Anonymous FTP
k1l0b1t
Belgium
I wanted to create an anonymous ftp share to put some files up, but I can't seem to login with [email protected] (pure-ftpd)
I tried restarting pure-ftpd, but no success. Any tips how I get this working? (or how to add a read-only ftp user)
But you did enable anonymous ftp access via the account?
Have you tried using username anonymous (without @domain.com) and password some email addres (even non existing) or [email protected]?
What dot he log files say when trying to connect?
No, it still does not work. (The @domain.com is required because I'm using the server IP (My server only has 1 IP#). and whatever I enter as a password It does not work (I did "whitelist" my ip in CSF to be able to test). My FTP software says this, both with and without the @domain.com part:
Opdracht:    USER anonymous
Antwoord:    331 User anonymous OK. Password required
Opdracht:    PASS ***************************
Antwoord:    530 Login authentication failed
I think I'll just put the files up on a subdomain and add `Options +Indexes` to a .htaccess file, But it would still be nice to get anonymous FTP working.
It's not set up by default. Since Anonymus FTP is not looked as a good idea these days. So you will have to dig in a configure the system.
Start here:
cat /etc/pure-ftpd.conf |grep Anonymous
Thx @bdacus01, I know anonymous ftp is a "bad" idea, but I just want to have it working (decided I'm not going to use it) I'll take a look at it later
In the past there was a selection part in the enhanced skin for anonymous ftp, but it must be enabled, this was with proftpd.
There are some anonymous options in the pureftpd.conf where you can also point out if they may upload or only download.
I don't know if this enables things or choices on user level.
Please let us know your results after you have taken a look at it, because this question is asked more often and at this moment I don't have a testing server available. Maybe after the weekend I do.
I did find an option "NoAnonymous yes", changed it to no, but no success. I think it was a proftpd thing that allowed read-only users. Logging in with "anonymous" works then, but that is not configured (I only have 1 IP) I thik anonymous ftp via the [email protected] was a proftpd feature. Anyways thanks for the help @Richard G and @bdacus01, not going to do too much to get somthing "just to work to have it working"
You're welcome. As said with a bit of luck I will have a VPS for a few days which I can test with.
I'm still curious so I will do some tests myself, if I might get it to work (I have my doubts that I will) then I will post it here.
Well I promised to do some tests myself and report back. And I found this:
However in my case minuid was already at 99 by default.
I added the cryptline in the directadmin.conf which also did not do any good.
The anonymous ftp user is added to the /etc/proftpd.passwd file, which also places it in the /etc/pureftpd.pdb file. I checked this and that part works.
Also tried to set the NoAnonymous to no in the puref-ftpd.conf to make things work.
However, I'm also only running into the authentication failures.
As this should work, I could be mistaken but seems to me you found a bug.
Good chance @smtalk or @DirectAdmin Support can fix this for you if you send in a ticket.
Thanks for testing ;) .Except I have an internal licence trough my provider, so I can't send tickets to directadmin. And I'm using a directory with directory indexing enabled now, so anonymous FTP is not needed anymore. But thanks again for testing ;)
You're welcome. However, I might have use for anonymous FTP for some accounts, it should be working some way.
So in that case I might send in a ticket if no answer is coming in this thread.
As for testing, you're welcome.
Also good to hear you found another solution.
A really late update on this:
Enabling the 'set_crypt_for_anonymous_ftp' option to 1 in directadmin.conf, and setting "NoAnonymous " to no made it work.
I have had this problem, too. I was using proftpd (not the default pureftpd) see here. I ended up changing global settings as the server does not serve customers.
Would be nice to see this feature working out of the box as I will eventually have DirectAdmin customers.
have you tried setting the `set_crypt_for_anonymous_ftp`, that did the trick for me
are you using `[email protected]` (required if it's a non-owned ip and not the default domain of the account)
oh yeah, discovered upload is broken (unless you make a directory chown by nobody, but then it'l work without the checkbox enabled in DA)
because anonymous upload is disadvised, you should not chown a dir to nobody, nor check the checkbox in da (in case in a future update it would end up working)
