hi guys,
I am testing directadmin, I have a vps on digital ocean, 2vcpu and 4 gb ram using isp config + nginx 1.10.3 + php 7.0.3 + MariaDB 10.1.44 on debian 9.11.
I only have wordpress sites and I am testing 1 on direct admin, this wordpress site is an Ecommerce, Woocommerce + wp rocket using nginx config from satelliteWP/rocket-nginx (I cant put links) + cloudflare + keycdn + aelia currency switcher (thats why the first tyme byte is that high, about 1 sec).
In general the performance is good as you can see on the graph
check the image, the spike between 12:40 and 15:40 is using the same site on direct admin.
is a new droplet with same specs but with direct admin install on it, so it has nginx 1.17.9 + php 7.3.16 + mariadb 10.4.12 on debian 10
I used exact the same config in both, php on demand, ssl on (my own certificate), the site on direct admin is really slow, I even deactivated firewall but the same history, hosting that site on directadmin using the same config increase ttfb in 3 sec average, that is too much, check the image.
I am not seeing something?, there is some special config on this?
greetings
greetings
