itscoffetime
- Sep 19, 2019
I tried but I keep on getting:I took a test with them (DA 8.1), works perfectly
Since jetbackup will not be ready for Centos 8 (for DA) yet, I plan to subscribe to them
I always get the same error:I took a test with them (DA 8.1), works perfectly
If you are using CSF, make sure you have authorized the SSH port in TCP (IN and OUT)I always get the same error:
Could not connect remote host.
Tried with a backup server running Centos and other in Ubintu, same error. Thing is I have tried Jetbackup and it works (but I don't want to use something not finished) and so does manual rsync.It works properly. You can install Ubuntu for the remote backup server.
Contacted support and waiting for a reply
It has been working so good for me as well! kudos to the team!We have been looking at it while testing jet backup. I may have to try it out.
-tried it out and it seems to work great! Easier than JB to install and configure and works with Centos8
