No matching DirectoryIndex (index.php,index.html) found
rifkytech
Medan, Indonesia
Hello i have some problem, sometime, my client got 503 Service Unvailable, & i found this error on /var/log/httpd/domains/domain.com.error.log
"AH01276: Cannot serve directory /home/dimasaf/domains/domain.com/private_html/: No matching DirectoryIndex (index.php,index.html) found, and server-generated directory index forbidden by Options directive"
and when I reboot the server again, the server returns to normal. whats problem here? i really confused, please help me
i use latest directadmin, and use centOs 7
i use apache2 with php-fpm
If i read it right, it looks for the following files "index.php and index.html" in the home/dimasaf/domains/domain.com/private_html folder (this is the HTTPS folder).
Did the owner of this website copy his site over to your hostingservice?
edit: after a google search i found this:
I believe the error 'No matching DirectoryIndex' is not relative. It's probably because of PHP-FPM hits a limit of max allowed processes. Check what you see there
/usr/local/directadmin/directadmin c | grep -i php_fpm_max_children_default
and in logs /var/log/php-fpm*.log something like server reached pm.max_children setting (30), consider raising it.
yess, how to add size max_children? in my server pm.mac_children only 10
Edit your httpd.conf file. Alex give you a clue for the solution. Just increase that value and restart apache.
You should not edit httpd.conf and it won't help by the way. Run the following as root:
/usr/local/directadmin/directadmin set php_fpm_max_children_default 30
./build rewrite_confs
to set it to 30.
Too big value might bring to issues with high RAM usage and disk IO in case your server is under brute-force attacks. So you need to investigate on why PHP scripts are running slow or hanging....
to set it to 30.
That's true. My mistake
