Message Notification not being sent
uvhost
UK
hi,
even though i have email set here (which i have removed while taking screenshot)
https://prnt.sc/p74x4d
DirectAdmin is not sending me message notifications (like bruteforce and load etc) in my email.
Any idea why?
Have a look at /usr/local/directadmin/conf/directadmin.conf and check if:
hide_brute_force_notifications=0
This should be the default value, but if it's present and set to 1, you won't receive these notifications either.
Also check your exim logs to see if there are attempts to send them out.
In /usr/local/directadmin/conf/directadmin.conf
there is no hide_brute_force_notifications=0 or hide_brute_force_notifications=1
should i add it?
i have the latest Directadmin installed.
should i add it?
The default value is 0 so in that case it should not be necessary to add it.
But it can't do any harm either, so you can give it a try.
Remember to restart Directadmin afterwards. If that's not helping, then maybe somebody else can help.
