Install OpenLiteSpeed
staff
France
I would like to install OpenLiteSpeed and I would like to know if the rewrite mod and the htaccess files are compatible?
I currently install versions of PHP 7.3, 7.2, 7.1, 7.0 (PHP-FPM) and as a web server nginx_apache
Is there a big difference between nginx_apache and OpenLiteSpeed for speed?
How to access the Webadmin console?
I wanted to test installing OpenLiteSpeed so I changed PHP-FPM from PHP versions to LSPHP and I wanted to install OpenLiteSpeed and I got an error saying:
openlitespeed webserver configuration option is not compatible with lsphp or php-fastcgi PHP mode with mod_ruid2 enabled.
Thank you
Yeah only mod rewrite is available
You cant access web admin console
Disable mod
_ruid2 during installation
./build clean
./build set webserver openlitespeed
./build set mod_ruid2 no
./build set php1_mode lsphp
./build openlitespeed
./build php
./build rewrite_confs
You can access webadmin as long as you install libnsl otherwise you get a 503 error.
The webadmin is read-only so you need to edit config files direct
speed wise. dont play with the config unless you know what you are doing. if your website/application can use their cache plugin IE wordpress then do so.
