Regarding Brute Force Attack
anuragjyoti
Hello
I am new to Direct Admin Panel. I have recently purchased from my hosting company Direct Admin panel the thing is I am continuously getting message of Brute Force Attack do we have anything like cphulk in Direct Admin panel
I even blocked some ips but still its the same.
Thanks for the reply but csf is already installed on our server
Secondly the bruteforce attack is for exim and phpmyadmin3.
what can be done?
hi vmaker
I tried to follow above link
wget -O csf-bfm-install.sh https://raw.githubusercontent.com/poralix/directadmin-bfm-csf/master/install.sh
--2019-11-26 06:17:15-- https://raw.githubusercontent.com/poralix/directadmin-bfm-csf/master/install.sh
Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 151.101.0.133, 151.101.64.133, 151.101.128.133, ...
Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|151.101.0.133|:443... connected.
Length: 7337 (7.2K) [text/plain]
Saving to: ‘csf-bfm-install.sh’
100%[===================================================================================================================================================>] 7,337 --.-K/s in 0s
2019-11-26 06:17:15 (74.5 MB/s) - ‘csf-bfm-install.sh’ saved [7337/7337]
[user ~]$ chmod 700 csf-bfm-install.sh
[user~]$ ./csf-bfm-install.sh
[NOTICE] CSF/LFD was not found on your server! Going to install it...
csf.tgz: Permission denied
tar (child): csf.tgz: Cannot open: No such file or directory
tar (child): Error is not recoverable: exiting now
tar: Child returned status 2
tar: Error is not recoverable: exiting now
[ERROR] CSF/LFD failed to unpack! Terminating... echo
Hi Vmaker
I tried all the step in above yrl
But yet there are lot of notification for brute forcce attack
Depending on the frequency of how hard your accounts are getting hit, and how many differing ips, look into "fail2ban" also
You dont have CSF installed properly, I advise to install it first manual to avoid problems
