You have not given the reseller any IP's. Unable to create an assigned IP domain or any nameservers without any
ChiefZigZag
Unsure why this happens when I attempt to create a reseller with any package it simply does not work. If I click customize however it seems to work fine. Any ideas?
That was a known issue in 1.60.3, just update to pre-release or wait for 1.60.4 which should be out in a couple of days (RC1 already announced).
It appears the problem has regressed on the most recent prerelease build..
Compiled on    FreeBSD 12.0 64-bit
Compile Date    Feb 26 2020, 16:25:08
Server Version    1.60.3
Current Available Version    1.603000
Last Updated    Wed Feb 26 15:26:18 2020
Last Restart    Thu Feb 27 07:44:00 2020
I used to be able to create a custom reseller but since the 1.60.4 release I haven't even been able to do that.
Do you have IPs in the package? As you’re using reseller’s IPs option as far as I see.
Initially it wasn't working..but after trying numerous combination the problem appeared to go away on its own..it was there however and it was impossible to create a reseller. Now it creates every time, odd.
