ChiefZigZag
 - Feb 17, 2020
I attempted to upgrade from MySQL to MariaDB.. the upgrade to MariaDB 5.5 worked. 10.x doesnt work at all, I tried some options provided from the following post with no luck. Here is where my build keeps stopping on MariaDB 10.4, any ideas?
[ 11%] Building C object plugin/auth_pam/CMakeFiles/pam_user_map.dir/mapper/pam_user_map.c.o
clang: warning: -Wl,-z,relro,-z,now: 'linker' input unused [-Wunused-command-line-argument]
/usr/local/directadmin/custombuild/mariadb-10.4.12/plugin/auth_pam/mapper/pam_user_map.c:42:10: fatal error: 'security/pam_ext.h' file not found
#include <security/pam_ext.h>
1 error generated.
--- plugin/auth_pam/CMakeFiles/pam_user_map.dir/mapper/pam_user_map.c.o ---
*** [plugin/auth_pam/CMakeFiles/pam_user_map.dir/mapper/pam_user_map.c.o] Error code 1
make[2]: stopped in /usr/local/directadmin/custombuild/mariadb-10.4.12
1 error
--- plugin/auth_pam/CMakeFiles/pam_user_map.dir/all ---
*** [plugin/auth_pam/CMakeFiles/pam_user_map.dir/all] Error code 2
make[1]: stopped in /usr/local/directadmin/custombuild/mariadb-10.4.12
A failure has been detected in another branch of the parallel make
--- storage/rocksdb/CMakeFiles/rocksdblib.dir/all ---
*** [storage/rocksdb/CMakeFiles/rocksdblib.dir/all] Error code 2
--- storage/rocksdb/CMakeFiles/rocksdb_tools.dir/all ---
*** [storage/rocksdb/CMakeFiles/rocksdb_tools.dir/all] Error code 2
