CustomBuild 2.0 rev. 2369 with steroids
smtalk
Administrator
Staff member
LT, EU
CB 2.0 rev. 2369 has been released. It's a huge release for developers :) As it now lets you overwrite any call, execute pre/post hooks etc. For example, you could now:
1) create "./build varnish" or just overwrite regular "./build apache" call with whatever you want by using pre-call hook and 'exiting' at the end
2) execute anything before/after CustomBuild command, for example, after update_versions you could mail yourself/server-owner a message that updates have been applied
All CustomBuild variables are reachable in 'hooks', structure is /usr/local/directadmin/custombuild/custom/hooks/command/pre/anything.sh (pre could be post as well), for example, you could try custom/hooks/versions/pre/test.sh with the following content:
#!/bin/sh
echo "Oh yeah! My PHP version is ${PHP1_RELEASE_OPT}, and I'm just exiting with a strange error code instead of listing the version updates...."
exit 4
If you'd like to just finish the function, "return" instead of "exit" could be used.
For per-function hooks - if any are needed, just create a ticket/mail us, and they'll be added :)
In addition to this, CB 2.0 rev. 2369 includes update_versions_full, update_full and update_versions full calls, they all do the same:
1) Update OS packages
2) Update CustomBuild and CustomBuild packages
Everything with just a single call.
All that I can say is simply... AWESOME JOB! Thank you! Now it's a peace of cake to apply custom patches when needed.
Regarding "update_full" - we may need some additional info regarding what exactly it does. For example in FreeBSD - is it calling freebsd-update and/or updating all ports?
“pkg -y upgrade” for now.
I think we need some useful examples utilizing this new feature. Like a HOW-TO with practical examples.
i've renamed my default username, when trying to update custombuild i get
chown: invalid group: 'root:admin'
It's not related to the version announced. It can be ignored, unless you have any particular problem with it?
Can I also add a post hook for the cronjob? In addition to the email that's being send when there is a update available, I would like to call a simple command:
/root/pushover-notification/notification.sh "title" "updates that are available"
So that I can also receive Pushover notifications when there are updates available.
Check CB 2.0 rev. 2048:
Added custom/hooks/cron_execute/pre and custom/hooks/cron_execute/post hooks for pre/post execution of the CustomBuild cronjob. "./build cron" is needed to re-generate the cronjob which uses the hooks.
:eek: That's quick, thanks ? One thing; I got an error after ./build update, ./build cron and manually testing the cron:
./custombuild: line 26: syntax error: unexpected end of file
That's because this if isn't closed:
if [ "${AVAIL_UPDATES}" -gt 0 ]; then
After adding
fi
to line 16 it works again. And the hook is working perfectly, now update messages are also send as a push notification (y) :
More info; https://erulezz.dev/directadmin-push-notifications-with-pushover/
Hey.
It looks like a corupted version of file is uploaded on servers.
Please have a look:
[root@s1 custombuild]# ./build version
2.0.0 (rev: 2606)
Another ./build update
Saving to: '/usr/local/directadmin/custombuild/ioncube_loaders_lin_x86-64.tar.gz'
/usr/local/directadmin/custombuild/ 100%[================================================================>]  13.08M  42.4MB/s    in 0.3s
2020-11-27 22:08:04 (42.4 MB/s) - '/usr/local/directadmin/custombuild/ioncube_loaders_lin_x86-64.tar.gz' saved [13714677/13714677]
MD5 Checksum on ioncube_loaders_lin_x86-64.tar.gz passed.
Now it's time for ./build ioncube
*** MD5 Checksum for ioncube_10.4.4/ioncube_loaders_lin_x86-64.tar.gz failed *again*.***
The md5 checksum value may be incorrect, or a wrong file is being downloaded.
Install continuing with this possibly corrupted file. (it may also be fine)
ionCube loader 10.4.4 is now installed for PHP 7.4.
Hey.
Please have a look:
2.0.0 (rev: 2606)
May you try:
./build ioncube
Thank you for the report! It should try installing 10.4.5 now :)
Thanks @smtalk now it's fine:
[root@s1 custombuild]# ./build ioncube
Downloading             ioncube_loaders_lin_x86-64.tar.gz...
--2020-11-27 22:59:34--  https://files-lt.directadmin.com/services/custombuild/ioncube_10.4.5/ioncube_loaders_lin_x86-64.tar.gz
Resolving files-lt.directadmin.com (files-lt.directadmin.com)... 193.46.84.159
Connecting to files-lt.directadmin.com (files-lt.directadmin.com)|193.46.84.159|:443... connected.
Length: 13714677 (13M) [application/octet-stream]
/usr/local/directadmin/custombuild/ 100%[================================================================>]  13.08M  41.4MB/s    in 0.3s
2020-11-27 22:59:35 (41.4 MB/s) - '/usr/local/directadmin/custombuild/ioncube_loaders_lin_x86-64.tar.gz' saved [13714677/13714677]
ionCube loader 10.4.5 is now installed for PHP 7.4.
That was quick!
I asked this before but it was ignored..... When I use this with Evo, my download rate increases when compiling (1.5MB/s shown here, it fluctuates)..... Why? Doesn't make sense?
*Think I posted in the wrong thread.
Yes, it’s a wrong thread. CB does not show any network stats on compilation time, so, you should contact the creator of that software for this question.
I think you missed my point....... What would be downloading when I compile stuff? Enhanced skin is fine, a few kB if that for the text output, but Evo seems to want to rinse my download, especially over 1MB/s ?‍♂️
I do wish JBMC would support Enhanced going forward, or even remove it totally...... Seems we are now forced to use Evo.
How can I add two post hooks for php and exim.conf? I would like a script to run after custombuild updates them.
