PHP 7.3 switch to php 5.6
cikabrke
My Directadmin is 1.60.4 everything is well installed
CentOS 7.0 64-Bit
Im switch to php 5.6 on User account after installation prestashop 1.4 with php 5.6 problem CREATE TABLE
everything is updated :(
Just out of curiosity, why switch back when it worked before?
But most of all, why installing an ancient prestashop version and not install the newest 1.7.6.5. which also works with php 7?
because some scripts don't work on php 7 PERFECT :)
they ask for clients and they pay and we have to give them
I know that, but you can use multiple versions, use php 7 for the user with the newest Prestashop version.
Give php 5.6 to the other users with scripts which don't work on php 7.
Unless the user with Prestashop also has other scripts which can't work with php 7. ;)
Did you manage to fix the issue by checking the sql_mode setting like suggested?
1) SET sql_mode = '';
2) SET GLOBAL sql_mode=(SELECT REPLACE(@@sql_mode,'ONLY_FULL_GROUP_BY',''));
sql_mode needs to be set in /etc/my.cnf or /etc/my.cnf.d/server.cnf.
Simply this in [mysqld] section:
sql_mode=
i tried everything and always the same problem :(
I installed again DA the same problem
I do not have permissions to create
Where I can find how to install php 7 et php 5.6 do i need php.ini to create for each i installed a thousand times creating table is always a problem
