CustomBuild versions - more detail
sparek
I think it would be beneficial if
/usr/local/directadmin/custombuild/build versions
Would include the specific option to pass to CustomBuild to compile that option.
For example, an update to Nghttp2 recently became available
Nghttp2 1.39.2 to 1.40.0 update is available.
But listing:
/usr/local/directadmin/custombuild/build help
I wasn't able to come up with what to pass to build in order to upgrade this.
I had to scour through the source of /usr/local/directadmin/custombuild/build to figure out that it was:
/usr/local/directadmin/custombuild/build nghttp2
I think an improvement could be made if
would list this as:
Nghttp2 1.39.2 to 1.40.0 update is available. - nghttp2
Do this for every option in CustomBuild, so we'd know to pass
/usr/local/directadmin/custombuild/build xxxxxx
To rebuild/upgrade xxxxxx
Run
to see all options available. There you’ll likely find the functionality you seek. :)
The following is also available, if you prefer JSON format:
Bash:
/usr/local/directadmin/custombuild/build versions_json
Run
Well... I mean, the point kind of was that nghttp2 is not listed there. I'm not sure if there are others that are missing or not.
/usr/local/directadmin/custombuild/build | grep nghttp2
/usr/local/directadmin/custombuild/build help | grep nghttp2
But yet, in order to recompile Nghttp2 the correct parameter to pass is:
How is one suppose to know that Nghttp2 is referred to as nghttp2? Without reading through the source of /usr/local/directadmin/custombuild/build
(although... actually now as I read that, it's kind of one of those "duh!" moments. But still, I think all of this could be better informed)
Bash:
This returns an empty set for me. Might this be because all of my versions are up-to-date now?
