Imagick update issue
Richard G
Maastricht
Have imagick running on 2 servers. After update to 8.02 this is happening on both servers
PHP Warning:  Version warning: Imagick was compiled against ImageMagick version 1801 but version 1802 is loaded. Imagick will run but may behave surprisingly in Unknown on line 0
How can I fix this?
Seems to be fixed by running:
./build imagick
However, this should not happen on a ./build update_versions on multiple servers, correct?
Seems imagick is gone from options.conf, or is that normal?
[root@server24: /usr/local/directadmin/custombuild]# ./build set imagick yes
Changed imagick option from yes to yes
So let's check options.conf:
[root@server24: /usr/local/directadmin/custombuild]# cat options.conf | grep imag
I also looked in there with nano, it's not to be found.
Maybe that caused the previous issue?
How can I fix this?
./build imagick
Also had this yesterday, that is also what fixed it for me.
In fact "./build imagick" = "./build php_imagick"
And before you probably ran "./build imagemagick"
./build imagick
that give's me :
[root@www custombuild]# ./build imagick
./build: line 11520: /usr/local/php73/bin/php-config: No such file or directory
imagick 3.4.4 PHP extension has been installed successfully.
my problem:
[root@www custombuild]# php -v
PHP 7.3.11 (cli) (built: Dec  2 2019 23:25:50) ( NTS )
Copyright (c) 1997-2018 The PHP Group
Zend Engine v3.3.11, Copyright (c) 1998-2018 Zend Technologies
that give's me :
my problem:
Are you running rev. 2446? Please check ./build version
I think you have PHP 7.3 set as some PHP release enabled, but it's not built. Please check:
ls /usr/local/php73/bin/php*
The following should fix it:
./build php
./build php
ls gives me cannot access not a directory
the build php fixed it , thanks !
