I'm having problems with randomly high server load .
The server go up until 10-15 and then it begins to go down slowly until 0.30, suddenly grow up until sort of 10 and again the same. This is happening about every 7-10 minutes.
I don't know which can be the problem, I've optimized php, mysql, apache, nginx... but continue happening, this is one of the reports that I receive.
I have 2 vcores with 7GB of RAM - apache_nginx | php-fpm 7.2 | opcache | memcached | sphinx
Thank you for your help.
Warning: The system load average is 13.54
9/6/2019, 23:12:05
This is an automated message notifying you that the 5 minute load average on your system is 13.54.
This has exceeded the 10 threshold.
One Minute - 13.23
Five Minutes - 13.54
Fifteen Minutes - 13.81
top - 23:12:02 up 3 days, 13:19, 2 users, load average: 13.23, 13.54, 13.81
Tasks: 283 total, 2 running, 281 sleeping, 0 stopped, 0 zombie
%Cpu(s): 31.2 us, 12.5 sy, 0.0 ni, 53.1 id, 3.1 wa, 0.0 hi, 0.0 si, 0.0 st
KiB Mem : 6806976 total, 171152 free, 3747736 used, 2888088 buff/cache
KiB Swap: 2621436 total, 2333712 free, 287724 used. 2516320 avail Mem
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
1134 nginx 20 0 293768 214440 4380 S 31.2 3.2 26:23.67 nginx: worker process
13992 apache 20 0 2423408 22180 4164 S 18.8 0.3 1:01.82 /usr/sbin/httpd -DFOREGROUND
1135 nginx 20 0 293768 214476 4416 R 12.5 3.2 27:07.71 nginx: worker process
11951 admin 20 0 360188 25660 8640 S 12.5 0.4 0:14.18 php-fpm: pool admin
15895 root 20 0 58564 2224 1476 R 6.2 0.0 0:00.01 /usr/bin/top -c -b -n 1
1 root 20 0 191276 3012 1748 S 0.0 0.0 0:53.88 /usr/lib/systemd/systemd --switched-root --system --deserialize 22
2 root 20 0 0 0 0 S 0.0 0.0 0:00.35 [kthreadd]
3 root 20 0 0 0 0 S 0.0 0.0 1:03.96 [ksoftirqd/0]
5 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 [kworker/0:0H]
7 root rt 0 0 0 0 S 0.0 0.0 0:01.11 [migration/0]
8 root 20 0 0 0 0 S 0.0 0.0 0:00.00 [rcu_bh]
9 root 20 0 0 0 0 S 0.0 0.0 7:38.12 [rcu_sched]
10 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 [lru-add-drain]
11 root rt 0 0 0 0 S 0.0 0.0 0:01.69 [watchdog/0]
12 root rt 0 0 0 0 S 0.0 0.0 0:01.49 [watchdog/1]
13 root rt 0 0 0 0 S 0.0 0.0 0:00.96 [migration/1]
14 root 20 0 0 0 0 S 0.0 0.0 1:11.90 [ksoftirqd/1]
16 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 [kworker/1:0H]
18 root 20 0 0 0 0 S 0.0 0.0 0:00.00 [kdevtmpfs]
19 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 [netns]
20 root 20 0 0 0 0 S 0.0 0.0 0:00.38 [khungtaskd]
21 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 [writeback]
22 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 [kintegrityd]
I/O Information:
Total DISK READ : 647.52 K/s | Total DISK WRITE : 1262.66 K/s
Actual DISK READ: 32.38 K/s | Actual DISK WRITE: 2.21 M/s
TID PRIO USER DISK READ DISK WRITE SWAPIN IO COMMAND
11658 be/4 admin 615.14 K/s 64.75 K/s 0.00 % 48.77 % php-fpm: pool admin
23865 be/4 mysql 0.00 B/s 64.75 K/s 0.00 % 19.56 % mysqld
11958 be/4 admin 32.38 K/s 0.00 B/s 0.00 % 0.97 % php-fpm: pool admin
23833 be/4 mysql 0.00 B/s 388.51 K/s 0.00 % 0.38 % mysqld
25048 be/4 mysql 0.00 B/s 32.38 K/s 0.00 % 0.00 % mysqld
14122 be/4 apache 0.00 B/s 679.89 K/s 0.00 % 0.00 % httpd -DFOREGROUND
14181 be/4 admin 0.00 B/s 32.38 K/s 0.00 % 0.00 % php-fpm: pool admin
1 be/4 root 0.00 B/s 0.00 B/s 0.00 % 0.00 % systemd --switched-root --system --deserialize 22
2 be/4 root 0.00 B/s 0.00 B/s 0.00 % 0.00 % [kthreadd]
3 be/4 root 0.00 B/s 0.00 B/s 0.00 % 0.00 % [ksoftirqd/0]
5 be/0 root 0.00 B/s 0.00 B/s 0.00 % 0.00 % [kworker/0:0H]
7 rt/4 root 0.00 B/s 0.00 B/s 0.00 % 0.00 % [migration/0]
8 be/4 root 0.00 B/s 0.00 B/s 0.00 % 0.00 % [rcu_bh]
9 be/4 root 0.00 B/s 0.00 B/s 0.00 % 0.00 % [rcu_sched]
10 be/0 root 0.00 B/s 0.00 B/s 0.00 % 0.00 % [lru-add-drain]
11 rt/4 root 0.00 B/s 0.00 B/s 0.00 % 0.00 % [watchdog/0]
12 rt/4 root 0.00 B/s 0.00 B/s 0.00 % 0.00 % [watchdog/1]
13 rt/4 root 0.00 B/s 0.00 B/s 0.00 % 0.00 % [migration/1]
14 be/4 root 0.00 B/s 0.00 B/s 0.00 % 0.00 % [ksoftirqd/1]
30381 be/4 memcache 0.00 B/s 0.00 B/s 0.00 % 0.00 % memcached -u memcached -p 11211 -m 128 -c 512 -l 127.0.0.1, -U 0
16 be/0 root 0.00 B/s 0.00 B/s 0.00 % 0.00 % [kworker/1:0H]
18 be/4 root 0.00 B/s 0.00 B/s 0.00 % 0.00 % [kdevtmpfs]
19 be/0 root 0.00 B/s 0.00 B/s 0.00 % 0.00 % [netns]
20 be/4 root 0.00 B/s 0.00 B/s 0.00 % 0.00 % [khungtaskd]
21 be/0 root 0.00 B/s 0.00 B/s 0.00 % 0.00 % [writeback]
22 be/0 root 0.00 B/s 0.00 B/s 0.00 % 0.00 % [kintegrityd]
23 be/0 root 0.00 B/s 0.00 B/s 0.00 % 0.00 % [bioset]
/usr/sbin/ss output:
Netid State Recv-Q Send-Q Local Address:Port Peer Address:Port
u_str ESTAB 0 0 * 26362019 * 26362021
u_str ESTAB 0 0 /var/run/dovecot/anvil 23402870 * 23402867
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 14657282 * 14657280
u_str ESTAB 0 0 * 24006795 * 24006504
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 23247458 * 23247456
u_str ESTAB 0 0 * 19031 * 19032
u_str ESTAB 0 0 /var/run/dovecot/login/login 26035663 * 26034447
u_str ESTAB 0 0 * 26329141 * 26329143
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 25643265 * 25643262
u_str ESTAB 0 0 * 25293053 * 25293054
u_str ESTAB 0 0 /var/run/dovecot/config 25286361 * 25286358
u_str ESTAB 0 0 * 23317861 * 23317468
u_str ESTAB 0 0 * 25293841 * 25293843
u_str ESTAB 0 0 * 25708488 * 25709005
u_str ESTAB 0 0 * 25640709 * 25640712
u_str ESTAB 0 0 * 25640538 * 25641538
u_str ESTAB 0 0 * 10022173 * 10023259
u_str ESTAB 0 0 /run/systemd/journal/stdout 19032 * 19031
u_str ESTAB 0 0 * 25709670 * 25709671
u_str ESTAB 0 0 * 21081351 * 21081353
u_str ESTAB 0 0 * 10022167 * 10023253
u_str ESTAB 0 0 * 25630132 * 25630822
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 25286360 * 25286359
u_str ESTAB 0 0 * 25228578 * 25228579
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 24742471 * 24742470
u_str ESTAB 0 0 * 25709204 * 25709205
u_str ESTAB 0 0 /var/run/dovecot/config 25708476 * 25708996
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 10023260 * 10023192
u_str ESTAB 0 0 /var/run/dovecot/anvil 25641538 * 25640538
u_str ESTAB 0 0 * 25047403 * 25048286
u_str ESTAB 0 0 * 23329338 * 23329340
u_str ESTAB 0 0 * 23247456 * 23247458
u_str ESTAB 0 0 * 25641997 * 25641999
u_str ESTAB 0 0 * 21081352 * 21081354
u_str ESTAB 0 0 * 10022164 * 10022215
u_str ESTAB 0 0 /var/run/dovecot/login/login 26362021 * 26362019
u_str ESTAB 0 0 /var/run/dovecot/config 26329142 * 26329140
u_str ESTAB 0 0 /var/run/dovecot/config 25630131 * 25630130
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 21231430 * 21231429
u_str ESTAB 0 0 /var/run/dovecot/login/login 10023403 * 10022270
u_str ESTAB 0 0 /var/run/dovecot/anvil 10023321 * 10023312
u_str ESTAB 0 0 /run/systemd/journal/stdout 14885 * 14884
u_str ESTAB 0 0 * 25709209 * 25709733
u_str ESTAB 0 0 * 25709013 * 25708502
u_str ESTAB 0 0 /var/run/dovecot/config 17026728 * 17026726
u_str ESTAB 0 0 /var/run/dovecot/config 25708474 * 25708989
u_str ESTAB 0 0 /var/run/dovecot/config 24763774 * 24763089
u_str ESTAB 0 0 /var/run/dovecot/config 10022223 * 10022172
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 25709148 * 25709147
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 23432079 * 23432078
u_str ESTAB 0 0 * 12939922 * 12939921
u_str ESTAB 0 0 /var/run/dovecot/config 10022216 * 10022166
u_str ESTAB 0 0 * 25709708 * 25709710
u_str ESTAB 0 0 /var/run/dovecot/anvil 23317468 * 23317861
u_str ESTAB 0 0 * 10023312 * 10023321
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 26362033 * 26362031
u_str ESTAB 0 0 * 26240065 * 26239774
u_str ESTAB 0 0 /var/run/dovecot/login/login 25642167 * 25642165
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 25293833 * 25293831
u_str ESTAB 0 0 /var/run/dovecot/anvil 24816047 * 24815107
u_str ESTAB 0 0 * 24597205 * 24597225
u_str ESTAB 0 0 * 10022170 * 10022221
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 10023252 * 10022165
u_str ESTAB 0 0 /var/run/dovecot/config 25703249 * 25703894
u_str ESTAB 0 0 * 25643266 * 25643269
u_str ESTAB 0 0 /var/run/dovecot/config 25640516 * 25640513
u_str ESTAB 0 0 * 25630130 * 25630131
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 23317467 * 23317860
u_str ESTAB 0 0 * 10023219 * 10023282
u_str ESTAB 0 0 * 25709203 * 25709725
u_str ESTAB 0 0 /var/run/dovecot/config 10022221 * 10022170
u_str ESTAB 0 0 * 26361288 * 26361289
u_str ESTAB 0 0 * 26329144 * 26329147
u_str ESTAB 0 0 * 25709114 * 25709113
u_str ESTAB 0 0 * 25703894 * 25703249
u_str ESTAB 0 0 /var/run/dovecot/config 25228580 * 25228577
u_str ESTAB 0 0 /var/run/dovecot/config 24742472 * 24742469
u_str ESTAB 0 0 /var/run/dovecot/login/login 10023398 * 10023308
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 25569525 * 25569523
u_str ESTAB 0 0 * 25228594 * 25228595
u_str ESTAB 0 0 * 14657280 * 14657282
u_str ESTAB 0 0 * 23247455 * 23247457
u_str ESTAB 0 0 /var/run/dovecot/config 21081353 * 21081351
u_str ESTAB 0 0 * 10022165 * 10023252
u_str ESTAB 0 0 /var/run/dovecot/anvil 26329147 * 26329144
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 25228579 * 25228578
u_str ESTAB 0 0 * 24742469 * 24742472
u_str ESTAB 0 0 * 23329342 * 23328711
u_str ESTAB 0 0 * 12939927 * 12939928
u_str ESTAB 0 0 * 10023199 * 10022232
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 26361243 * 26361973
u_str ESTAB 0 0 /var/run/dovecot/login/login 25709005 * 25708488
u_str ESTAB 0 0 * 25708990 * 25708473
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 25640712 * 25640709
u_str ESTAB 0 0 /var/run/dovecot/config 23329340 * 23329338
u_str ESTAB 0 0 * 10022171 * 10023258
u_str ESTAB 0 0 /run/dbus/system_bus_socket 13949 * 13948
u_str ESTAB 0 0 * 23432036 * 23432037
u_str ESTAB 0 0 /var/run/dovecot/config 10022215 * 10022164
u_str ESTAB 0 0 * 25708894 * 25708895
u_str ESTAB 0 0 /var/run/dovecot/anvil 25228584 * 25228581
u_str ESTAB 0 0 * 23329339 * 23329341
u_str ESTAB 0 0 /var/run/dovecot/config 14530558 * 14530555
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 26240064 * 26239772
u_str ESTAB 0 0 * 25708997 * 25708477
u_str ESTAB 0 0 * 25569523 * 25569525
u_str ESTAB 0 0 * 25293831 * 25293833
u_str ESTAB 0 0 * 26034451 * 26035666
u_str ESTAB 0 0 /var/run/dovecot/login/login 25708537 * 25708525
u_str ESTAB 0 0 * 24763089 * 24763774
u_str ESTAB 0 0 * 24257145 * 24257144
u_str ESTAB 0 0 * 25251863 * 25251864
u_str ESTAB 0 0 * 25709113 * 25709114
u_str ESTAB 0 0 /var/run/dovecot/config 25643227 * 25642160
u_str ESTAB 0 0 * 25228577 * 25228580
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 23329341 * 23329339
u_str ESTAB 0 0 * 21231429 * 21231430
u_str ESTAB 0 0 * 14884 * 14885
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 25709205 * 25709204
u_str ESTAB 0 0 * 25708996 * 25708476
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 25293843 * 25293841
u_str ESTAB 0 0 * 25708525 * 25708537
u_str ESTAB 0 0 * 25708989 * 25708474
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 25048286 * 25047403
u_str ESTAB 0 0 * 25047402 * 25047404
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 24763771 * 24763090
u_str ESTAB 0 0 * 24257144 * 24257145
u_str ESTAB 0 0 * 10022172 * 10022223
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 21081354 * 21081352
u_str ESTAB 0 0 * 16382787 * 16382789
u_str ESTAB 0 0 * 23317859 * 23317466
u_str ESTAB 0 0 /var/run/dovecot/anvil 25709731 * 25709207
u_str ESTAB 0 0 /var/run/dovecot/anvil 25708543 * 25708523
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 10023258 * 10022171
u_str ESTAB 0 0 * 26361237 * 26361238
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 25703250 * 25703895
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 25630822 * 25630132
u_str ESTAB 0 0 * 25291731 * 25291733
u_str ESTAB 0 0 /var/run/dovecot/anvil 25286365 * 25286362
u_str ESTAB 0 0 /var/run/dovecot/config 23317466 * 23317859
u_str ESTAB 0 0 /var/run/dovecot/config 10022232 * 10023199
u_str ESTAB 0 0 * 25293825 * 25293826
u_str ESTAB 0 0 /var/run/dovecot/anvil 25640720 * 25640715
u_str ESTAB 0 0 * 24763090 * 24763771
u_str ESTAB 0 0 /var/run/dovecot/config 23247457 * 23247455
u_str ESTAB 0 0 * 25251862 * 25251865
u_str ESTAB 0 0 * 25228634 * 25229592
u_str ESTAB 0 0 * 26329140 * 26329142
u_str ESTAB 0 0 * 25708895 * 25708894
u_str ESTAB 0 0 * 25643262 * 25643265
u_str ESTAB 0 0 * 23247485 * 23247488
u_str ESTAB 0 0 /run/systemd/journal/stdout 14680 * 13577
u_str ESTAB 0 0 /var/run/dovecot/login/login 25709733 * 25709209
u_str ESTAB 0 0 * 25293826 * 25293825
u_str ESTAB 0 0 * 25708486 * 25709004
u_str ESTAB 0 0 /run/systemd/journal/stdout 24006504 * 24006795
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 10023259 * 10022173
u_str ESTAB 0 0 /var/run/dovecot/config 26034450 * 26034448
u_str ESTAB 0 0 /var/run/dovecot/config 25229592 * 25228634
u_str ESTAB 0 0 * 25703895 * 25703250
u_str ESTAB 0 0 * 25286362 * 25286365
u_str ESTAB 0 0 * 26361973 * 26361243
u_str ESTAB 0 0 /var/run/dovecot/anvil 26239774 * 26240065
u_str ESTAB 0 0 /var/run/dovecot/config 24816045 * 24815105
u_str ESTAB 0 0 * 16382788 * 16383292
u_str ESTAB 0 0 * 10022175 * 10023261
u_str ESTAB 0 0 * 26361289 * 26361288
u_str ESTAB 0 0 * 26034448 * 26034450
u_str ESTAB 0 0 /var/run/dovecot/config 25251865 * 25251862
u_str ESTAB 0 0 * 25286358 * 25286361
u_str ESTAB 0 0 * 25228581 * 25228584
u_str ESTAB 0 0 * 24742470 * 24742471
u_str ESTAB 0 0 * 23317860 * 23317467
u_str ESTAB 0 0 * 12939928 * 12939927
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 10023282 * 10023219
u_str ESTAB 0 0 * 25709207 * 25709731
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 25708502 * 25709013
u_str ESTAB 0 0 * 25228595 * 25228594
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 10023254 * 10023185
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 25708473 * 25708990
u_str ESTAB 0 0 /var/run/dovecot/config 25047404 * 25047402
u_str ESTAB 0 0 /var/run/dovecot/config 10022225 * 10022174
u_str ESTAB 0 0 * 26034449 * 26035664
u_str ESTAB 0 0 * 23432037 * 23432036
u_str ESTAB 0 0 /var/run/dovecot/config 16382789 * 16382787
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 26329143 * 26329141
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 25291733 * 25291731
u_str ESTAB 0 0 * 25286359 * 25286360
u_str ESTAB 0 0 /var/run/dovecot/config 25709725 * 25709203
u_str ESTAB 0 0 * 24815107 * 24816047
u_str ESTAB 0 0 /var/run/dovecot/anvil 25709004 * 25708486
u_str ESTAB 0 0 * 25640715 * 25640720
u_str ESTAB 0 0 * 24815105 * 24816045
u_str ESTAB 0 0 /run/systemd/journal/stdout 24597225 * 24597205
u_str ESTAB 0 0 * 10022174 * 10022225
u_str ESTAB 0 0 * 13948 * 13949
u_str ESTAB 0 0 * 25709147 * 25709148
u_str ESTAB 0 0 * 10022166 * 10022216
u_str ESTAB 0 0 * 25293054 * 25293053
u_str ESTAB 0 0 * 14530555 * 14530558
u_str ESTAB 0 0 * 12939921 * 12939922
u_str ESTAB 0 0 * 15320 * 14043
u_str ESTAB 0 0 /var/run/dovecot/config 26220463 * 26219479
u_str ESTAB 0 0 * 25643291 * 25643294
u_str ESTAB 0 0 * 25641995 * 25641998
u_str ESTAB 0 0 * 24763743 * 24763755
u_str ESTAB 0 0 /var/run/dovecot/anvil 14531587 * 14530559
u_str ESTAB 0 0 * 25293026 * 25293027
u_str ESTAB 0 0 /var/run/dovecot/login/login 10023405 * 10022276
u_str ESTAB 0 0 * 23431146 * 23431147
u_str ESTAB 0 0 * 23183590 * 23183589
u_str ESTAB 0 0 /var/run/dovecot/config 21908831 * 21908829
u_str ESTAB 0 0 * 10023185 * 10023254
u_str ESTAB 0 0 * 24009829 * 24009828
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 10023253 * 10022167
u_str ESTAB 0 0 * 25709593 * 25709592
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 14530557 * 14530556
u_str ESTAB 0 0 * 25293023 * 25293024
u_str ESTAB 0 0 * 25709647 * 25709646
u_str ESTAB 0 0 * 25672278 * 25672714
u_str ESTAB 0 0 * 25535508 * 25534749
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 25293034 * 25293033
u_str ESTAB 0 0 * 25046897 * 25046898
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 14657262 * 14657260
u_str ESTAB 0 0 * 25742692 * 25742694
u_str ESTAB 0 0 * 25708523 * 25708543
u_str ESTAB 0 0 /var/run/dovecot/login/login 25709039 * 25709036
u_str ESTAB 0 0 /var/run/dovecot/login/login 25641999 * 25641997
u_str ESTAB 0 0 * 20848129 * 20848131
u_str ESTAB 0 0 /var/run/dovecot/anvil 24640659 * 24640655
u_str ESTAB 0 0 /run/dbus/system_bus_socket 14708 * 14589
u_str ESTAB 0 0 /var/run/dovecot/anvil 25292851 * 25291652
u_str ESTAB 0 0 * 25228635 * 25229593
u_str ESTAB 0 0 /var/run/dovecot/config 23739853 * 23739851
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 23431107 * 23431105
u_str ESTAB 0 0 * 25708838 * 25708295
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 25709679 * 25709184
u_str ESTAB 0 0 * 25709036 * 25709039
u_str ESTAB 0 0 * 25643287 * 25643289
u_str ESTAB 0 0 * 25641992 * 25641994
u_str ESTAB 0 0 * 25292883 * 25292882
u_str ESTAB 0 0 * 10023218 * 10022246
u_str ESTAB 0 0 * 23431105 * 23431107
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 23432052 * 23432050
u_str ESTAB 0 0 * 20495 * 19700
u_str ESTAB 0 0 /var/run/dovecot/config 10022246 * 10023218
u_str ESTAB 0 0 * 25709706 * 25709709
u_str ESTAB 0 0 * 25709637 * 25709636
u_str ESTAB 0 0 /var/run/dovecot/config 25643289 * 25643287
u_str ESTAB 0 0 * 14530556 * 14530557
u_str ESTAB 0 0 * 25643232 * 25643235
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 24640653 * 24640652
u_str ESTAB 0 0 * 25709642 * 25709641
u_str ESTAB 0 0 /var/run/dovecot/config 25672714 * 25672278
u_str ESTAB 0 0 * 25228617 * 25228619
u_str ESTAB 0 0 /var/run/dovecot/config 25046899 * 25046896
u_str ESTAB 0 0 * 23432047 * 23432046
u_str ESTAB 0 0 /var/run/dovecot/config 10022217 * 10023184
u_str ESTAB 0 0 * 10022949 * 10022948
u_str ESTAB 0 0 * 26219479 * 26220463
u_str ESTAB 0 0 /var/run/dovecot/config 25742694 * 25742692
u_str ESTAB 0 0 * 23432040 * 23432042
u_str ESTAB 0 0 * 14530559 * 14531587
u_str ESTAB 0 0 * 25293024 * 25293023
u_str ESTAB 0 0 /var/run/dovecot/config 24640654 * 24640651
u_str ESTAB 0 0 * 10022276 * 10023405
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 25709667 * 25709666
u_str ESTAB 0 0 * 25291759 * 25291761
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 25228619 * 25228617
u_str ESTAB 0 0 * 12939925 * 12939924
u_str ESTAB 0 0 * 14657257 * 14657256
u_str ESTAB 0 0 /var/run/dovecot/anvil 26361943 * 26361940
u_str ESTAB 0 0 /var/run/dovecot/anvil 10023334 * 10022277
u_str ESTAB 0 0 /var/run/dovecot/anvil 25672283 * 25672280
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 25229593 * 25228635
u_str ESTAB 0 0 * 25046896 * 25046899
u_str ESTAB 0 0 * 12939924 * 12939925
u_str ESTAB 0 0 /var/run/dovecot/login/login 26220465 * 26219483
u_str ESTAB 0 0 * 25709686 * 25709687
u_str ESTAB 0 0 * 25709592 * 25709593
u_str ESTAB 0 0 * 25643288 * 25643290
u_str ESTAB 0 0 * 14657256 * 14657257
u_str ESTAB 0 0 * 10023211 * 10022243
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 25293044 * 25293042
u_str ESTAB 0 0 * 24640651 * 24640654
u_str ESTAB 0 0 * 10022277 * 10023334
u_str ESTAB 0 0 * 10023308 * 10023398
u_str ESTAB 0 0 * 12357 * 11599
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 25672715 * 25672279
u_str ESTAB 0 0 * 10023184 * 10022217
u_str ESTAB 0 0 * 10022948 * 10022949
u_str ESTAB 0 0 /run/systemd/journal/stdout 15292 * 15291
u_str ESTAB 0 0 /var/run/dovecot/anvil 25709709 * 25709706
u_str ESTAB 0 0 /var/run/dovecot/anvil 25641998 * 25641995
u_str ESTAB 0 0 /var/run/dovecot/config 25474890 * 25474888
u_str ESTAB 0 0 * 24763744 * 24763745
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 19730383 * 19731117
u_str ESTAB 0 0 /run/systemd/journal/stdout 3820054 * 3819300
u_str ESTAB 0 0 * 25293027 * 25293026
u_str ESTAB 0 0 /var/run/dovecot/login/login 10023404 * 10022273
u_str ESTAB 0 0 * 25672280 * 25672283
u_str ESTAB 0 0 * 25292908 * 25292907
u_str ESTAB 0 0 /var/run/dovecot/anvil 25046903 * 25046900
u_str ESTAB 0 0 * 23432046 * 23432047
u_str ESTAB 0 0 * 21908829 * 21908831
u_str ESTAB 0 0 * 25708849 * 25708848
u_str ESTAB 0 0 * 24009828 * 24009829
u_str ESTAB 0 0 * 26219480 * 26220462
u_str ESTAB 0 0 * 25742693 * 25742695
u_str ESTAB 0 0 * 25474888 * 25474890
u_str ESTAB 0 0 /var/run/dovecot/config 20848131 * 20848129
u_str ESTAB 0 0 * 12940608 * 12940609
u_str ESTAB 0 0 * 21908830 * 21908832
u_str ESTAB 0 0 /var/run/dovecot/config 25708296 * 25708837
u_str ESTAB 0 0 /run/dbus/system_bus_socket 14043 * 15320
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 25742695 * 25742693
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 25709687 * 25709686
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 25709136 * 25709133
u_str ESTAB 0 0 * 25709034 * 25709038
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 25641994 * 25641992
u_str ESTAB 0 0 * 3819300 * 3820054
u_str ESTAB 0 0 /var/run/dovecot/anvil 25643235 * 25643232
u_str ESTAB 0 0 * 25229570 * 25228598
u_str ESTAB 0 0 * 23739852 * 23739854
u_str ESTAB 0 0 * 14657260 * 14657262
u_str ESTAB 0 0 * 15291 * 15292
u_str ESTAB 0 0 * 25474889 * 25474891
u_str ESTAB 0 0 * 25292882 * 25292883
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 24763745 * 24763744
u_str ESTAB 0 0 * 24243352 * 24242547
u_str ESTAB 0 0 * 20848130 * 20848132
u_str ESTAB 0 0 * 10023212 * 10023279
u_str ESTAB 0 0 /var/run/dovecot/anvil 10023332 * 10022274
u_str ESTAB 0 0 * 14589 * 14708
u_str ESTAB 0 0 * 25535507 * 25534750
u_str ESTAB 0 0 * 25293033 * 25293034
u_str ESTAB 0 0 * 23739851 * 23739853
u_str ESTAB 0 0 * 23183589 * 23183590
u_str ESTAB 0 0 * 25709641 * 25709642
u_str ESTAB 0 0 * 25641991 * 25641993
u_str ESTAB 0 0 /run/systemd/journal/stdout 12940609 * 12940608
u_str ESTAB 0 0 /var/run/dovecot/config 10022243 * 10023211
u_str ESTAB 0 0 * 21870135 * 21870136
u_str ESTAB 0 0 /run/systemd/journal/stdout 11599 * 12357
u_str ESTAB 0 0 * 25709646 * 25709647
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 25534749 * 25535508
u_str ESTAB 0 0 * 25046900 * 25046903
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 21908832 * 21908830
u_str ESTAB 0 0 * 26219483 * 26220465
u_str ESTAB 0 0 * 25708848 * 25708849
u_str ESTAB 0 0 * 25709133 * 25709136
u_str ESTAB 0 0 /var/run/dovecot/login/login 25708535 * 25708519
u_str ESTAB 0 0 * 25708887 * 25708890
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 25643290 * 25643288
u_str ESTAB 0 0 * 24640655 * 24640659
u_str ESTAB 0 0 * 10022273 * 10023404
u_str ESTAB 0 0 * 25672279 * 25672715
u_str ESTAB 0 0 * 25291652 * 25292851
u_str ESTAB 0 0 /var/run/dovecot/anvil 23247488 * 23247485
u_str ESTAB 0 0 * 25708837 * 25708296
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 26220462 * 26219480
u_str ESTAB 0 0 * 25709120 * 25709122
u_str ESTAB 0 0 /var/run/dovecot/anvil 25709038 * 25709034
u_str ESTAB 0 0 /var/run/dovecot/anvil 25643294 * 25643291
u_str ESTAB 0 0 /var/run/dovecot/config 25641993 * 25641991
u_str ESTAB 0 0 /var/run/dovecot/anvil 24242547 * 24243352
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 25228598 * 25229570
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 25708295 * 25708838
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 25709122 * 25709120
u_str ESTAB 0 0 /var/run/dovecot/config 24763755 * 24763743
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 20848132 * 20848130
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 10023279 * 10023212
u_str ESTAB 0 0 * 24640652 * 24640653
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 21870136 * 21870135
u_str ESTAB 0 0 * 10022274 * 10023332
u_str ESTAB 0 0 /var/run/dovecot/config 25534750 * 25535507
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 25291761 * 25291759
u_str ESTAB 0 0 * 25292907 * 25292908
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 25046898 * 25046897
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 23739854 * 23739852
u_str ESTAB 0 0 * 23432050 * 23432052
u_str ESTAB 0 0 /run/dbus/system_bus_socket 19700 * 20495
u_str ESTAB 0 0 /var/run/dovecot/config 25708511 * 25709012
u_str ESTAB 0 0 /var/run/dovecot/login/login 25708999 * 25708480
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 25708900 * 25708898
u_str ESTAB 0 0 * 23981671 * 23981674
u_str ESTAB 0 0 * 10023188 * 10022220
u_str ESTAB 0 0 * 22725369 * 22725370
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 25228602 * 25229578
u_str ESTAB 0 0 * 23311773 * 23312624
u_str ESTAB 0 0 * 17026726 * 17026728
u_str ESTAB 0 0 /var/run/dovecot/anvil-auth-penalty 10022319 * 10023392
u_str ESTAB 0 0 * 25709616 * 25709617
u_str ESTAB 0 0 /var/run/dovecot/config 24763776 * 24763091
u_str ESTAB 0 0 /var/run/dovecot/anvil 22698191 * 22698187
u_str ESTAB 0 0 * 21231877 * 21231876
u_str ESTAB 0 0 * 12939933 * 12939934
u_str ESTAB 0 0 /var/run/dovecot/login/login 25642205 * 25643268
u_str ESTAB 0 0 * 26362031 * 26362033
u_str ESTAB 0 0 * 10022303 * 10023378
u_str ESTAB 0 0 * 26239771 * 26239773
u_str ESTAB 0 0 * 25229578 * 25228602
u_str ESTAB 0 0 * 26361235 * 26361234
u_str ESTAB 0 0 * 10023370 * 10023424
u_str ESTAB 0 0 /var/run/dovecot/anvil 25708998 * 25708478
u_str ESTAB 0 0 /var/run/dovecot/config 23981674 * 23981671
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 23432042 * 23432040
u_str ESTAB 0 0 * 25643229 * 25642170
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 22725422 * 22726171
u_str ESTAB 0 0 * 22725387 * 22725388
u_str ESTAB 0 0 * 22725373 * 22725374
u_str ESTAB 0 0 * 22726114 * 22726118
u_str ESTAB 0 0 /var/run/dovecot/anvil 22723226 * 22724533
u_str ESTAB 0 0 * 23311772 * 23311774
u_str ESTAB 0 0 * 10023389 * 10022318
u_str ESTAB 0 0 * 25292879 * 25292880
u_str ESTAB 0 0 /var/run/dovecot/anvil 24763104 * 24763101
u_str ESTAB 0 0 /var/run/dovecot/login/login 10023424 * 10023370
u_str ESTAB 0 0 * 10023206 * 10023274
u_str ESTAB 0 0 * 21870134 * 21870137
u_str ESTAB 0 0 * 25699272 * 25699878
u_str ESTAB 0 0 * 10023338 * 10023409
u_str ESTAB 0 0 * 26361238 * 26361237
u_str ESTAB 0 0 /var/run/dovecot/login/login 10023397 * 10023305
u_str ESTAB 0 0 /var/run/dovecot/anvil 10023382 * 10023365
u_str ESTAB 0 0 /var/run/dovecot/config 25699273 * 25699271
u_str ESTAB 0 0 * 25292914 * 25292915
u_str ESTAB 0 0 /var/run/dovecot/config 24242541 * 24243334
u_str ESTAB 0 0 * 22726108 * 22726110
u_str ESTAB 0 0 * 22724530 * 22723225
u_str ESTAB 0 0 * 26361980 * 26361982
u_str ESTAB 0 0 /var/run/dovecot/config 26361938 * 26361936
u_str ESTAB 0 0 * 25640514 * 25641494
u_str ESTAB 0 0 * 24763092 * 24763773
u_str ESTAB 0 0 * 19731117 * 19730383
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 25641494 * 25640514
u_str ESTAB 0 0 /var/run/dovecot/anvil 25699879 * 25699274
u_str ESTAB 0 0 * 25642165 * 25642167
u_str ESTAB 0 0 * 25291746 * 25291745
u_str ESTAB 0 0 * 22726107 * 22726112
u_str ESTAB 0 0 /var/run/dovecot/anvil 26035666 * 26034451
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 26035664 * 26034449
u_str ESTAB 0 0 /var/run/dovecot/anvil 25229597 * 25229594
u_str ESTAB 0 0 * 23432075 * 23432074
u_str ESTAB 0 0 /var/run/dovecot/anvil 26362020 * 26362017
u_str ESTAB 0 0 /var/run/dovecot/anvil 26361215 * 26361212
u_str ESTAB 0 0 * 25709649 * 25709650
u_str ESTAB 0 0 /var/run/dovecot/config 22699231 * 22698184
u_str ESTAB 0 0 * 25708478 * 25708998
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 25708477 * 25708997
u_str ESTAB 0 0 /var/run/dovecot/config 25708510 * 25709010
u_str ESTAB 0 0 * 25291745 * 25291746
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 24243341 * 24243335
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 22724532 * 22724531
u_str ESTAB 0 0 * 10023350 * 10023374
u_str ESTAB 0 0 /var/run/dovecot/config 26239773 * 26239771
u_str ESTAB 0 0 * 25709617 * 25709616
u_str ESTAB 0 0 * 10023368 * 10023384
u_str ESTAB 0 0 * 10023303 * 10023318
u_str ESTAB 0 0 /var/run/dovecot/config 25709003 * 25709000
u_str ESTAB 0 0 * 25708898 * 25708900
u_str ESTAB 0 0 * 23981672 * 23981673
u_str ESTAB 0 0 /var/run/dovecot/config 21870137 * 21870134
u_str ESTAB 0 0 /var/run/dovecot/config 25642170 * 25643229
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 23402232 * 23402866
u_str ESTAB 0 0 * 22726171 * 22725422
u_str ESTAB 0 0 /var/run/dovecot/login/login 26034454 * 26034453
u_str ESTAB 0 0 * 25228599 * 25228600
u_str ESTAB 0 0 * 23432074 * 23432075
u_str ESTAB 0 0 * 16991 * 16992
u_str ESTAB 0 0 * 26361234 * 26361235
u_str ESTAB 0 0 /var/run/dovecot/login/login 26361945 * 26361214
u_str ESTAB 0 0 * 23431151 * 23432108
u_str ESTAB 0 0 * 22698187 * 22698191
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 25708485 * 25709001
u_str ESTAB 0 0 * 25643268 * 25642205
u_str ESTAB 0 0 * 23431994 * 23431998
u_str ESTAB 0 0 * 14657277 * 14657276
u_str ESTAB 0 0 * 12939931 * 12939930
u_str ESTAB 0 0 * 25709011 * 25708501
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 25642171 * 25643230
u_str ESTAB 0 0 * 23402866 * 23402232
u_str ESTAB 0 0 * 10022268 * 10023329
u_str ESTAB 0 0 * 26361936 * 26361938
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 24816046 * 24815106
u_str ESTAB 0 0 /var/run/dovecot/login/login 10023422 * 10023367
u_str ESTAB 0 0 /var/run/dovecot/anvil 10023319 * 10023306
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 10023274 * 10023206
u_str ESTAB 0 0 /var/run/dovecot/config 19731118 * 19731116
u_str ESTAB 0 0 * 25709010 * 25708510
u_str ESTAB 0 0 * 25699274 * 25699879
u_str ESTAB 0 0 * 25291749 * 25291750
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 25291729 * 25292886
u_str ESTAB 0 0 /var/run/dovecot/config 23402231 * 23402865
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 22725374 * 22725373
u_str ESTAB 0 0 * 25640513 * 25640516
u_str ESTAB 0 0 * 26361214 * 26361945
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 22698186 * 22698185
u_str ESTAB 0 0 * 25708480 * 25708999
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 23981673 * 23981672
u_str ESTAB 0 0 * 23432072 * 23432071
u_str ESTAB 0 0 * 10023365 * 10023382
u_str ESTAB 0 0 /var/run/dovecot/config 10022220 * 10023188
u_str ESTAB 0 0 * 25535509 * 25535513
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 22725388 * 22725387
u_str ESTAB 0 0 /var/run/dovecot/anvil 22726118 * 22726114
u_str ESTAB 0 0 * 26034453 * 26034454
u_str ESTAB 0 0 * 25229594 * 25229597
u_str ESTAB 0 0 * 25228600 * 25228599
u_str ESTAB 0 0 * 10023392 * 10022319
u_str ESTAB 0 0 /var/run/dovecot/config 26361210 * 26361208
u_str ESTAB 0 0 * 24763101 * 24763104
u_str ESTAB 0 0 * 22698185 * 22698186
u_str ESTAB 0 0 * 25709636 * 25709637
u_str ESTAB 0 0 * 23432078 * 23432079
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 25709096 * 25709094
u_str ESTAB 0 0 * 25699271 * 25699273
u_str ESTAB 0 0 * 25643230 * 25642171
u_str ESTAB 0 0 * 25292915 * 25292914
u_str ESTAB 0 0 * 22725370 * 22725369
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 22726110 * 22726108
u_str ESTAB 0 0 * 22724533 * 22723226
u_str ESTAB 0 0 /var/run/dovecot/anvil 10023341 * 10023336
u_str ESTAB 0 0 * 24243334 * 24242541
u_str ESTAB 0 0 * 23432071 * 23432072
u_str ESTAB 0 0 /var/run/dovecot/config 23311774 * 23311772
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 26361211 * 26361209
u_str ESTAB 0 0 * 25709650 * 25709649
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 24763773 * 24763092
u_str ESTAB 0 0 * 22698184 * 22699231
u_str ESTAB 0 0 * 12939934 * 12939933
u_str ESTAB 0 0 /var/run/dovecot/anvil 10023384 * 10023368
u_str ESTAB 0 0 * 25709001 * 25708485
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 10023257 * 10023189
u_str ESTAB 0 0 /var/run/dovecot/anvil 25535513 * 25535509
u_str ESTAB 0 0 * 24243335 * 24243341
u_str ESTAB 0 0 * 22724531 * 22724532
u_str ESTAB 0 0 * 26239772 * 26240064
u_str ESTAB 0 0 * 26361209 * 26361211
u_str ESTAB 0 0 * 26361937 * 26361939
u_str ESTAB 0 0 * 25709619 * 25709620
u_str ESTAB 0 0 /var/run/dovecot/anvil 10023318 * 10023303
u_str ESTAB 0 0 * 10023189 * 10023257
u_str ESTAB 0 0 * 25642160 * 25643227
u_str ESTAB 0 0 * 23402865 * 23402231
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 26361939 * 26361937
u_str ESTAB 0 0 * 10023305 * 10023397
u_str ESTAB 0 0 * 25709000 * 25709003
u_str ESTAB 0 0 * 19731116 * 19731118
u_str ESTAB 0 0 * 14657276 * 14657277
u_str ESTAB 0 0 * 12939930 * 12939931
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 25708501 * 25709011
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 25699878 * 25699272
u_str ESTAB 0 0 * 23402867 * 23402870
u_str ESTAB 0 0 /var/run/dovecot/config 22723225 * 22724530
u_str ESTAB 0 0 * 10023336 * 10023341
u_str ESTAB 0 0 /var/run/dovecot/anvil 10023329 * 10022268
u_str ESTAB 0 0 /run/systemd/journal/stdout 16992 * 16991
u_str ESTAB 0 0 * 26361208 * 26361210
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 25709671 * 25709670
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 25474891 * 25474889
u_str ESTAB 0 0 * 25292880 * 25292879
u_str ESTAB 0 0 /var/run/dovecot/anvil 23431998 * 23431994
u_str ESTAB 0 0 * 25292886 * 25291729
u_str ESTAB 0 0 * 22725379 * 22725380
u_str ESTAB 0 0 /var/run/dovecot/config 22726112 * 22726107
u_str ESTAB 0 0 /var/run/dovecot/login/login 10023409 * 10023338
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 10022318 * 10023389
u_str ESTAB 0 0 * 26361212 * 26361215
u_str ESTAB 0 0 * 10023367 * 10023422
u_str ESTAB 0 0 * 10023306 * 10023319
u_str ESTAB 0 0 * 26034436 * 26035583
u_str ESTAB 0 0 /var/run/dovecot/anvil 25723544 * 25723541
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 25291750 * 25291749
u_str ESTAB 0 0 * 13577 * 14680
u_str ESTAB 0 0 * 25708884 * 25708885
u_str ESTAB 0 0 * 25708357 * 25708360
u_str ESTAB 0 0 * 10022179 * 10023264
u_str ESTAB 0 0 * 14675 * 14677
u_str ESTAB 0 0 * 25569072 * 25569073
u_str ESTAB 0 0 /var/run/dovecot/login/login 10023406 * 10022279
u_str ESTAB 0 0 /var/run/dovecot/config 25640527 * 25641499
u_str ESTAB 0 0 * 24763760 * 24763083
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 14607923 * 14607921
u_str ESTAB 0 0 * 10023205 * 10022238
u_str ESTAB 0 0 /var/run/dovecot/anvil 25641514 * 25641511
u_str ESTAB 0 0 /var/run/dovecot/auth-userdb 22843159 * 22843158
u_str ESTAB 0 0 * 22710206 * 22710207
u_str ESTAB 0 0 /var/run/dovecot/login/login 10023400 * 10023314
u_str ESTAB 0 0 /var/run/dovecot/config 25643264 * 25643261
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 25251864 * 25251863
u_str ESTAB 0 0 * 25228614 * 25228613
u_str ESTAB 0 0 * 23431095 * 23431096
u_str ESTAB 0 0 * 22725380 * 22725379
u_str ESTAB 0 0 * 10022279 * 10023406
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 25709705 * 25709703
u_str ESTAB 0 0 /var/run/dovecot/anvil 24763099 * 24763777
u_str ESTAB 0 0 /var/run/dovecot/anvil 23328711 * 23329342
u_str ESTAB 0 0 * 10022271 * 10023331
u_str ESTAB 0 0 * 25641511 * 25641514
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 25293058 * 25293057
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 25229525 * 25229524
u_str ESTAB 0 0 * 22843158 * 22843159
u_str ESTAB 0 0 /var/run/dovecot/login/login 10023401 * 10023317
u_str ESTAB 0 0 * 25708353 * 25708356
u_str ESTAB 0 0 * 24009006 * 24009005
u_str ESTAB 0 0 * 19731461 * 19731464
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 10023266 * 10022181
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 14531125 * 14531121
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 25708885 * 25708884
u_str ESTAB 0 0 * 25641500 * 25641502
u_str ESTAB 0 0 * 23432085 * 23432086
u_str ESTAB 0 0 /var/run/dovecot/config 14607922 * 14607920
u_str ESTAB 0 0 /var/run/dovecot/config 26362016 * 26362013
u_str ESTAB 0 0 * 26219481 * 26220464
u_str ESTAB 0 0 * 26034447 * 26035663
u_str ESTAB 0 0 * 25709094 * 25709096
u_str ESTAB 0 0 * 10022270 * 10023403
u_str ESTAB 0 0 /var/run/dovecot/anvil 10023322 * 10023315
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 26361982 * 26361980
u_str ESTAB 0 0 /var/run/dovecot/config 25708356 * 25708353
u_str ESTAB 0 0 * 25643261 * 25643264
u_str ESTAB 0 0 * 10022181 * 10023266
u_str ESTAB 0 0 /run/systemd/journal/stdout 14677 * 14675
u_str ESTAB 0 0 /var/run/dovecot/anvil 25708301 * 25708297
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 26362015 * 26362014
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 26035583 * 26034436
u_str ESTAB 0 0 * 25723540 * 25724507
u_str ESTAB 0 0 * 13345 * 13344
u_str ESTAB 0 0 * 25708519 * 25708535
u_str ESTAB 0 0 * 10022305 * 10023418
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 25293888 * 25293066
u_str ESTAB 0 0 * 25251866 * 25251870
u_str ESTAB 0 0 /run/dbus/system_bus_socket 14709 * 13586
u_str ESTAB 0 0 * 25293057 * 25293058
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 23432086 * 23432085
u_str ESTAB 0 0 * 14607921 * 14607923
u_str ESTAB 0 0 * 10023203 * 10022236
u_str ESTAB 0 0 /var/run/dovecot/anvil 26035662 * 26034445
u_str ESTAB 0 0 * 25709012 * 25708511
u_str ESTAB 0 0 * 25229523 * 25229526
u_str ESTAB 0 0 * 24009836 * 24009835
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 10023269 * 10022183
u_str ESTAB 0 0 * 25569073 * 25569072
u_str ESTAB 0 0 * 25293066 * 25293888
u_str ESTAB 0 0 /var/run/dovecot/anvil 25251870 * 25251866
u_str ESTAB 0 0 /run/systemd/journal/stdout 22042 * 22041
u_str ESTAB 0 0 * 13586 * 14709
u_str ESTAB 0 0 * 25709702 * 25709704
u_str ESTAB 0 0 * 21231876 * 21231877
u_str ESTAB 0 0 * 14607920 * 14607922
u_str ESTAB 0 0 * 14162 * 14163
u_str ESTAB 0 0 /var/run/dovecot/config 25724506 * 25723539
u_str ESTAB 0 0 * 25229527 * 25229531
u_str ESTAB 0 0 * 10023315 * 10023322
u_str ESTAB 0 0 /var/run/dovecot/anvil 25708541 * 25708517
u_str ESTAB 0 0 /var/run/dovecot/config 25708886 * 25708883
u_str ESTAB 0 0 * 25708354 * 25708355
u_str ESTAB 0 0 /var/run/dovecot/config 22710208 * 22710205
u_str ESTAB 0 0 /var/run/dovecot/config 10022233 * 10022182
u_str ESTAB 0 0 * 14706 * 14707
u_str ESTAB 0 0 * 25228613 * 25228614
u_str ESTAB 0 0 /var/run/dovecot/config 23431071 * 23431992
u_str ESTAB 0 0 /var/run/dovecot/anvil 10023374 * 10023350
u_str ESTAB 0 0 /var/run/dovecot/config 25709704 * 25709702
u_str ESTAB 0 0 /run/dbus/system_bus_socket 14163 * 14162
u_str ESTAB 0 0 * 26362014 * 26362015
u_str ESTAB 0 0 * 26034435 * 26035584
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 10023261 * 10022175
u_str ESTAB 0 0 * 26361940 * 26361943
u_str ESTAB 0 0 * 25708883 * 25708886
u_str ESTAB 0 0 * 25708346 * 25708852
u_str ESTAB 0 0 * 23311775 * 23311779
u_str ESTAB 0 0 * 14531120 * 14531123
u_str ESTAB 0 0 * 10022072 * 10021873
u_str ESTAB 0 0 /var/run/dovecot/anvil 25708890 * 25708887
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 25641502 * 25641500
u_str ESTAB 0 0 /var/run/dovecot/config 25292833 * 25291641
u_str ESTAB 0 0 * 14657185 * 14657186
u_str ESTAB 0 0 * 26362017 * 26362020
u_str ESTAB 0 0 /var/run/dovecot/config 26035584 * 26034435
u_str ESTAB 0 0 * 25723543 * 25723545
u_str ESTAB 0 0 * 25293885 * 25293886
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 22710207 * 22710206
u_str ESTAB 0 0 * 10023325 * 10023402
u_str ESTAB 0 0 /var/run/dovecot/config 10022224 * 10023191
u_str ESTAB 0 0 * 10022182 * 10022233
u_str ESTAB 0 0 * 25709666 * 25709667
u_str ESTAB 0 0 * 24531294 * 24531297
u_str ESTAB 0 0 /var/run/dovecot/anvil 14531131 * 14531128
u_str ESTAB 0 0 * 25709620 * 25709619
u_str ESTAB 0 0 /var/run/dovecot/anvil 25642166 * 25642163
u_str ESTAB 0 0 * 25641499 * 25640527
u_str ESTAB 0 0 /var/run/dovecot/config 10022238 * 10023205
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 25724507 * 25723540
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 14657192 * 14657189
u_str ESTAB 0 0 * 22710205 * 22710208
u_str ESTAB 0 0 * 17026727 * 17026729
u_str ESTAB 0 0 /var/run/dovecot/login/login 10023408 * 10022285
u_str ESTAB 0 0 /var/run/dovecot/config 10022228 * 10022178
u_str ESTAB 0 0 * 14707 * 14706
u_str ESTAB 0 0 * 23431993 * 23431073
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 25642162 * 25642161
u_str ESTAB 0 0 /var/run/dovecot/anvil 10023388 * 10022315
u_str ESTAB 0 0 /var/run/dovecot/login/login 25723545 * 25723543
u_str ESTAB 0 0 * 25229524 * 25229525
u_str ESTAB 0 0 /var/run/dovecot/login/login 10023402 * 10023325
u_str ESTAB 0 0 /var/run/dovecot/anvil 25708360 * 25708357
u_str ESTAB 0 0 /var/run/dovecot/anvil 10023378 * 10022303
u_str ESTAB 0 0 /var/run/dovecot/anvil 10023340 * 10022283
u_str ESTAB 0 0 * 10022183 * 10023269
u_str ESTAB 0 0 * 25640708 * 25640711
u_str ESTAB 0 0 * 23431992 * 23431071
u_str ESTAB 0 0 * 22725418 * 22725419
u_str ESTAB 0 0 /run/systemd/journal/stdout 10021873 * 10022072
u_str ESTAB 0 0 * 25708297 * 25708301
u_str ESTAB 0 0 * 25291641 * 25292833
u_str ESTAB 0 0 /var/run/dovecot/anvil 23311779 * 23311775
u_str ESTAB 0 0 * 10022315 * 10023388
u_str ESTAB 0 0 * 10023200 * 10023268
u_str ESTAB 0 0 * 26034445 * 26035662
u_str ESTAB 0 0 * 25723541 * 25723544
u_str ESTAB 0 0 * 25293042 * 25293044
u_str ESTAB 0 0 * 24531295 * 24531296
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 23312624 * 23311773
u_str ESTAB 0 0 * 10023317 * 10023401
u_str ESTAB 0 0 * 25708517 * 25708541
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 25708355 * 25708354
u_str ESTAB 0 0 /var/run/dovecot/anvil 25643269 * 25643266
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 23432108 * 23431151
u_str ESTAB 0 0 * 10022283 * 10023340
u_str ESTAB 0 0 /var/run/dovecot/login/login 25709710 * 25709708
u_str ESTAB 0 0 * 24763091 * 24763776
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 23431073 * 23431993
u_str ESTAB 0 0 /var/run/dovecot/login/login 10023414 * 10023352
u_str ESTAB 0 0 * 25642161 * 25642162
u_str ESTAB 0 0 * 24763777 * 24763099
u_str ESTAB 0 0 /var/run/dovecot/anvil 14607927 * 14607924
u_str ESTAB 0 0 * 10022317 * 10023427
u_str ESTAB 0 0 /var/run/dovecot/config 10022236 * 10023203
u_str ESTAB 0 0 * 25293886 * 25293885
u_str ESTAB 0 0 * 24009835 * 24009836
u_str ESTAB 0 0 /var/run/dovecot/anvil 10023326 * 10023323
u_str ESTAB 0 0 * 10023191 * 10022224
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 25708852 * 25708346
u_str ESTAB 0 0 * 24009005 * 24009006
u_str ESTAB 0 0 /var/run/dovecot/anvil 19731464 * 19731461
u_str ESTAB 0 0 * 10022178 * 10022228
u_str ESTAB 0 0 * 23431147 * 23431146
u_str ESTAB 0 0 * 22725419 * 22725418
u_str ESTAB 0 0 /var/run/dovecot/anvil 24763083 * 24763760
u_str ESTAB 0 0 /var/run/dovecot/login/login 10023427 * 10022317
u_str ESTAB 0 0 /var/run/dovecot/anvil 10023331 * 10022271
u_str ESTAB 0 0 * 10023204 * 10023272
u_str ESTAB 0 0 * 25723539 * 25724506
u_str ESTAB 0 0 /var/run/dovecot/anvil 25229531 * 25229527
u_str ESTAB 0 0 * 14657189 * 14657192
u_str ESTAB 0 0 * 10023314 * 10023400
u_str ESTAB 0 0 * 10022285 * 10023408
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 10023264 * 10022179
u_str ESTAB 0 0 /var/run/dovecot/config 25640711 * 25640708
u_str ESTAB 0 0 /var/run/dovecot/config 14531123 * 14531120
u_str ESTAB 0 0 * 22041 * 22042
u_str ESTAB 0 0 /run/systemd/journal/stdout 14805 * 13681
u_str ESTAB 0 0 * 25642163 * 25642166
u_str ESTAB 0 0 * 25291642 * 25292835
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 16383292 * 16382788
u_str ESTAB 0 0 * 14657186 * 14657185
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 10023272 * 10023204
u_str ESTAB 0 0 /var/run/dovecot/config 25229526 * 25229523
u_str ESTAB 0 0 /var/run/dovecot/config 24531297 * 24531294
u_str ESTAB 0 0 * 10023192 * 10023260
u_str ESTAB 0 0 * 24815106 * 24816046
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 17026729 * 17026727
u_str ESTAB 0 0 /var/run/dovecot/config 10022230 * 10022180
u_str ESTAB 0 0 * 23431096 * 23431095
u_str ESTAB 0 0 * 14531128 * 14531131
u_str ESTAB 0 0 * 10023352 * 10023414
u_str ESTAB 0 0 * 13681 * 14805
u_str ESTAB 0 0 * 14607924 * 14607927
u_str ESTAB 0 0 * 26362013 * 26362016
u_str ESTAB 0 0 /var/run/dovecot/anvil 26220464 * 26219481
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 24531296 * 24531295
u_str ESTAB 0 0 * 10023323 * 10023326
u_str ESTAB 0 0 * 13344 * 13345
u_str ESTAB 0 0 /var/run/dovecot/login/login 10023418 * 10022305
u_str ESTAB 0 0 * 10022180 * 10022230
u_str ESTAB 0 0 * 25709184 * 25709679
u_str ESTAB 0 0 * 14531121 * 14531125
u_str ESTAB 0 0 * 25709703 * 25709705
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 25292835 * 25291642
u_str ESTAB 0 0 /var/run/dovecot/stats-writer 10023268 * 10023200
Top Memory Usage:
mysql 23818 5.9 28.9 3962392 1970116 ? Ssl 18:45 15:48 /usr/sbin/mysqld
root 1384 0.1 10.9 1165524 744084 ? Ssl Sep03 5:16 /usr/local/sbin/clamd --foreground=yes
root 3125 0.3 8.1 1496504 554652 ? Rl Sep03 18:43 /usr/local/sphinx-3.1.1/bin/searchd --config /usr/local/sphinx-3.1.1/etc/sphinx.conf
root 32056 0.0 3.1 293764 212248 ? Ss 17:03 0:00 nginx: master process /usr/sbin/nginx -c /etc/nginx/nginx.conf
nginx 1135 7.3 3.1 293768 214476 ? S 17:04 27:07 nginx: worker process
nginx 1134 7.1 3.1 293768 214440 ? S 17:04 26:23 nginx: worker process
memcach+ 30377 0.1 1.6 454244 112612 ? Ssl Sep05 4:44 /usr/bin/memcached -u memcached -p 11211 -m 128 -c 512 -l 127.0.0.1, -U 0
apache 12795 13.5 0.4 2555356 28720 ? Sl 22:58 1:48 /usr/sbin/httpd -DFOREGROUND
root 22572 0.3 0.3 172340 23860 ? Ss 00:00 4:20 lfd - sleeping
apache 13992 11.6 0.3 2423408 22180 ? Sl 23:03 1:01 /usr/sbin/httpd -DFOREGROUND
Virtual Memory Info:
procs -----------------------memory---------------------- ---swap-- -----io---- -system-- --------cpu-------- -----timestamp-----
r b swpd free buff cache si so bi bo in cs us sy id wa st CEST
4 0 287724 168736 213032 2681292 1 1 445 703 16 31 16 5 74 5 0 2019-09-06 23:12:03
3 1 287724 177296 213156 2681780 0 0 488 2208 8263 31010 34 12 51 3 0 2019-09-06 23:12:04
0 1 287724 174828 213252 2683060 0 0 996 1532 8217 21981 32 9 55 5 0 2019-09-06 23:12:05
Automated Message Generated by DirectAdmin 1.58.2
