As it's been requested multiple times, let's have a public changelog for CustomBuild 2.0
Revisions skipped means there were minor changes to typos/comments etc.
2945 - Fix download of mime.types file for RoundCube.
2944 - Remove AddEncoding from default Apache configuration.
2943 - Remove freetype/zstd from the components list.
2942 - Fix sysbk download URL.
2941 - Fix majordomo download server.
2940 - Fix php-lsapi extension download.
2939 - Remove mysql_rel from versions.txt.
2938 - Fix missing GZIP_BIN variable in MySQL backup function.
2937 - Take all the extra mysqldump options from directadmin.conf for MySQL backup.
2936 - SymLinksIfOwnerMatch instead of FollowSymlinks use in httpd-directories-old.conf.
2935 - Add missing configure/ directory changes (--with-fpm-systemd in configure.phpXX files).
2934 - Fix rspamd/redis installation order on rspamd installation time.
2933 - Bring PKG_CONFIG_PATH back to doPhp_build() to allow builds with custom libs.
2932 - If /home/mysql is detected - set ProtectHome=false in MySQL/MariaDB startup file.
2931 - Remove EOL OS support. Code cleanup (removed 12.5% of code).
2930 - Make sure /var/lib/mysql always exists.
2929 - Allow installing ionCube for PHP 8.1.
2928 - Fix composer chmod.
2927 - Remove ProtectHome from MySQL/MariaDB systemd startup service file in case data is stored in /home.
2926 - Add missing configure/php/configure.php82 file.
2925 - Fix /usr/sbin/sendmail -> /usr/sbin/exim symlink, ln needed -n flag to fix it.
2924 - Fix Squirrelmail download.
2923 - Use root:root chmod 644 for exim config files, instead of mail:mail chmod 600.
2922 - Fix "./build php_imap".
2921 - Fix sendmail symlink.
2920, 2919 - Add configure/fpm/conf/php-fpm.conf.82. Remove dovecot configuration support for dovecot 1.x.
2918 - Fix imapsync binary inclusion in CageFS.
2917 - Make sure /etc/exim.conf is root-owned.
2916 - More code and versions.txt cleanup.
2915 - More cleanup of old/unused code.
2914 - Make sure exim-related configuration files are owned by mail:mail.
2913 - Remove dovecot 2.1.x and 2.2.x support. Remove exim <4.96 support as all versions of Exim previous to version 4.96 are now obsolete. Remove eximconf_release <4.5 support, as it's not compatible with exim 4.96.
2912 - Remove cpanel_to_da support from CustomBuild as it's now bundled with DirectAdmin.
2911 - Remove hideFrontpage function.
2910 - Revert ionCube v12 at this time.
2909 - Don't cache versions.txt and patches_versions.txt.
2908 - Fix "./build update" command.
2907 - Allow building ionCube for PHP 8.1.
2906 - Fix extraction of roundcube_direct_login and pma_direct_login plugins.
2905 - Don't use jemalloc_versions.txt/galera_versions.txt anymore.
2904 - Fix MySQL password reset in conf/my.cnf.
2903 - Fully drop CentOS5 and 32bit system support.
2902 - MySQL binary install fixes on Debian/AlmaLinux9.
2901 - Fix download of /etc/exim.variables.conf.default.
2900 - Fix file downloads from mirrors.
2899 - Don't use md5 checks from versions.txt anymore.
2898 - Escape MySQL password when using in my.cnf.
2897 - Revert /home/mysql MySQL datadir detection improvement.
2896 - Add RoundCube 1.6 support for PHP 7.3.
2895 - Improved mysqladmin binary location check. Added RoundCube auto-downgrade for PHP <7.3.
2894 - Fix /etc/virtual/* permissions for MagicSpam.
2893 - Added initial support for PHP 8.2. Add MySQL socket to [client] section in my.cnf if it already exists.
2892 - Updated the way CPU cores are counted.
2891, 2890 - Auto-check for aarch64 MySQL tarball after compilation on ARM64 systems.
2889 - Default to systemd-build when MySQL/MariaDB is compiled.
2888, 2887 - Unify mysql_inst=mariadb option between OS.
2886, 2885 - Ubuntu/debian ARM64 fixes.
2884 - Improve ARM64 support. Allow AlmaLinux9 installs.
2883 - Initial support for ARM64.
2882 - Fix ProtectHome parameter for MariaDB start/stop script in case /home/mysql is used for data.
2881 - More issue noticed on AlmaLinux/RockyLinux 9, disabled the installation at this time.
2880 - Remove MariaDB support on non-systemd linux systems.
2879, 2878 - Add mysqld57.service.binary as it doesn't support notify type for startup yet.
2877 - Fix MySQL start/stop systemd script.
2876 - Added configure/systemd/(mysqld.service.binary|mariadb.service.binary) files for binary installation of mysql/mariadb.
2875 - Auto-installation of i360 PHP modules in case it's installed on the system.
2874 - Changed default chmod of /etc/virtual/domainowners to 640
2873 - MySQL/MariaDB binary installation is now used on AlmaLinux/RockyLinux 9.
2872 - MariaDB default has been changed to 10.6.
2871 - Changed PHP default to PHP 8.1.
2870, 2869 - Use libspf2 from OS repositories.
2868 - Enable crb repository for PHP dependencies on AlmaLinux9.
2867 - Fixed exim build on AlmaLinux 9. Removed PHP 7.2 compatibility of PSR extension.
2866 - Changed RoundCube auto-downgrade not to check downloaded file md5sum.
2865 - Require PHP 5.6 for RoundCube 1.5.3 and higher.
2864 - Fix installation of ImapSync.
2863 - Better compatibility with CentOS Stream 9 / AlmaLinux 9.
2862 - Added perl-Digest-HMAC to imapsync dependencies for CentOS7
2861 - Exim 4.96 support.
2860 - Added curl and unitd to csf.pignore defaults.
2859 - Exported "DEBIAN_FRONTEND=noninteractive" for debian/ubuntu systems.
2858 - Open outbound imap port 143 for imapsync by default on csf/imapsync installation time.
2857 - More fixes for MariaDB 10.6 installation.
2856 - Fix galera install for MariaDB 10.6.
2855 - Use PCRE2 by default for nginx builds.
2854 - Make PHP 8.1 default on AlmaLinux 9.
2853 - Do not save files in case server error is returned (--fail flag for cURL).
2852 - Swap files22 with damirror.cj2.nl.
2851 - Fix redis-spamd.service compatibility with redis 7.
2850 - Remove cpanel_to_da.sh from autoupdates list, as it's bundled with DirectAdmin now.
2849 - Fix OpenSSL version check for PHP <8.1.
2848 - Re-generate CustomBuild cronjob on every update time.
2847 - Auto-downgrade phpMyAdmin for PHP <7.2.
2846 - Make PHP 8.1 default on Debian12/Ubuntu22.
2845 - Fix auto-addition of named=ON entry to services.status file.
2844 - Remove da_autoupdate setting, as autoupdates are managed by DirectAdmin now.
2843 - Update netdata.conf to include web files owner/group in config.
2842 - Speed-up rewrite_confs in case nginx+apache is used as a webserver.
2841 - Fix "Customize Compilation" save function in CustomBuild plugin.
2840 - Added an auto-cleanup of PHP 8.1 directory.
2839, 2838 - Fixed DirectAdmin version check.
2837 - Added --without-pcre2 by default to configure.nginx, so that it'd be compatible with libmodsecurity.
2836, 2835 - Use nobold option for "./build options" in plugin.
2834 - Update conf location of netdata.
2833 - Remove DA license OS mismatch check.
2832 - Clear disable_functions on command-line PHP calls.
2831 - Fix patching of majordomo.
2830 - Move passwd-server-status to a more secure place.
2829 - Disable Apache on OLS installation time in case it got installed from OS repositories.
2828 - Auto-install gd-devel for webalizer on RHEL-based systems.
2827 - Move /server-status authentication to /var/www/html/passwd-server-status. Fix wordpress_with_fastcgi_cache.conf template (remove hardcoded wp/ path).
2826 - Add more imapsync dependencies to be auto-installed.
2825, 2824. 2823 - Change Apache /server-info and /server-status endpoints to always require authentication.
2822 - Changed configure.unit to specify /tmp as the temporary directory.
2821 - Disable recursion by default in named.conf.
2820 - Add bind/named reload after named.conf changes.
2819 - Fix download of 1006_openssl1.1_autoverify.patch for PHP-IMAP.
2818, 2817 - Show installed/available version of DirectAdmin even if hostname has an invalid certificate installed
2816 - Fix permissions of /usr/local/directadmin/plugins after installation of CustomBuild plugin. Create /etc/virtual in "./build all" if it does not exist.
2815 - Improve bind configuration check.
2814 - Add da-popb4smtp to services.status on exim installation time.
2813, 2812 - Make bind listen on all the interfaces if it's set to localhost only.
2811 - CustomBuild to report failure/success to the message system on new installs.
2810 - Auto-generate Let's Encrypt certificate for hostname on "./build all" time. Disable CSF testing mode automatically.
2809 - Use cURL instead of wget for file downloads. Update wordpress_with_fastcgi_cache.conf Nginx template.
2808, 2807 - Downgrade exim.conf version automatically if exim 4.95 or higher is not in use.
2806 - Add csf=yes/no to the options.conf file.
2805 - Fix prestashop nginx template file.
2804 - Fix "too many arguments" error.
2803 - Fix "0: integer expression expected" error in the output.
2802 - Moved scripts/check_named_conf.sh to CustomBuild.
2801 - Add sysbk to "./build all".
2800 - Allow upgrading RoundCube with old versions of MySQL if innodb_file_format=Barracuda is set in /etc/my.cnf.
2799 - Add more bind checks.
2798 - Added majordomo, CSF and bind to "./build all". ProFTPd/Pure-FTPd get FTP environment cleaned up on the installation time.
2797 - Do not check MySQL version for the installation of RoundCube versions <1.5.
2796 - Create services.status file if it does not exist.
2795 - Fixed grub_conf execution on AlmaLinux and other systems.
2794 - Throw an error if MySQL/MariaDB version is too old for RoundCube.
2793 - Use PHP-LSAPI 8.0 by default instead of 7.9, as 7.9 is not compatible with PHP 8.1.
2792 - Require DirectAdmin 1.63 to run CustomBuild.
2791, 2790 - Added PHP 8.1 support.
2789 - Stop clamd/freshclam on remove_clamav time.
2788 - Fix redis startup script to support cgroups.
2787 - Add support of "./build imapsync".
2786 - Make sure dovecot=ON is in services.status after installation of dovecot.
2785 - If exim isn't in services.status list - add it there after installation
2784 - Add MySQL da_admin password to setup.txt if it does not exist there.
2783 - Fix rename of /etc/my.cnf to /etc/my.cnf.old on MySQL/MariaDB update time.
2782 - Patch exim to have no compilation problems on systems with opendmarc 1.4.
2781 - Make sure /etc/virtual/ files created are owned by mail:mail.
2780 - Use TLSECCertificateFile/TLSECCertificateKeyFile in proftpd.conf configuration in case ECC certificate is used.
2779 - Allow installation of bubblewrap on LXC environments where it'd work.
2778 - Fix a bug in doExim() where grep had no file specified.
2777 - Move creation of basic my.cnf from setup procedures to CustomBuild.
2776 - Make doExim() responsible for /etc/virtual initial files.
2775 - Don't use SSLCACertificateFile in Apache configuration anymore. Use bundled certificate file.
2774 - Use devtoolset-9 to build Unit unit-http module on CentOS7.
2773 - Always generate server.crt.combined if webserver=apache is set.
2772, 2771, 2770 - Automatically update/patch PHP 5.6-7.3 with PHP-FPM patch.
2769 - Patch PHP 5.6, 7.0 for https://github.com/php/php-src/commit/cb2021e5f69da5e2868130a05bb53db0f9f89e4b
2768 - Patch PHP 7.1, 7.2 and 7.3 for https://github.com/php/php-src/commit/cb2021e5f69da5e2868130a05bb53db0f9f89e4b
2767 - Update imagick PHP extension to have no exceptions for PHP8, as 3.5.1 fully supports it.
2766 - Fix inclusion of password/managesieve plugins in RoundCube 1.5.0.
2765, 2764, 2763 - Fix PHP-FPM LVE patching on CloudLinux systems.
2762 - Don't use "grep -P" for DirectAdmin version check, as this option is not supported on FreeBSD.
2761 - Added AF_NETLINK to the list of RestrictAddressFamilies to the systemd script of php-fpm.
2760 - Build SRS support for exim <4.95 too.
2759 - Fix "./build remove_clamav".
2758 - Support SRS in exim 4.95.
2757, 2756 - Add support of wp-cli.
2755 - Supress errors on DA update check for old versions of DA.
2754 - DirectAdmin version check includes build (commit sha) check.
2753 - Improve jailshell support in fcgid.sh. Add libxml2-devel package as a dependency for ClamAV.
2752 - Updated LiteSpeed systemd script.
2751 - Added igbinary PHP extension support. PHP-Redis is built with igbinary by default if it's installed.
2750 - Fix ClamAV 0.104 installation on Debian 10.
2749 - Add bzip2 to the list of dependencies of ClamAV.
2748, 2747 - More ClamAV 0.104 related fixes.
2746, 2745 - Fix ClamAV 0.104 support.
2744 - Fix libpmem requirement for MariaDB 10.6.
2743 - Fix md5 check of mod_suexec_directory.patch.
2742 - Fix proundcube -> roundcube typo.
2741 - Change hardened apache patch version check, as it's been changed on files1.
2740 - Skip bubblewrap in "./build versions" on CloudLinux systems.
2739 - Fix MariaDB 10.6 installation of debian.
2738 - CloudLinux Solo support.
2737 - Add additional grub.conf locations for grub_conf.
2736 - Fix custom openlitespeed httpd-alias.conf path.
2735 - Add systemd-timesyncd to csf.pignore.
2734 - Stop pure-certd/pure-uploadscript services on pure-ftpd removal time.
2733 - Add redis to the list of components in CustomBuild plugin.
2732, 2731 - CentOS Stream 8 support.
2730 - MariaDB 10.6 support.
2729 - If force_hostname is set in directadmin.conf - use it for RoundCube password management plugin.
2728 - Protect roundcube/logs and phpMyAdmin/log directories from access over SSH.
2727 - Bugfix for redis installation.
2726 - Use cloudlinux-scl-release on CloudLinux/CentOS6 as scl repo.
Fix "./build update_full" to execute OS related updates.
2725 - Add /usr/local/lib64 to ld.so.conf.
2724 - Use devtoolset-7 to build dovecot on CentOS6.
2723 - Protect RoundCube/phpMyAdmin logs when using Nginx.
2722 - Set jail=1, not 2 on bubblewrap installation time.
Add redis-server to csf.pignore.
2721 - Fix nginx unit section in "./build list_removals".
2720 - Add Bubblewrap/Jail Shell to "./build all".
2719 - Add "--with-openssl" to cURL compilation flags.
2718, 2717 - Skip PHP-Redis installation on PHP 5.x.
2716 - Added "./build remove_unit".
2715 - Hide redis update in "./build versions" if redis=no is set.
2714 - Fix md5 checksum of phpredis.
2713 - Add redis=yes/no configuration option.
2712 - Fix apache 2.4.48 compilation.
2711 - Add nginx_unit to access group.
2710 - Change namespace_private.conf to auto-create Junk folder and have spam/Spam namespaces.
2709 - Fix java/python Nginx Unit modules installation on debian systems.
2708 - Added bz2 extension to PHP extensions list.
2707 - Added joomla template for nginx URL rewrites.
2706 - Added PHP-Redis extension support.
2705 - Added redis for rspamd support.
2704 - Add mysql user to csf.pignore list.
2703 - Link /usr/local/lib/node_modules to /usr/lib/node_modules for Nginx Unit, if /usr/lib/node_modules does not exist.
2702 - Fix "grub_conf" on debian systems having /etc/default/grub.d/50-cloudimg-settings.cfg (overriding default grub cmdline).
2701 - Added files-fi as official mirror.
2700 - If broken glibc-headers is found - reinstall it.
2699 - Auto-update grub configuration on debian with grub_conf.
2698 - Improved exim.conf compatiility check with the old versions.
Fixed RPM dependency installation on RHEL8.
2697 - RHEL8: use codeready-builder-for-rhel-8-x86_64-rpms instead of powertools repo.
2696, 2695, 2694 - auto-load conf/namespace_private.conf for dovecot. Rename spam folder to .Junk.
2693, 2692 - Block access to .env in nginx/apache.
2691 - Make sure fastcgi cache purge module is compiled-in in nginx as reverse proxy as well.
2690 - Add unit to "./build rewrite_confs". Execute post-startup checks to rewrite the config if broken.
2689 - chmod PHP-FPM sockets dir 710 instead of 700.
2688 - Update grub configuration for quota/cgroups automatically after "./build all".
2687, 2686 - Create /etc/nginx/templates directory if it does not exist (nginx_apache or nginx webserver options).
2685 - Update CloudFlare IPs.
2684 - Add PHP-XMLRPC support for PHP 8.0.
2683 - Add a fallback for the installation of epel-repo.
2682 - Add cgroups for Nginx Unit.
2681 - Add directadmin.hostmark.pl to the list of unofficial mirrors.
2680 - Make Nginx FastCGI cache to be available in nginx_apache option.
2679 - Rename nginx templates directory to configure/nginx_templates/
2678 - Added +cipher_server_preference to openssl options for a higher internet.nl score.
2677, 2676 - Fix PHP compilation of LSAPI v7.9.
2675 - LiteSpeed renamed their lsapi php SAPI directory name to litespeed-VERSION instead of just litespeed for v7.9. CustomBuild supports it now.
2674 - Changed "control_service litespeed restart" to "control_service litespeed reload"
2673 - Fix phpMyAdmin version check for PHP <7.2.
2672 - Fix RPC in rand_pass() for FreeBSD
2671 - Add cgroups support for OLS.
2670 - Add cgroups support for LiteSpeed.
2669 - Fix exection of /usr/local/directadmin/custombuild/custom/hooks/cron_execute/pre and post hooks.
2668 - Add PHP-readline to the list of PHP extensions available.
2667 - "./build create_options" to ask if defaults should be used.
2666 - Add psi=1 to /etc/default/grub when needed.
2665 - CloudLinux: skip CageFS force-update on update_webapps time if nothing has been updated.
2664 - Use mariadbd as the process name for MariaDB 10.5 on FreeBSD systems.
2663 - disable-nls automatically, even if custom configuration file is there, for ProFTPd on FreeBSD systems.
2662 - Add "tls_dh_max_bits = 4096" to exim.variables.conf.
2661 - Check if libzstd-devel (zstd-dev) is installed.
2660 - Add nginx user to apache group and vice-versa, so that PHP-FPM sockets could be read from both webservers if they're both installed.
2659 - Improve libnghttp2 check (to make sure libnghttp2-devel is installed, not just nghttp2 on CentOS).
2658, 2657 - Added "./build grub_conf" to re-generate grub configuration with kernel settings needed (for example, rootflags for XFS quotas).
2656 - Improve libpng version check for FreeBSD.
2655 - Add throttling for fastcgi.
2654 - Add throttling for php-fpm.
2653 - Ignore more unrecognized symbols in options.conf/php_extensions.conf.
2652 - Don't auto-enable http2 on CentOS6.
2651 - Fix PHP8 installation on old installs.
2650 - New install on CloudLinux6 still had issues with http2, it's fixed now.
2649 - Fix new installs on CloudLinux6.
2648 - Revert removal of libiconv, tutorials can be followed to solve the problems.
2647 - If libiconv is removed - recompile ClamAV too.
2646 - Add configure/imagemagick/configure.imagemagick for ImageMagick compilation options.
2645 - Added "./build remove_curl" option.
2644 - htscanner was still not disabled for PHP8, it's disabled now.
2643 - Skip htscanner extension for PHP 8.0 (as it's not supported yet).
2642 - Don't compile phalcon 4.x for PHP8 (as it's not supported).
2641 - Don't install epel-release on Oracle Linux 8.
2640 - Fix installation of mcrypt for PHP <7.2.
2639 - Make sure libcurl is installed on new installation time.
2638 - Fix detection of PowerTools repository on CentOS <8.3.
2637 - Make installation succeed with Oracle Linux 8.
2636 - Skip curl download on "./build update" time if curl=no is set in the options.conf file.
2635 - PCRE2 is built-into PHP core, skip it on the installation time. Install libsodium from OS repos on DA installation time.
2634 - Skip installation of libnghttp2-devel on CentOS6.
2633 - Further optimization to use more OS-provided libraries and lower the installation time of DA. curl=no is the new default in the options.conf, as it'll use OS provided version too.
2632 - Add ImageMagick to the list of recompiled components on custom iconv removal.
2631 - Improve installation checks for s-nail.
2630 - Remove compiled version of iconv only if PHP8 is in use.
2629 - Added missing zstd version in "./build versions".
2628 - Improve MySQL 5.7/8.0 installation on new installs.
2627 - Install zstd from OS packages on DA installation time (to make it faster).
2626 - Fix PHP installation on CentOS Stream.
2625 - Removed iconv support from CustomBuild, it also fixes PHP8 support for installations having compiled version of iconv.
2624 - Fix package names for FreeBSD.
2623 - Don't show empty glib line in CustomBuild plugin.
2622 - Fix CWAF md5sum on FreeBSD.
2621 - Apply MySQL 5.7 patches from ports on FreeBSD systems.
2620 - Add first nginx templates for CMS.
2619 - Use ol8_codeready_builder instead of powertools repo on Oracle Linux 8.
2618 - Use apr-1.7.0 (and higher) everywhere, APR is compiled with --with-devrandom, so, LXC/OpenVZ/VMware issues with getrandom() call shouldn't appear anymore.
2617 - Use lowercase powertools yum repo on CentOS8 if it exists.
2616 - Added missing wget timeout for Comodo WAF installation script.
2615 - All non-EOL OS versions should support read-timeout wget option, speficy it by default for all the actions.
2614 - Load /usr/lib/x86_64-linux-gnu/libxml2.so for ModSecurity on debian systems.
2613 - Fix "./build set" for cases having "+" as the value.
2612 - exim.variables.conf: use /etc/exim_dh.pem as dhparams file.
2611 - Force compile PCRE on CentOS6 for new installations.
2610, 2609 - Use APR-1.7.0 or newer when possible, downgrade to 1.6.5 on LXC/OpenVZ.
2608 - Use nginx_unit for unit (instead of nobody).
2607 - Detect correct libxml2 path for ModSecurity (Apache).
Don't re-install ICU on FeeBSD if already installed.
2606 - Fix PCRE detection for PHP <7.4 on debian new installs.
2605 - Change pure-ftpd intermedaite to respresent only HIGH ciphersuite.
2604 - pure-ftpd.conf: change default TLSCipherSuite to HIGH.
2603 - Added php-ldap to the list of available PHP extensions.
2602 - Add PHP8 support for imagick module.
2601, 2600 - Another pcre-related path fix for PHP <7.2.
2599 - Auto-install mcrypt if not installed for PHP <7.2.
2598 - Fix PHP <7.2 installations on new installs.
2597 - Support multiple versions of Java in Nginx unit.
2596 - Install icu-config and freetype-config bash scripts on Debian >=10 to support PHP <=7.3.
2595 - Changed PHP default to PHP 7.4.
2594 - Fix PHP8 compilation on CentOS6 (new DA installs only)
2593 - Fix path to PCRE in apache configuration.
2592 - Check for not used packages in "./build update" and skip download of them.
2591 - The following can be used to overwrite anything in CB options.conf:
export php1_release=8.0
./setup.sh auto
For PHP modules:
export php_imap=yes
./setup.sh auto
2590 - Turn PrivateTmp off on LXC systems for MySQL/Apache/PHP-FPM, due to no privileges in LXC for new namespaces.
2589 - Speed up new installation time of DA by using more OS-provided libraries instead of compiled ones.
2588 - Show security warning in "./build versions" if EOL version of MySQL/MariaDB is used.
2587 - Use libzip from OS repositories where possible.
2586 - Fix PHP 7.4 dependencies installation.
2585 - Fix Apache installation on AWS Debian 10.6.
Skip libzip installation for PHP 7.4.
2584, 2583 - Fix PHP 7.4 installation on CentOS6 32bit.
2582 - Fix composer 2.0 version check.
2581 - Take jailshell parameter directly from /etc/passwd in fcgid*.sh scripts.
2580, 2579, 2578 - Fix PHP installation on CentOS7 new installs.
2577 - Fix 'with-pcre-regex' path in PHP configure.phpXX file if OS-bundled PCRE2 version is used.
2576 - Don't compile PCRE2 on systems having it in OS-package manager.
Add basic Nginx FastCGI cache global configuration.
2575 - Auto-install ngx_cache_purge module with nginx.
Auto-install java/ruby/python from OS repos for Nginx Unit. Install NodeJS from NodeJS repos.
2574 - If directadmin-only auto-updates are set in CustomBuild cronjob, execute "./build update_da" only if there is a new version of DirectAdmin released.
2573 - Generate /etc/dovecot/conf.d/95-sni.conf on DirectAdmin installation time.
2572 - Improve java module compilation for nginx unit.
2571 - Fix MySQL 5.6 installation on debian/ubuntu.
2570 - Make sure the owner of /var/log/httpd is apache.
2569 - Auto-swap |IP| in /etc/proftpd.sftp.conf.
2568 - Fix MySQL8 installation on debian/ubuntu.
2567 - Auto-load /etc/proftpd.sftp.conf in /etc/proftpd.conf if file is detected.
2566 - Fix installation of latest version of libxml2 on FreeBSD.
2565 - Fix MySQL 5.7 installation on FreeBSD.
2564 - Set exim queue_run_max to the number of CPU cores on systems having >5 cores.
Added lshttpd exception to csf.pignore for LiteSpeed.
2563 - Code preparation for PHP8.
2562 - Fix MariaDB 10.5 installation on FreeBSD.
2561 - Fix xapian-core compilation on CentOS6.
2560 - Don't lock MySQL 5.7 version to 5.7.27 on FreeBSD boxes.
2559 - Added /usr/libexec/dovecot/indexer and /usr/libexec/dovecot/indexer-worker to default csf.pignore list.
2558, 2557 - Add noftpd function to make sure DA installation succeeds when no FTP server is set in the options.conf file.
2556 - Move x-forwarded-for definition to nginx-cloudflare.conf and httpd-cloudflare.conf files.
2555 - Add CloudFlare IPs to the trusted IPs list by default to replace the IP in webserver logs with the one provided by X-Forwarded-For header.
2554 - Added new 3rd party mirror: directadmin.mirrors.misaka.one
2553 - Dynamic version check for dnsproviders file (let's encrypt).
2552 - Always set mysql_detect_correct_methods=1 in directadmin.conf.
2551 - Fix psr module installation for php2/3/4.
2550 - Added x-httpd-php to the list of default handlers for mod_lsphp.
2548, 2549 - Add msmtp support for jailshell email sends.
2546, 2547 - Use "gmake install" instead of "make install" for ProFTPd installation on FreeBSD systems.
2545 - Fix visual bug on option-change time when the value is already set to the same one.
2544 - chown roundcube under webapps before setup is finished.
2543 - New pigeonhole package name was a typo from their side. Reverted the fix as new package has been released.
2542 - Use php-litespeed SAPI from CloudLinux repository if mod_lsapi is used.
2541 - Pigeonhole uses x.y.z dovecot version instead of x.y now, updating the code to support it.
2540 - Fix libcap detection on CentOS6 systems.
2539 - Preserve MySQL custom logrotate file if any (on RPM-based systems).
2538 - Keep changes to /etc/logrotate.d/mysql on MySQL update/upgrade time.
2537 - Some backwards compatibility for custom_versions.txt php53:5.2.17:.
2536 - Added socat to the list of dependencies for MariaDB.
2535 - Remove IdentLookups from proftpd.conf, it is not supported anymore.
2534 - CloudLinux boxes should have first lsphp version handler always defined as /usr/local/bin/lsphp.
2533 - exim.jail.conf support.
2432 - Show "Setting is already set to XX" if no changes are done using "./build set ..".
2431 - Add netdata to clsupergid on CloudLinux systems.
2429, 2430 - Unify httpd-directories.conf to top '/' level to allow for home2 rules.
2428 - Added unofficial_mirrors=yes/no. Defaults to no. Does not affect old installations (unless "set_fastest" is ran).
2427 - Fix gmp PHP extension compilation on debian.
2426 - Added files-sg.directadmin.com to official mirrors list.
2425 - Fix MariaDB installation on CentOS6 boxes.
2524 - Fix installation of yajl-devel and lua-devel from PowerTools repo on CentOS8.
2523 - Fix doIMagick call in "./build php_extensions".
2522 - If there is no yajl compiled-into ModSecurity - show current version as 0, so that update of ModSecurity would be shown.
2521 - Update dnsproviders.json to 3.8.0 (added ArvanCloud).
2520 - Remove default /icons/ alias for FancyIndex (apache).
Make intermediate ciphersuite internet.nl-friendly.
Add max_allowed_packet=64M to default my.cnf if none is set.
2519 - Changed default ModSecurity ruleset to owasp (CRS).
2518 - Added pcre2 to MariaDB 10.5 dependencies.
2517 - MariaDB 10.5 support.
2516 - Allow building ioncube for PHP 7.4.
2515 - Always install lego on letsencrypt installation time (earlier it had a version check).
2514 - Fix libzip installation on centos8 (cmake pre-requisite).
2513 - chown fix for dnsproviders.json
2512 - Use devtoolset on CentOS6 for ICU/PHP compilation (we may support newer versions of ICU in the future).
2511 - Fix yajl-devel installation on CentOS8 for ModSecurity.
2510 - Fix "redirection unexpected" on debian machines.
2509 - Fix "SecAuditLogFormat JSON" support in ModSecurity 2.9 (used for Apache). Requires recompilation of ModSecurity.
2508 - Default modsecurity_audit.log format is JSON now.
MySQL is given more time to start after upgrades.
2507 - Execute "./build update" on "./build update_full" time.
Use zstd for compression of emails in dovecot 2.3.11 and newer.
2506 - Add -ltr to debian7 exim ldflags.
2505 - More safety checks for config/version mismatch for exim 4.94.
2504 - Fix exim 4.94 installation on CentOS6.
2503 - Compatibility fixes for exim 4.94.
2502 - Use devtoolset-7 on CentOS6 for installation of zstd.
2501 - If MySQL/MariaDB is not managed by CustomBuild - use correct syntax for user creation/password changes.
2500 - Added zstd support by default.
2499 - Added session.save_path/upload_tmp_dir for webapps in case mod_lsapi is used.
2498 - Update some text/documentation in "./build versions" and "./build opt_help full".
2497 - Enable pigeonhole by default.
2496 - ModSecurity ruleset fixes on nginx installation time.
2495 - MySQL 5.7.27 downgrade for FreeBSD, as there is no newer version of MySQL 5.7 in official repositories.
2494 - Include exim.dkim.conf in exim_conf update command.
2493 - Execute /usr/share/magicspam/bin/activate_module on exim_conf time, if it exists.
2492 - Install sqlite-devel for fts-xapian automatically.
2491 - Basic support for letsencrypt.sh 2.0 and Lego client.
2490 - Fix SpamAssassin pre-requisites installation on CentOS8.
2489 - Some systems got MPM auto-switched to prefork on PHP recompilation time, this release should fix this.
2488 - Turn on "managesieve_vacation" option by default in RoundCube if Pigeonhole is used.
2487 - Auto-install libuv on libzip installation time.
2486 - Add ldconfig calls to more places after installation of new libraries.
2485 - Added new mirror.
2484 - Update configure/fastcgi/fcgid.sh to support /~userdir access with jailshell.
2483 - Auto-reload OpenLiteSpeed with pureftpd_uploadscan=yes if .htaccess is uploaded.
2482 - Improve netdata socket directory permissions.
2481 - ProFTPd configuration respects ssl_configuration=modern/intermediate/old.
2480 - Added Netdata installation command.
2479 - ProFTPd related fixes for CentOS8.
2478 - Improve installed packages check on debian systems.
2477 - Automatically open UDP port 11335 in CSF on rspamd installation time.
2476 - Rspamd: revert "normal" listener to TCP/IP port 11333.
2475 - Create "/usr/lib/modules" on jailshell installation time if it does not exist.
2474 - Added snuffleupagus to "./build versions".
2473 - Initial support for snuffleupagus PHP extension.
Set jail=2 with "./build bubblewrap" by default.
2472, 2471 - rspamd: for security reasons, use socket files in /var/run/rspamd, instead of TCP/IP.
2470, 2469 - Fix http/2 default on CentOS8 new installations.
2468 - php-fastcgi related fixes for webapps.
2467 - Remove vm-pop3d from services.status on dovecot installation time.
2466 - Don't hardcode /home/ for user homedir in jailed fcgid.
2465 - Simplified fcgid.sh scripts (same version for all PHP variants). Added "dovecotconf" as an alias to "dovecot_conf". Fastcgi mode supports jail now.
2464 - Set dovecot=1 in directadmin.conf on new installations.
2463 - Some fixes for MySQL 8.0 installation.
2461, 2462 - Remove Let's Encrypt pre-checks for old invalid certificates (it was added temporarily).
2460 - Fix CustomBuild cronjob syntax.
2459 - Revert jailcron, because jailshell is enough for cronjob shells.
2458 - Added custom/hooks/cron_execute/pre and custom/hooks/cron_execute/post hooks for pre/post execution of the CustomBuild cronjob. "./build cron" is needed to re-generate the cronjob which uses the hooks.
2457 - Fix MySQL 5.6 installation on new installs.
2456 - Some minor fixes for installation of phalcon PHP extension.
2455 - Another systemd-related fix for Apache 2.4.43.
2454 - Added rspamd to csf.pignore. Added jailcron for cronjobs.
2453 - Don't call dovecot conversion on new installation time.
2452 - Fix Apache 2.4.43 compilation issues.
2451 - Added jailed shell support. More details to come in documentation.
2450 - Don't include --with-apxs2 in PHP configuration file if mod_php isn't used.
2449 - added damirror.pars.host to https mirrors list.
2448 - A fix for default MPM module loaded after PHP re-build.
2447 - Install epel-release package on SpamAssassin installation time to get all of the dependencies installed.
2446 - Skip imagick extension installation if particular version of php hasn't been installed yet.
2445 - Build ImageMagick after PHP time on new installation.
2444 - Fix writeLog function to log minutes to custombuild.log correctly (it was logging months instead of minutes in time format).
2443 - Reinstall imagick PHP extension after update of ImageMagick.
2442 - Fix MagicSpam include in exim.conf.
2441 - Fix litespeed installation with the trial key.
2440 - Auto-create mysqld runtime directory on systemd-based OS.
2439 - Added gmp to the list of possible PHP extensions.
2438 - Fix MySQL8 installation on FreeBSD11.
2437 - Fix MySQL wget URL on FreeBSD systems.
2436 - Alpha bits for Unit installation.
2435 - Re-install FTS-Xapian on "./build dovecot" time if it has been installed already.
Add --enable-embed PHP configuration flag if mod_php is not used.
2434 - Fix php-imap compilation with OpenSSL 1.1.
2433 - Improve wording of php-imap/xml extensions in "./build versions".
2432 - Check for invalid Let's Encrypt certificates on systems with mail_sni=0.
2431 - Add Let's Encrypt checks for CAA issues to update_webapps and update_da calls.
2430 - Let's Encrypt hotfix for CAA bug (https://community.letsencrypt.org/t/2020-02-29-caa-rechecking-bug/114591). Any command doing doChecks() (for example "./build versions" will do a 1-time checkup for cert renewal).
2429 - Allow clicking 'enter' for default settings when custom installation settings are used.
2428 - Fix php_extensions.conf on customized new installation.
2427 - Disable root logins to phpMyAdmin.
2426 - Cosmetic bugfix for "./build set" for old PHP extensions..
2425 - Add option_set_valid_php() for validity of php_extensions.conf settings.
2424 - Fix ioncube question on custom installation set.
2423 - Auto-install pam-devel for PHP-IMAP.
2422 - Improvements for "PHP Extension Settings" section. Changed variables structure for php_extensions.conf settings.
2421 - Improvements for getPhpOpt() function.
2420 - Added "./build php_extensions" to build all PHP extensions at once. Added "xmlrpc" to the list of available PHP extensions.
2419 - Add new PHP extension section to CB plugin (plugin will need to be updated).
2418 - Use "./build set_php extension yes/no". Backwards compatibility for ioncube/zend/suhosin/imagick/opcache.
2417 - Rename phalcon -> php_phalcon, append php_ to every "./build php_extension". Backwards compatibility for ioncube/zend/suhosin/imagick/opcache.
2416 - PHP extensions controlled in php_extensions.conf. phalcon and imap added as new PHP extensions.
2415 - Show correct OpenLiteSpeed version in installation output.
2414 - Added -DWITHOUT_MROONGA=YES to compilation of MariaDB on FreeBSD.
2413 - Fix MariaDB compilation on FreeBSD.
2412 - Add mirror.serverion.com to unofficial mirrors list.
2411 - Install libnsl on CentOS8 for OpenLiteSpeed web admin.
2410 - Added files-ca to official mirrors list. Better detection of MySQL binary package on FreeBSD systems.
2409 - exim Makefile using uses getFile() instead of wget now.
2408 - phpMyAdmin SSO: the cookies set the host, so if mysql is remote, ensure the direct_login/index.php is updated to point to that host
2407 - Fix empty line in /etc/exim.variables.conf with ssl_configuration=modern option set.
2406 - Downgrade ssl_configuration option to "old" on EOL OS (CentOS4/5, Debian6/7 etc.).
2405 - Fix OpenSSL <1.0.2 version check for SSLOpenSSLConfCmd use on CentOS6/Debian8/Debian9 .
2404 - Use predefined 4096-bit DHE public key where possible, to solve internet.nl error. Configure it using SSLOpenSSLConfCmd directive in Apache, if OpenSSL 1.0.2 or higher is detected.
Use ssl_configuration=old/intermediate/moden for Exim and Dovecot. TLSv1.1 is EOL as of March 31, 2020. Windows 7 support ended on January 14, 2020.
2403 - Don't allow setting ssl_configuration=modern on OS/webservers not supporting TLSv1.3. Old OS support TLSv1.3 by default in LiteSpeed/OpenLiteSpeed only.
2402 - Disable MySQL/MariaDB versions in options.conf that are unavailable on CentOS8.
2401 - libpng->libwebp for libwebp updates in CustomBuild plugin.
2400 - modify setup.txt and set correct da_admin password there on MySQL/MariaDB reinstallation time.
2399 - don't remove MySQL-python package on MySQL update time.
2398 - added dummy da-exim dpkg package for exim installations on debian.
2397 - error and exit if mod_ruid2 if enabled on unsupported system.
set MySQL data direcotry to /var/lib/mysql on new installations of debian.
2396 - install dependencies on SpamAssassin installation time.
2395 - downgrade version of ICU if PHP 5.3/5.4 is enabled.
2394 - added ability to upgrade MySQL 5.1 to 5.5.
2393 - fix nginx installation on CentOS6 if libmodsecurity 3.0 is used.
2392 - skip modsecurity download on "./build update" if webserver is not set to apache.
2391 - fix libmodsecurity 3.0 installation on CentOS6.
2390 - fix mariadb 5.5 installation on new installs
2389 - exit litespeed update sooner in case license is expired.
2388 - fix ICU linking issue on Ubuntu 18.04 (https://unicode-org.atlassian.net/browse/ICU-20959).
2387 - hide libmodsecurity/modsecurity connector updates in available updates list if nginx is not used.
2386 - phpMyAdmin config.inc.php is chmod 440 by default now.
2385 - fixed composer current version check in CustomBuild plugin.
2384 - added "pexe:/opt/alt/php../usr/bin/php" to csf.pignore list.
2383 - Fixed typo for composer component in the output of "./build version".
2382 - Fixed PHP 5.3 "make install" for new installations. It needed "bin" directory to be pre-created.
2381 - Added composer support.
Added csf.pignore checks for CustomBuild used services. It takes the list from configure/csf.pignore.
2380 - Added lua 5.3 support, which is minimal version required required for ModSecurity.
2379 - Suppress s-nail warnings in "./build version" output.
2378 - Fixed imagick compilation when multiple versions of PHP are used.
2377 - Set global CacheRoot for LiteSpeed by default.
2376 - Use "['Servers'][]['DisableIS'] = true;" in phpMyAdmin configuration to make large tables load faster.
2375 - Auto-install sqlite on Centos6 boxes for PHP 7.4.
2374 - Fix "newaliases" command for new installations of exim.
2373 - Added "--with-pear" option to PHP 7.4.
2372 - Fix OpenLiteSpeed taking up nginx_apache ports on startup.
Auto-enable mod_lsapi when switching from another webserver to apache if CloudLinux is used.
2371 - Fix OpenLiteSpeed taking up nginx_apache ports on startup.
2370 - Suppress warnings on FreeBSD for nginx-related certification copying on the build time.
2369 - Inherit exits from subshell in CustomBuild hooks.
2368 - Added "update_full" alias for "update_versions_full"/"update_versions full".
2367 - Added per-call CustomBuild hooks. (https://forum.directadmin.com/threads/custombuild-2-0-rev-2369-with-steroids.60153/)
Added "full" update method (update_versions_full and update_versions full). Runs OS updates + CustomBuild update and update_versions.
