTAB      0      0      /var/run/dovecot/anvil 26220464              * 26219481
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 24531296              * 24531295
u_str  ESTAB      0      0         * 10023323              * 10023326
u_str  ESTAB      0      0         * 13344                 * 13345
u_str  ESTAB      0      0      /var/run/dovecot/login/login 10023418              * 10022305
u_str  ESTAB      0      0         * 10022180              * 10022230
u_str  ESTAB      0      0         * 25709184              * 25709679
u_str  ESTAB      0      0         * 14531121              * 14531125
u_str  ESTAB      0      0         * 25709703              * 25709705
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 25292835              * 25291642
u_str  ESTAB      0      0      /var/run/dovecot/stats-writer 10023268              * 10023200
Top Memory Usage:
mysql    23818  5.9 28.9 3962392 1970116 ?     Ssl  18:45  15:48 /usr/sbin/mysqld
root      1384  0.1 10.9 1165524 744084 ?      Ssl  Sep03   5:16 /usr/local/sbin/clamd --foreground=yes
root      3125  0.3  8.1 1496504 554652 ?      Rl   Sep03  18:43 /usr/local/sphinx-3.1.1/bin/searchd --config /usr/local/sphinx-3.1.1/etc/sphinx.conf
root     32056  0.0  3.1 293764 212248 ?       Ss   17:03   0:00 nginx: master process /usr/sbin/nginx -c /etc/nginx/nginx.conf
nginx     1135  7.3  3.1 293768 214476 ?       S    17:04  27:07 nginx: worker process
nginx     1134  7.1  3.1 293768 214440 ?       S    17:04  26:23 nginx: worker process
memcach+ 30377  0.1  1.6 454244 112612 ?       Ssl  Sep05   4:44 /usr/bin/memcached -u memcached -p 11211 -m 128 -c 512 -l 127.0.0.1, -U 0
apache   12795 13.5  0.4 2555356 28720 ?       Sl   22:58   1:48 /usr/sbin/httpd -DFOREGROUND
root     22572  0.3  0.3 172340 23860 ?        Ss   00:00   4:20 lfd - sleeping
apache   13992 11.6  0.3 2423408 22180 ?       Sl   23:03   1:01 /usr/sbin/httpd -DFOREGROUND
Virtual Memory Info:
procs -----------------------memory---------------------- ---swap-- -----io---- -system-- --------cpu-------- -----timestamp-----
 r  b         swpd         free         buff        cache   si   so    bi    bo   in   cs  us  sy  id  wa  st                CEST
 4  0       287724       168736       213032      2681292    1    1   445   703   16   31  16   5  74   5   0 2019-09-06 23:12:03
 3  1       287724       177296       213156      2681780    0    0   488  2208 8263 31010  34  12  51   3   0 2019-09-06 23:12:04
 0  1       287724       174828       213252      2683060    0    0   996  1532 8217 21981  32   9  55   5   0 2019-09-06 23:12:05
Automated Message Generated by DirectAdmin 1.58.2
Have a look at swap memory, Check crons as well.
It may also be the VPS, we had a similar issue and move to a new host where the issue seems to have gone.
check if something eating up all IO on server,
try also to turn off memecached
I checked disabling memcached but happens the same.
How can I see IO?
It's a public cloud of OVH, do you thing this can be the problem?
These are two screenshots from htop. screenshot2.jpg screenshot1.jpg screenshot3.jpg
You most likely has either brute-force attacks to your PHP application or SPAM bots posting to comments, feed-back forms, etc.
1. Check apache server status for suspicious and repeating URLs, IPs
2. Check apache server logs for suspicious and repeating URLs, IPs either. Search for POST requests.
3. Check mysqladmin for running queries.
https://help.directadmin.com/?query=server-status
seems like you got issues with your sql, try to optimzie it, or reoptimize it, its using over 75% of your memory,
or you code coded poorly or your my.cnf missconfigured
Finally I upgraded to an instance with more resources (15GB RAM and 4vcores) and now looks work fine, I also increased "innodb_buffer_pool_size" to 8GB that is the minumum recommended
I'm using WAF CloudFlare and also I've configured mod_security in the server with a large list of bad robots, web traffic seems normal, I attach a screenshot.
Too little PHP-FPM processes in comparison to Apache's processes... Are you sure you don't have mod_php installed?
I'm using php-fpm in phpinfo says: Server API --> FPM/FastCGI
That's huge amount of HTTPD processes. What is the output of the command "httpd -V"?
[root@cl home]# httpd -V
Server version: Apache/2.4.41 (Unix)
Server built: Aug 31 2019 00:56:28
Server's Module Magic Number: 20120211:88
Server loaded: APR 1.6.5, APR-UTIL 1.6.1
Compiled using: APR 1.6.5, APR-UTIL 1.6.1
Architecture: 64-bit
Server MPM: event
threaded: yes (fixed thread count)
forked: yes (variable process count)
Server compiled with....
-D APR_HAS_SENDFILE
-D APR_HAS_MMAP
-D APR_HAVE_IPV6 (IPv4-mapped addresses enabled)
-D APR_USE_SYSVSEM_SERIALIZE
-D APR_USE_PTHREAD_SERIALIZE
-D SINGLE_LISTEN_UNSERIALIZED_ACCEPT
-D APR_HAS_OTHER_CHILD
-D AP_HAVE_RELIABLE_PIPED_LOGS
-D DYNAMIC_MODULE_LIMIT=256
-D HTTPD_ROOT="/etc/httpd"
-D HAVE_SYSTEMD
-D SUEXEC_BIN="/usr/sbin/suexec"
-D DEFAULT_PIDLOG="/var/logs/httpd.pid"
-D DEFAULT_SCOREBOARD="logs/apache_runtime_status"
-D DEFAULT_ERRORLOG="logs/error_log"
-D AP_TYPES_CONFIG_FILE="conf/mime.types"
-D SERVER_CONFIG_FILE="conf/httpd.conf"
and
./build options
Hi Alex,
# cd /usr/local/directadmin/custombuild
# ./build options
Apache: 2.4.41
Nginx (reverse proxy): 1.17.3
mod_ruid2: 0.9.8
LibModSecurity: 3.0.3
LibModSecurity Rule Set: comodo
htscanner: no
Dovecot: 2.3.7.2
Dovecot configuration: yes
AWstats: no
Exim: 4.92.2
exim.conf update: yes, release 4.5
BlockCracking: no
Easy Spam Fighter: yes
SpamAssassin: 3.4.2
SpamAssassin rule updates: daily
ClamAV: 0.101.4
MariaDB: 10.4.7
MySQL backup: yes
MySQL backup directory: /usr/local/directadmin/custombuild/mysql_backups
MySQL compress backups: no
PHP (default): 7.2 as php-fpm
phpMyAdmin: 4.9.0.1-all-languages
ProFTPD: no
Pure-FTPd: 1.0.49
RoundCube webmail: 1.3.10
Replace "php.ini" with './build all' and './build php_ini': no
Cron for notifications and (or) updates: yes
Cron frequency: daily
Auto notifications: yes
Auto notifications email address: [email protected]
Run "clean" every time: yes
Run "clean_old_webapps" every time: yes
Run "clean_old_tarballs" every time: yes
Show texts in bold: yes
SquirrelMail: no
Zend Guard Loader: no
ionCube loader: no
Suhosin: no
Hi Alex,
I wrote the other day but I don't know what happened with my response, I write again.
It's a server in production, can't try twit the settings, this are the current settings:
Apache --> /etc/httpd/conf/extra/httpd-mpm.conf
<IfModule mpm_event_module>
    StartServers             6
    MinSpareThreads	    32
    MaxSpareThreads	   128
    ThreadsPerChild         64
    ServerLimit            700
    MaxRequestWorkers      700
    MaxConnectionsPerChild   4000
</IfModule>
nginx --> /etc/nginx/nginx-proxy.conf
proxy_connect_timeout 600s;
proxy_send_timeout    600s;
proxy_read_timeout    600s;
proxy_buffer_size     128k;
#proxy_buffers       4 256k;
proxy_buffers        256 16k;
open_file_cache                	max=200000 inactive=20s;
open_file_cache_errors         	on;
open_file_cache_min_uses	2;
open_file_cache_valid          	30s;
proxy_busy_buffers_size 256k;
php-fpm72 --> /usr/local/directadmin/data/templates/custom/php-fpm.conf
|?PHP_VER=54|
|?OPEN_BASEDIR_PATH=`HOME`/:/tmp/:/var/tmp/:/usr/local/php`PHP_VER`/lib/:`ACTIVE_USR_LOCAL_PHP_LIB`:/usr/local/lib/php/|
|?EMAIL=`USER`@`DOMAIN`|
|?MAX_CHILDREN=100|
|?MAX_REQUESTS=500|
|CUSTOM1|
[|USER|]
user = $pool
group = $pool
listen = /usr/local/php|PHP_VER|/sockets/$pool.sock
listen.owner = $pool
listen.group = |SERVER_GROUP|
listen.mode = 660
pm = ondemand
pm.max_children = |MAX_CHILDREN|
pm.process_idle_timeout = 20
pm.max_requests = |MAX_REQUESTS|
php_admin_value[sendmail_path] = /usr/sbin/sendmail -t -i -f |EMAIL|
|*if PHP_SESSION_SAVE_PATH!=""|
php_admin_value[session.save_path] = |PHP_SESSION_SAVE_PATH|
|*endif|
|*if OPEN_BASEDIR="ON"|
php_admin_value[open_basedir] = |OPEN_BASEDIR_PATH|
|*endif|
|*if PHP_MAIL_LOG_ENABLED="1"|
php_admin_value[mail.log] = |HOME|/.php/php-mail.log
|*endif|
|*if LIMIT_EXTENSIONS!=""|
security.limit_extensions = |LIMIT_EXTENSIONS|
|*endif|
|CUSTOM2|
I have already answered twice and my answer does not appear, how long does it take here to moderate the messages?
How do I do it?
Do I go to Admin/CustomBuild/Edit Options and in WEB Server Settings change "mod_ruid2" to no and save, then I go to tab "Build Software" and build "Apache"?
Is there any risk?
Thank you,
Carlos
Yes, recompilation of Apache is required here, I'd rather say. Please correct me if I'm wrong.
./build apache
./build rewrite_confs
There always risks to re-compile a software, if for example your config files contain a syntax error, it might stay unnoticed until you reboot server or re-compile/upgrade Apache/nginx...
