I think you’re talking about DNS changes, right?
After I changed the username max lenght now I get this error;
tar: The following options were used after any non-optional arguments in archive create or update mode. These options are positional and affect only arguments that follow them. Please, rearrange them properly.
tar: --exclude ‘cpbackup-exclude.conf’ has no effect
tar: --exclude ‘.cphorde’ has no effect
tar: --exclude ‘.gemrc’ has no effect
tar: --exclude ‘.contactemail’ has no effect
tar: --exclude ‘.lastlogin’ has no effect
tar: --exclude ‘.cpanel’ has no effect
tar: --exclude ‘tmp’ has no effect
tar: --exclude ‘ssl’ has no effect
tar: --exclude ‘logs’ has no effect
tar: --exclude ‘.zshrc’ has no effect
tar: --exclude ‘.cpaddons’ has no effect
tar: --exclude ‘cpanel3-skel’ has no effect
tar: Exiting with failure status due to previous errors
WARNING! i6306362_wp1 cannot be owned by dbo7ghligyzz, renaming database user to dbo7ghligyzz_wp1
Trying to find files in public_html to rename i6306362_wp1 to dbo7ghligyzz_wp1. A copy of the file will have '.cpanel_backup_copy_dbname.php' appended at the end.
/home/admin/user_backups/dbo7ghligyzz/domains/upscalereps.com/public_html/wp-config.php
WARNING! i6306362_wp1 username cannot be owned by dbo7ghligyzz, renaming database user to dbo7ghligyzz_wp1
Trying to find files in public_html to rename i6306362_wp1 to dbo7ghligyzz_wp1. A copy of the file will have '.cpanel_backup_copy.php' appended at the end.
Cannot find creator 'gdresell' when restoring 'user.gdresell.dbo7ghligyzz.tar.gz'. Reverting to 'admin'
domain.com already exists on the server.
