- Feb 27, 2003
DirectAdmin 1.59.4 has been released.
This is a bug-fix release to fix a few things and help remove confusion in other areas.
All changes are listed on the versions page:
https://www.directadmin.com/versions.php?version=1.594000
Sudden Reseller Bandwidth increase:
If you noticed a spike in Reseller Bandwith, this is related to a recent fix in DA 1.59.
However, there are 2 scenarios in the amount of that spike.
If you are or were using OpenLiteSpeed, there used to be a bug where it would log incorrect data to the bandwidth count.
DA has extra checks to filter that out, but some Users may have had higher than expected data.
This logging should be solved a while ago, but the Reseller BW spike relates to DA now counting old User bandwidth which were deleted within the month.
A smaller spike might be correct, in that that Users BW used is now counted as it should be.
But a higher spike falls in that same category, but could be showing the very high usage as counted by the bad bw logged from the OLS bug in the past.
More info on what to check is listed here:
https://forum.directadmin.com/showthread.php?t=59281&p=303471#post303471
If you're unsure what to do, and simply don't care about any deleted User data, simply kill all "old deleted User bandwidth" data and run the bw tally, eg:
which would bring you back to your previous total, BUT might be wrong count, lower than it should be, if you were never using OLS.. but just deletes that previous BW anyway.
Other changes:
Bugfixes:
Sorry for the larger than normal number of releases, but we feel it's better to fix and get things out
cd /usr/local/directadmin
rm -f data/users/*/bandwidth.reseller.tally
echo 'action=bandwidthtally&value=all' >> data/task.queue; ./dataskq d432
Other changes:
- Hide login-as IP from the client
- Show the deleted User bandwidth to help avoid confusion with regards to the DA fix
Bugfixes:
- Unable to delete MX records from MX Records page
- FreeBSD; ssh keys unable to get fingerprint
- Include force_ssl and force_redirect in restores
- Allow :123 port to be appeneded to host in referer_check.allow override file
- Allow older curl versions to still work with FTPS backup uploads
