Mysql8 on directadmin does not start!!
aidin1840
i recently upgrade from 5.7 to 8 with custombuild 2.0. but after the completion Mysql did not start!!
ERROR 2002 (HY000): Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (2)
i have done anything that described here:
but nothing happend. still does not run!
mysql.sock does not exist.
ls -la /var/lib/mysql/mysql.sock
ls: cannot access /var/lib/mysql/mysql.sock: No such file or directory
Please help me thanks
check mysql log, maybe some directives in my.cnf incompatible with new version
but it must show restart process, more details about errors/warnings also commands to check detailed info about problem
copy here output of restart command
i have another question:
i have not any backup of my databases. if i back up /var/lib/mysql and rebuild and install new mysql is it possible to restore back databases from old /var/lib/mysql ?
i mean replace old one with the newly built
Check journalctl for log entries, or set a log-file in MySQL configuration to see what's going on there :)
thanks but it is centos 6 and has not any journalctl !
[root@server ~]# journalctl
-bash: journalctl: command not found
Okay, try:
su - mysql -s /bin/bash
mysqld
[root@server ~]# su - mysql -s /bin/bash
-bash-4.1$ mysqld
2020-06-01T12:45:53.924439Z 0 [Warning] [MY-010139] [Server] Changed limits: max_open_files: 1024 (requested 8161)
2020-06-01T12:45:53.924487Z 0 [Warning] [MY-010142] [Server] Changed limits: table_open_cache: 431 (requested 4000)
2020-06-01T12:45:54.221755Z 0 [System] [MY-010116] [Server] /usr/sbin/mysqld (mysqld 8.0.20) starting as process 12018
2020-06-01T12:45:54.236507Z 1 [System] [MY-011012] [Server] Starting upgrade of data directory.
2020-06-01T12:45:54.236712Z 1 [System] [MY-013576] [InnoDB] InnoDB initialization has started.
2020-06-01T12:45:57.600242Z 1 [System] [MY-013577] [InnoDB] InnoDB initialization has ended.
2020-06-01T12:45:59.084303Z 0 [Warning] [MY-010727] [Server] System table 'plugin' is expected to be transactional.
2020-06-01T12:45:59.098495Z 0 [System] [MY-011323] [Server] X Plugin ready for connections. Socket: '/var/run/mysqld/mysqlx.sock' bind-address: '::' port: 33060
2020-06-01T12:45:59.130583Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_yith_wcwl_lists`" or dump/reload to fix it!
2020-06-01T12:45:59.131431Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_yith_wcwl`" or dump/reload to fix it!
2020-06-01T12:45:59.132449Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_yith_wcaf_payments`" or dump/reload to fix it!
2020-06-01T12:45:59.133261Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_yith_wcaf_payment_notes`" or dump/reload to fix it!
2020-06-01T12:45:59.138891Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_yith_wcaf_commissions`" or dump/reload to fix it!
2020-06-01T12:45:59.139741Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_yith_wcaf_commission_notes`" or dump/reload to fix it!
2020-06-01T12:45:59.140777Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_yith_wcaf_clicks`" or dump/reload to fix it!
2020-06-01T12:45:59.235634Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_woocommerce_log`" or dump/reload to fix it!
2020-06-01T12:45:59.237075Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_woocommerce_downloadable_product_permissions`" or dump/reload to fix it!
2020-06-01T12:45:59.248754Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_woocommerce_api_keys`" or dump/reload to fix it!
2020-06-01T12:45:59.250179Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_woo_wallet_transactions`" or dump/reload to fix it!
2020-06-01T12:45:59.259114Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_wc_webhooks`" or dump/reload to fix it!
2020-06-01T12:45:59.279095Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_wc_download_log`" or dump/reload to fix it!
2020-06-01T12:45:59.280502Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_users`" or dump/reload to fix it!
2020-06-01T12:45:59.328437Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_posts`" or dump/reload to fix it!
2020-06-01T12:45:59.378315Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_dokan_vendor_balance`" or dump/reload to fix it!
2020-06-01T12:45:59.480676Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_dokan_report_abuse_reports`" or dump/reload to fix it!
2020-06-01T12:45:59.545922Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_dokan_follow_store_followers`" or dump/reload to fix it!
2020-06-01T12:45:59.567880Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_comments`" or dump/reload to fix it!
2020-06-01T12:45:59.582013Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `j59k2_weblinks`" or dump/reload to fix it!
2020-06-01T12:45:59.615011Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `j59k2_users`" or dump/reload to fix it!
2020-06-01T12:45:59.663920Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `j59k2_user_notes`" or dump/reload to fix it!
2020-06-01T12:45:59.751606Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `j59k2_ucm_history`" or dump/reload to fix it!
2020-06-01T12:45:59.753242Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `j59k2_ucm_content`" or dump/reload to fix it!
2020-06-01T12:45:59.791449Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `j59k2_tags`" or dump/reload to fix it!
2020-06-01T12:45:59.819662Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `j59k2_redirect_links`" or dump/reload to fix it!
2020-06-01T12:45:59.865969Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `j59k2_newsfeeds`" or dump/reload to fix it!
2020-06-01T12:45:59.881220Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `j59k2_modules`" or dump/reload to fix it!
2020-06-01T12:45:59.895841Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `j59k2_messages`" or dump/reload to fix it!
2020-06-01T12:45:59.919105Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `j59k2_menu`" or dump/reload to fix it!
2020-06-01T12:46:01.634241Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `j59k2_finder_links`" or dump/reload to fix it!
2020-06-01T12:46:01.636082Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `j59k2_finder_filters`" or dump/reload to fix it!
2020-06-01T12:46:01.638012Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `j59k2_extensions`" or dump/reload to fix it!
2020-06-01T12:46:01.723035Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `j59k2_content`" or dump/reload to fix it!
2020-06-01T12:46:01.724998Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `j59k2_contact_details`" or dump/reload to fix it!
2020-06-01T12:46:01.726870Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `j59k2_categories`" or dump/reload to fix it!
2020-06-01T12:46:01.728730Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `j59k2_banners`" or dump/reload to fix it!
2020-06-01T12:46:01.747170Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `j59k2_banner_clients`" or dump/reload to fix it!
2020-06-01T12:46:02.796452Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_users`" or dump/reload to fix it!
2020-06-01T12:46:03.063410Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_posts`" or dump/reload to fix it!
2020-06-01T12:46:03.130492Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_links`" or dump/reload to fix it!
2020-06-01T12:46:03.178438Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_comments`" or dump/reload to fix it!
2020-06-01T12:46:03.206312Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_permanent_block`" or dump/reload to fix it!
2020-06-01T12:46:03.208483Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_login_lockdown`" or dump/reload to fix it!
2020-06-01T12:46:03.210728Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_login_activity`" or dump/reload to fix it!
2020-06-01T12:46:03.212905Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_global_meta`" or dump/reload to fix it!
2020-06-01T12:46:03.215145Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_failed_logins`" or dump/reload to fix it!
2020-06-01T12:46:03.217339Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_events`" or dump/reload to fix it!
2020-06-01T12:46:03.703440Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_users`" or dump/reload to fix it!
2020-06-01T12:46:03.967849Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_posts`" or dump/reload to fix it!
2020-06-01T12:46:04.083404Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_links`" or dump/reload to fix it!
2020-06-01T12:46:04.085582Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_duplicator_packages`" or dump/reload to fix it!
2020-06-01T12:46:04.087740Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_comments`" or dump/reload to fix it!
2020-06-01T12:46:04.110367Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_permanent_block`" or dump/reload to fix it!
2020-06-01T12:46:04.112508Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_login_lockdown`" or dump/reload to fix it!
2020-06-01T12:46:04.114708Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_login_activity`" or dump/reload to fix it!
2020-06-01T12:46:04.116898Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_global_meta`" or dump/reload to fix it!
2020-06-01T12:46:04.119984Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_failed_logins`" or dump/reload to fix it!
2020-06-01T12:46:04.122345Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_events`" or dump/reload to fix it!
2020-06-01T12:46:04.621799Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_users`" or dump/reload to fix it!
2020-06-01T12:46:04.708802Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_posts`" or dump/reload to fix it!
2020-06-01T12:46:04.752257Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_links`" or dump/reload to fix it!
2020-06-01T12:46:04.754591Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_comments`" or dump/reload to fix it!
2020-06-01T12:46:04.779668Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_permanent_block`" or dump/reload to fix it!
2020-06-01T12:46:04.782033Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_login_lockdown`" or dump/reload to fix it!
2020-06-01T12:46:04.784352Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_login_activity`" or dump/reload to fix it!
2020-06-01T12:46:04.787683Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_global_meta`" or dump/reload to fix it!
2020-06-01T12:46:04.790323Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_failed_logins`" or dump/reload to fix it!
2020-06-01T12:46:04.792963Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_events`" or dump/reload to fix it!
2020-06-01T12:46:05.402957Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `ap_form_19127_review`" or dump/reload to fix it!
2020-06-01T12:46:05.405520Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `ap_form_19127`" or dump/reload to fix it!
2020-06-01T12:46:05.408130Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `ap_form_18812`" or dump/reload to fix it!
2020-06-01T12:46:05.410652Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `ap_form_18010_review`" or dump/reload to fix it!
2020-06-01T12:46:05.413216Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `ap_form_18010`" or dump/reload to fix it!
2020-06-01T12:46:05.415790Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `ap_form_17652`" or dump/reload to fix it!
2020-06-01T12:46:05.418310Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `ap_form_16519_review`" or dump/reload to fix it!
2020-06-01T12:46:05.420896Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `ap_form_16519`" or dump/reload to fix it!
2020-06-01T12:46:05.423532Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `ap_form_15922_review`" or dump/reload to fix it!
2020-06-01T12:46:05.426172Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `ap_form_15922`" or dump/reload to fix it!
2020-06-01T12:46:05.429164Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `ap_form_14096`" or dump/reload to fix it!
2020-06-01T12:46:05.431805Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `ap_form_13868`" or dump/reload to fix it!
2020-06-01T12:46:05.434420Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `ap_form_13688`" or dump/reload to fix it!
2020-06-01T12:46:05.437117Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `ap_form_13500`" or dump/reload to fix it!
2020-06-01T12:46:05.439794Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `ap_form_12722`" or dump/reload to fix it!
2020-06-01T12:46:05.442534Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `ap_form_11797`" or dump/reload to fix it!
2020-06-01T12:46:05.445838Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `ap_form_11375`" or dump/reload to fix it!
2020-06-01T12:46:05.450091Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `ap_form_11029`" or dump/reload to fix it!
2020-06-01T12:46:05.454234Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `ap_form_10120`" or dump/reload to fix it!
2020-06-01T12:46:05.626433Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_users`" or dump/reload to fix it!
2020-06-01T12:46:05.679997Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_posts`" or dump/reload to fix it!
2020-06-01T12:46:05.703191Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_links`" or dump/reload to fix it!
2020-06-01T12:46:05.705952Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_comments`" or dump/reload to fix it!
2020-06-01T12:46:06.231841Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_users`" or dump/reload to fix it!
2020-06-01T12:46:06.340912Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_posts`" or dump/reload to fix it!
2020-06-01T12:46:06.380417Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_links`" or dump/reload to fix it!
2020-06-01T12:46:06.399346Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_comments`" or dump/reload to fix it!
2020-06-01T12:46:06.417379Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_permanent_block`" or dump/reload to fix it!
2020-06-01T12:46:06.420429Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_login_lockdown`" or dump/reload to fix it!
2020-06-01T12:46:06.423543Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_login_activity`" or dump/reload to fix it!
2020-06-01T12:46:06.426677Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_global_meta`" or dump/reload to fix it!
2020-06-01T12:46:06.429730Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_failed_logins`" or dump/reload to fix it!
2020-06-01T12:46:06.432875Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_events`" or dump/reload to fix it!
2020-06-01T12:46:07.290342Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_users`" or dump/reload to fix it!
2020-06-01T12:46:07.393292Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_posts`" or dump/reload to fix it!
2020-06-01T12:46:07.443645Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_links`" or dump/reload to fix it!
2020-06-01T12:46:07.480521Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_comments`" or dump/reload to fix it!
2020-06-01T12:46:07.502613Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_permanent_block`" or dump/reload to fix it!
2020-06-01T12:46:07.505674Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_login_lockdown`" or dump/reload to fix it!
2020-06-01T12:46:07.508713Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_login_activity`" or dump/reload to fix it!
2020-06-01T12:46:07.511748Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_global_meta`" or dump/reload to fix it!
2020-06-01T12:46:07.514844Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_failed_logins`" or dump/reload to fix it!
2020-06-01T12:46:07.518007Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_events`" or dump/reload to fix it!
2020-06-01T12:46:07.824126Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_woocommerce_downloadable_product_permissions`" or dump/reload to fix it!
2020-06-01T12:46:07.908171Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_wc_webhooks`" or dump/reload to fix it!
2020-06-01T12:46:07.955775Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_users`" or dump/reload to fix it!
2020-06-01T12:46:08.203576Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_posts`" or dump/reload to fix it!
2020-06-01T12:46:08.250670Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_masterslider_sliders`" or dump/reload to fix it!
2020-06-01T12:46:08.272140Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_links`" or dump/reload to fix it!
2020-06-01T12:46:08.276369Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_duplicator_packages`" or dump/reload to fix it!
2020-06-01T12:46:08.279860Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_comments`" or dump/reload to fix it!
2020-06-01T12:46:08.690206Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_woocommerce_downloadable_product_permissions`" or dump/reload to fix it!
2020-06-01T12:46:08.712373Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_wc_webhooks`" or dump/reload to fix it!
2020-06-01T12:46:08.746112Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_users`" or dump/reload to fix it!
2020-06-01T12:46:08.933930Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_posts`" or dump/reload to fix it!
2020-06-01T12:46:08.968666Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_links`" or dump/reload to fix it!
2020-06-01T12:46:08.972291Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_duplicator_packages`" or dump/reload to fix it!
2020-06-01T12:46:08.976250Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_comments`" or dump/reload to fix it!
2020-06-01T12:46:09.428242Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_users`" or dump/reload to fix it!
2020-06-01T12:46:09.602880Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_posts`" or dump/reload to fix it!
2020-06-01T12:46:09.641218Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_links`" or dump/reload to fix it!
2020-06-01T12:46:09.643071Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_comments`" or dump/reload to fix it!
2020-06-01T12:46:09.661606Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_permanent_block`" or dump/reload to fix it!
2020-06-01T12:46:09.663435Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_login_lockdown`" or dump/reload to fix it!
2020-06-01T12:46:09.665447Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_login_activity`" or dump/reload to fix it!
2020-06-01T12:46:09.667288Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_global_meta`" or dump/reload to fix it!
2020-06-01T12:46:09.669192Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_failed_logins`" or dump/reload to fix it!
2020-06-01T12:46:09.671034Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_events`" or dump/reload to fix it!
2020-06-01T12:46:10.345497Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_wc_comments_subscription`" or dump/reload to fix it!
2020-06-01T12:46:10.349489Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_users`" or dump/reload to fix it!
2020-06-01T12:46:10.423946Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_posts`" or dump/reload to fix it!
2020-06-01T12:46:10.496596Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_links`" or dump/reload to fix it!
2020-06-01T12:46:10.856584Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_comments`" or dump/reload to fix it!
2020-06-01T12:46:10.884755Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_permanent_block`" or dump/reload to fix it!
2020-06-01T12:46:10.888713Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_login_lockdown`" or dump/reload to fix it!
2020-06-01T12:46:10.893202Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_login_activity`" or dump/reload to fix it!
2020-06-01T12:46:10.896926Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_global_meta`" or dump/reload to fix it!
2020-06-01T12:46:10.900623Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_failed_logins`" or dump/reload to fix it!
2020-06-01T12:46:10.904388Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_events`" or dump/reload to fix it!
2020-06-01T12:46:10.910374Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_users`" or dump/reload to fix it!
2020-06-01T12:46:11.027153Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_posts`" or dump/reload to fix it!
2020-06-01T12:46:11.075887Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_links`" or dump/reload to fix it!
2020-06-01T12:46:11.104034Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_comments`" or dump/reload to fix it!
2020-06-01T12:46:11.672535Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_users`" or dump/reload to fix it!
2020-06-01T12:46:11.783939Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_posts`" or dump/reload to fix it!
2020-06-01T12:46:11.829358Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_links`" or dump/reload to fix it!
2020-06-01T12:46:11.833256Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_comments`" or dump/reload to fix it!
2020-06-01T12:46:11.865762Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_permanent_block`" or dump/reload to fix it!
2020-06-01T12:46:11.870481Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_login_lockdown`" or dump/reload to fix it!
2020-06-01T12:46:11.874375Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_login_activity`" or dump/reload to fix it!
2020-06-01T12:46:11.878254Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_global_meta`" or dump/reload to fix it!
2020-06-01T12:46:11.882142Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_failed_logins`" or dump/reload to fix it!
2020-06-01T12:46:11.886058Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_events`" or dump/reload to fix it!
2020-06-01T12:46:12.392589Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_users`" or dump/reload to fix it!
2020-06-01T12:46:12.510850Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_posts`" or dump/reload to fix it!
2020-06-01T12:46:12.554556Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_links`" or dump/reload to fix it!
2020-06-01T12:46:12.559047Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_comments`" or dump/reload to fix it!
2020-06-01T12:46:12.592337Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_permanent_block`" or dump/reload to fix it!
2020-06-01T12:46:12.596646Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_login_lockdown`" or dump/reload to fix it!
2020-06-01T12:46:12.600905Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_login_activity`" or dump/reload to fix it!
2020-06-01T12:46:12.605119Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_global_meta`" or dump/reload to fix it!
2020-06-01T12:46:12.609416Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_failed_logins`" or dump/reload to fix it!
2020-06-01T12:46:12.613869Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_events`" or dump/reload to fix it!
2020-06-01T12:46:12.777079Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `proxies_priv`" or dump/reload to fix it!
2020-06-01T12:46:12.978175Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_users`" or dump/reload to fix it!
2020-06-01T12:46:13.026132Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_posts`" or dump/reload to fix it!
2020-06-01T12:46:13.059761Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_nextend2_smartslider3_slides`" or dump/reload to fix it!
2020-06-01T12:46:13.071999Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_nextend2_smartslider3_sliders`" or dump/reload to fix it!
2020-06-01T12:46:13.103208Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_links`" or dump/reload to fix it!
2020-06-01T12:46:13.107562Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_duplicator_packages`" or dump/reload to fix it!
2020-06-01T12:46:13.111908Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_comments`" or dump/reload to fix it!
2020-06-01T12:46:13.636442Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_users`" or dump/reload to fix it!
2020-06-01T12:46:13.753408Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_posts`" or dump/reload to fix it!
2020-06-01T12:46:13.796435Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_links`" or dump/reload to fix it!
2020-06-01T12:46:13.800896Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_comments`" or dump/reload to fix it!
2020-06-01T12:46:13.824373Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_permanent_block`" or dump/reload to fix it!
2020-06-01T12:46:13.828886Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_login_lockdown`" or dump/reload to fix it!
2020-06-01T12:46:13.834369Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_login_activity`" or dump/reload to fix it!
2020-06-01T12:46:13.838936Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_global_meta`" or dump/reload to fix it!
2020-06-01T12:46:13.843443Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_failed_logins`" or dump/reload to fix it!
2020-06-01T12:46:13.848109Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_events`" or dump/reload to fix it!
2020-06-01T12:46:14.337991Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_users`" or dump/reload to fix it!
2020-06-01T12:46:14.755465Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_posts`" or dump/reload to fix it!
2020-06-01T12:46:14.806941Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_links`" or dump/reload to fix it!
2020-06-01T12:46:14.838578Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_comments`" or dump/reload to fix it!
2020-06-01T12:46:14.865707Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_permanent_block`" or dump/reload to fix it!
2020-06-01T12:46:14.871246Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_login_lockdown`" or dump/reload to fix it!
2020-06-01T12:46:14.875839Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_login_activity`" or dump/reload to fix it!
2020-06-01T12:46:14.880417Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_global_meta`" or dump/reload to fix it!
2020-06-01T12:46:14.885059Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_failed_logins`" or dump/reload to fix it!
2020-06-01T12:46:14.889705Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_events`" or dump/reload to fix it!
2020-06-01T12:46:14.897413Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_yith_wcwl_lists`" or dump/reload to fix it!
2020-06-01T12:46:14.902424Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_yith_wcwl`" or dump/reload to fix it!
2020-06-01T12:46:14.997582Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_woocommerce_log`" or dump/reload to fix it!
2020-06-01T12:46:15.010982Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_woocommerce_ir_sms_archive`" or dump/reload to fix it!
2020-06-01T12:46:15.038758Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_woocommerce_downloadable_product_permissions`" or dump/reload to fix it!
2020-06-01T12:46:15.053340Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_woocommerce_api_keys`" or dump/reload to fix it!
2020-06-01T12:46:15.058194Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_wc_webhooks`" or dump/reload to fix it!
2020-06-01T12:46:15.074622Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_wc_download_log`" or dump/reload to fix it!
2020-06-01T12:46:15.079460Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_users`" or dump/reload to fix it!
2020-06-01T12:46:15.142528Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_smush_dir_images`" or dump/reload to fix it!
2020-06-01T12:46:15.206983Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_remindmedb`" or dump/reload to fix it!
2020-06-01T12:46:15.215211Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_posts`" or dump/reload to fix it!
2020-06-01T12:46:15.276239Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_links`" or dump/reload to fix it!
2020-06-01T12:46:15.289310Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_ewwwio_images`" or dump/reload to fix it!
2020-06-01T12:46:15.294242Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_duplicator_pro_packages`" or dump/reload to fix it!
2020-06-01T12:46:15.307675Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_duplicator_packages`" or dump/reload to fix it!
2020-06-01T12:46:15.329525Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_dokan_vendor_balance`" or dump/reload to fix it!
2020-06-01T12:46:15.503896Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_dokan_follow_store_followers`" or dump/reload to fix it!
2020-06-01T12:46:15.525601Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_comments`" or dump/reload to fix it!
2020-06-01T12:46:15.560537Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_yith_wcwl_lists`" or dump/reload to fix it!
2020-06-01T12:46:15.565460Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_yith_wcwl`" or dump/reload to fix it!
2020-06-01T12:46:15.674972Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_woocommerce_log`" or dump/reload to fix it!
2020-06-01T12:46:15.689309Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_woocommerce_ir_sms_archive`" or dump/reload to fix it!
2020-06-01T12:46:15.718675Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_woocommerce_downloadable_product_permissions`" or dump/reload to fix it!
2020-06-01T12:46:15.733349Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_woocommerce_api_keys`" or dump/reload to fix it!
2020-06-01T12:46:15.738532Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_wc_webhooks`" or dump/reload to fix it!
2020-06-01T12:46:15.743697Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_wc_download_log`" or dump/reload to fix it!
2020-06-01T12:46:15.749833Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_users`" or dump/reload to fix it!
2020-06-01T12:46:15.809598Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_remindmedb`" or dump/reload to fix it!
2020-06-01T12:46:15.814883Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_posts`" or dump/reload to fix it!
2020-06-01T12:46:15.879298Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_links`" or dump/reload to fix it!
2020-06-01T12:46:15.893977Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_ewwwio_images`" or dump/reload to fix it!
2020-06-01T12:46:15.899581Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_duplicator_pro_packages`" or dump/reload to fix it!
2020-06-01T12:46:15.913607Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_comments`" or dump/reload to fix it!
2020-06-01T12:46:15.950531Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_yith_wcwl_lists`" or dump/reload to fix it!
2020-06-01T12:46:15.955948Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_yith_wcwl`" or dump/reload to fix it!
2020-06-01T12:46:16.292222Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_woocommerce_downloadable_product_permissions`" or dump/reload to fix it!
2020-06-01T12:46:16.343254Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_wc_webhooks`" or dump/reload to fix it!
2020-06-01T12:46:16.348714Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_wc_download_log`" or dump/reload to fix it!
2020-06-01T12:46:16.354053Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_users`" or dump/reload to fix it!
2020-06-01T12:46:16.492270Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_remindmedb`" or dump/reload to fix it!
2020-06-01T12:46:16.498520Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_posts`" or dump/reload to fix it!
2020-06-01T12:46:16.560823Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_links`" or dump/reload to fix it!
2020-06-01T12:46:16.574877Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_ewwwio_images`" or dump/reload to fix it!
2020-06-01T12:46:16.580431Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_duplicator_pro_packages`" or dump/reload to fix it!
2020-06-01T12:46:16.594407Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_comments`" or dump/reload to fix it!
2020-06-01T12:46:17.201261Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_users`" or dump/reload to fix it!
2020-06-01T12:46:17.321988Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_posts`" or dump/reload to fix it!
2020-06-01T12:46:17.363781Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_links`" or dump/reload to fix it!
2020-06-01T12:46:17.370247Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_comments`" or dump/reload to fix it!
2020-06-01T12:46:17.393211Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_permanent_block`" or dump/reload to fix it!
2020-06-01T12:46:17.398838Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_login_lockdown`" or dump/reload to fix it!
2020-06-01T12:46:17.404877Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_login_activity`" or dump/reload to fix it!
2020-06-01T12:46:17.410421Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_global_meta`" or dump/reload to fix it!
2020-06-01T12:46:17.416559Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_failed_logins`" or dump/reload to fix it!
2020-06-01T12:46:17.422340Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_events`" or dump/reload to fix it!
2020-06-01T12:46:17.456456Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_yith_wcwl_lists`" or dump/reload to fix it!
2020-06-01T12:46:17.463371Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_yith_wcwl`" or dump/reload to fix it!
2020-06-01T12:46:17.584615Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_woocommerce_log`" or dump/reload to fix it!
2020-06-01T12:46:17.613991Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_woocommerce_downloadable_product_permissions`" or dump/reload to fix it!
2020-06-01T12:46:17.631297Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_woocommerce_api_keys`" or dump/reload to fix it!
2020-06-01T12:46:17.637097Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_wc_webhooks`" or dump/reload to fix it!
2020-06-01T12:46:17.643130Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_wc_download_log`" or dump/reload to fix it!
2020-06-01T12:46:17.649012Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_users`" or dump/reload to fix it!
2020-06-01T12:46:17.761848Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_posts`" or dump/reload to fix it!
2020-06-01T12:46:17.787892Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_links`" or dump/reload to fix it!
2020-06-01T12:46:17.794428Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_duplicator_packages`" or dump/reload to fix it!
2020-06-01T12:46:17.884344Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_comments`" or dump/reload to fix it!
2020-06-01T12:46:18.502766Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_users`" or dump/reload to fix it!
2020-06-01T12:46:18.631347Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_posts`" or dump/reload to fix it!
2020-06-01T12:46:18.679308Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_links`" or dump/reload to fix it!
2020-06-01T12:46:18.873568Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_comments`" or dump/reload to fix it!
2020-06-01T12:46:18.944287Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_bpspro_seclog_ignore`" or dump/reload to fix it!
2020-06-01T12:46:18.950372Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_bpspro_mscan`" or dump/reload to fix it!
2020-06-01T12:46:18.956394Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_bpspro_login_security`" or dump/reload to fix it!
2020-06-01T12:46:18.962381Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_bpspro_db_backup`" or dump/reload to fix it!
2020-06-01T12:46:18.968456Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_permanent_block`" or dump/reload to fix it!
2020-06-01T12:46:18.974459Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_login_lockdown`" or dump/reload to fix it!
2020-06-01T12:46:18.980749Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_login_activity`" or dump/reload to fix it!
2020-06-01T12:46:18.986903Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_global_meta`" or dump/reload to fix it!
2020-06-01T12:46:18.992946Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_failed_logins`" or dump/reload to fix it!
2020-06-01T12:46:18.999924Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_events`" or dump/reload to fix it!
2020-06-01T12:46:19.159931Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_users`" or dump/reload to fix it!
2020-06-01T12:46:19.269147Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_posts`" or dump/reload to fix it!
2020-06-01T12:46:19.310052Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_links`" or dump/reload to fix it!
2020-06-01T12:46:19.317326Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_comments`" or dump/reload to fix it!
2020-06-01T12:46:19.808233Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_users`" or dump/reload to fix it!
2020-06-01T12:46:19.893591Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_posts`" or dump/reload to fix it!
2020-06-01T12:46:19.929626Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_links`" or dump/reload to fix it!
2020-06-01T12:46:19.932802Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_comments`" or dump/reload to fix it!
2020-06-01T12:46:19.952197Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_permanent_block`" or dump/reload to fix it!
2020-06-01T12:46:19.955448Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_login_lockdown`" or dump/reload to fix it!
2020-06-01T12:46:19.958605Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_login_activity`" or dump/reload to fix it!
2020-06-01T12:46:19.962197Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_global_meta`" or dump/reload to fix it!
2020-06-01T12:46:19.965913Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_failed_logins`" or dump/reload to fix it!
2020-06-01T12:46:19.969568Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_events`" or dump/reload to fix it!
2020-06-01T12:46:19.975559Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_users`" or dump/reload to fix it!
2020-06-01T12:46:20.057915Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_posts`" or dump/reload to fix it!
2020-06-01T12:46:20.098838Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_links`" or dump/reload to fix it!
2020-06-01T12:46:20.103932Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_comments`" or dump/reload to fix it!
2020-06-01T12:46:20.143536Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_users`" or dump/reload to fix it!
2020-06-01T12:46:20.254832Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_posts`" or dump/reload to fix it!
2020-06-01T12:46:20.310878Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_links`" or dump/reload to fix it!
2020-06-01T12:46:20.317664Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_comments`" or dump/reload to fix it!
2020-06-01T12:46:20.341668Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_permanent_block`" or dump/reload to fix it!
2020-06-01T12:46:20.348516Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_login_lockdown`" or dump/reload to fix it!
2020-06-01T12:46:20.355361Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_login_activity`" or dump/reload to fix it!
2020-06-01T12:46:20.362646Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_global_meta`" or dump/reload to fix it!
2020-06-01T12:46:20.371402Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_failed_logins`" or dump/reload to fix it!
2020-06-01T12:46:20.378395Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_events`" or dump/reload to fix it!
2020-06-01T12:46:20.426860Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_users`" or dump/reload to fix it!
2020-06-01T12:46:20.550591Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_posts`" or dump/reload to fix it!
2020-06-01T12:46:20.595607Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_links`" or dump/reload to fix it!
2020-06-01T12:46:20.602253Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_comments`" or dump/reload to fix it!
2020-06-01T12:46:20.633667Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_users`" or dump/reload to fix it!
2020-06-01T12:46:20.926779Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_posts`" or dump/reload to fix it!
2020-06-01T12:46:20.976573Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_links`" or dump/reload to fix it!
2020-06-01T12:46:20.983557Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_comments`" or dump/reload to fix it!
2020-06-01T12:46:21.029316Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_permanent_block`" or dump/reload to fix it!
2020-06-01T12:46:21.036842Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_login_lockdown`" or dump/reload to fix it!
2020-06-01T12:46:21.043961Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_login_activity`" or dump/reload to fix it!
2020-06-01T12:46:21.051831Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_global_meta`" or dump/reload to fix it!
2020-06-01T12:46:21.059101Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_failed_logins`" or dump/reload to fix it!
2020-06-01T12:46:21.066793Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_events`" or dump/reload to fix it!
2020-06-01T12:46:21.830410Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_users`" or dump/reload to fix it!
2020-06-01T12:46:21.946880Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_posts`" or dump/reload to fix it!
2020-06-01T12:46:22.003688Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_links`" or dump/reload to fix it!
2020-06-01T12:46:22.031175Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_comments`" or dump/reload to fix it!
2020-06-01T12:46:22.060152Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_permanent_block`" or dump/reload to fix it!
2020-06-01T12:46:22.072241Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_login_lockdown`" or dump/reload to fix it!
2020-06-01T12:46:22.079200Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_login_activity`" or dump/reload to fix it!
2020-06-01T12:46:22.086534Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_global_meta`" or dump/reload to fix it!
2020-06-01T12:46:22.093423Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_failed_logins`" or dump/reload to fix it!
2020-06-01T12:46:22.100412Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_events`" or dump/reload to fix it!
2020-06-01T12:46:22.745823Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_users`" or dump/reload to fix it!
2020-06-01T12:46:23.023543Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_posts`" or dump/reload to fix it!
2020-06-01T12:46:23.077354Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_links`" or dump/reload to fix it!
2020-06-01T12:46:23.084826Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_comments`" or dump/reload to fix it!
2020-06-01T12:46:23.114319Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_permanent_block`" or dump/reload to fix it!
2020-06-01T12:46:23.122570Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_login_lockdown`" or dump/reload to fix it!
2020-06-01T12:46:23.129769Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_login_activity`" or dump/reload to fix it!
2020-06-01T12:46:23.136854Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_global_meta`" or dump/reload to fix it!
2020-06-01T12:46:23.144137Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_failed_logins`" or dump/reload to fix it!
2020-06-01T12:46:23.151306Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_events`" or dump/reload to fix it!
2020-06-01T12:46:23.161151Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_users`" or dump/reload to fix it!
2020-06-01T12:46:23.297989Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_posts`" or dump/reload to fix it!
2020-06-01T12:46:23.359501Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_links`" or dump/reload to fix it!
2020-06-01T12:46:23.367156Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_comments`" or dump/reload to fix it!
2020-06-01T12:46:23.406541Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_users`" or dump/reload to fix it!
2020-06-01T12:46:23.554330Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_posts`" or dump/reload to fix it!
2020-06-01T12:46:23.608896Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_links`" or dump/reload to fix it!
2020-06-01T12:46:23.616570Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_comments`" or dump/reload to fix it!
2020-06-01T12:46:23.641872Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_permanent_block`" or dump/reload to fix it!
2020-06-01T12:46:23.645819Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_login_lockdown`" or dump/reload to fix it!
2020-06-01T12:46:23.649686Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_login_activity`" or dump/reload to fix it!
2020-06-01T12:46:23.653542Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_global_meta`" or dump/reload to fix it!
2020-06-01T12:46:23.657357Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_failed_logins`" or dump/reload to fix it!
2020-06-01T12:46:23.661164Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_events`" or dump/reload to fix it!
2020-06-01T12:46:24.230362Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_users`" or dump/reload to fix it!
2020-06-01T12:46:24.630776Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_posts`" or dump/reload to fix it!
2020-06-01T12:46:25.106098Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_links`" or dump/reload to fix it!
2020-06-01T12:46:25.304629Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_comments`" or dump/reload to fix it!
2020-06-01T12:46:25.333590Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_permanent_block`" or dump/reload to fix it!
2020-06-01T12:46:25.341934Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_login_lockdown`" or dump/reload to fix it!
2020-06-01T12:46:25.349297Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_login_activity`" or dump/reload to fix it!
2020-06-01T12:46:25.356661Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_global_meta`" or dump/reload to fix it!
2020-06-01T12:46:25.364133Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_failed_logins`" or dump/reload to fix it!
2020-06-01T12:46:25.372418Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_events`" or dump/reload to fix it!
2020-06-01T12:46:25.382070Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_users`" or dump/reload to fix it!
2020-06-01T12:46:25.517411Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_posts`" or dump/reload to fix it!
2020-06-01T12:46:25.572978Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_links`" or dump/reload to fix it!
2020-06-01T12:46:25.581136Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_comments`" or dump/reload to fix it!
2020-06-01T12:46:26.168542Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_users`" or dump/reload to fix it!
2020-06-01T12:46:26.494087Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_posts`" or dump/reload to fix it!
2020-06-01T12:46:26.681296Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_links`" or dump/reload to fix it!
2020-06-01T12:46:26.780641Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_comments`" or dump/reload to fix it!
2020-06-01T12:46:26.819730Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_permanent_block`" or dump/reload to fix it!
2020-06-01T12:46:26.827715Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_login_lockdown`" or dump/reload to fix it!
2020-06-01T12:46:26.835805Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_login_activity`" or dump/reload to fix it!
2020-06-01T12:46:26.843590Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_global_meta`" or dump/reload to fix it!
2020-06-01T12:46:26.852746Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_failed_logins`" or dump/reload to fix it!
2020-06-01T12:46:26.860414Z 2 [ERROR] [MY-010923] [Server] Table upgrade required. Please do "REPAIR TABLE `wp_aiowps_events`" or dump/reload to fix it!
2020-06-01T12:46:26.866634Z 2 [ERROR] [MY-011060] [Server] Incorrect definition of table mysql.event: expected column 'definer' at position 3 to have type char(93), found type char(77)..
2020-06-01T12:46:26.877889Z 0 [Warning] [MY-010727] [Server] System table 'time_zone_leap_second' is expected to be transactional.
2020-06-01T12:46:26.881652Z 0 [Warning] [MY-010727] [Server] System table 'time_zone_name' is expected to be transactional.
2020-06-01T12:46:26.885474Z 0 [Warning] [MY-010727] [Server] System table 'time_zone' is expected to be transactional.
2020-06-01T12:46:26.889292Z 0 [Warning] [MY-010727] [Server] System table 'time_zone_transition_type' is expected to be transactional.
2020-06-01T12:46:26.893105Z 0 [Warning] [MY-010727] [Server] System table 'time_zone_transition' is expected to be transactional.
2020-06-01T12:46:26.899524Z 2 [ERROR] [MY-011060] [Server] Incorrect definition of table mysql.proc: expected column 'definer' at position 11 to have type char(93), found type char(77)..
2020-06-01T12:46:30.728381Z 0 [ERROR] [MY-010022] [Server] Failed to Populate DD tables.
2020-06-01T12:46:30.739183Z 0 [ERROR] [MY-010119] [Server] Aborting
2020-06-01T12:46:32.406430Z 0 [System] [MY-010910] [Server] /usr/sbin/mysqld: Shutdown complete (mysqld 8.0.20)  MySQL Community Server - GPL.
[root@server ~]# sh -x /etc/init.d/mysqld start
+ . /etc/rc.d/init.d/functions
++ TEXTDOMAIN=initscripts
++ umask 022
++ PATH=/sbin:/usr/sbin:/bin:/usr/bin
++ export PATH
++ '[' -z '' ']'
++ COLUMNS=80
++ '[' -z '' ']'
+++ /sbin/consoletype
++ CONSOLETYPE=pty
++ '[' -f /etc/sysconfig/i18n -a -z '' -a -z '' ']'
++ . /etc/profile.d/lang.sh
++ unset LANGSH_SOURCED
++ '[' -z '' ']'
++ '[' -f /etc/sysconfig/init ']'
++ . /etc/sysconfig/init
+++ BOOTUP=color
+++ RES_COL=60
+++ MOVE_TO_COL='echo -en \033[60G'
+++ SETCOLOR_SUCCESS='echo -en \033[0;32m'
+++ SETCOLOR_FAILURE='echo -en \033[0;31m'
+++ SETCOLOR_WARNING='echo -en \033[0;33m'
+++ SETCOLOR_NORMAL='echo -en \033[0;39m'
+++ PROMPT=yes
+++ AUTOSWAP=no
+++ ACTIVE_CONSOLES='/dev/tty[1-6]'
+++ SINGLE=/sbin/sushell
++ '[' pty = serial ']'
++ __sed_discard_ignored_files='/\(~\|\.bak\|\.orig\|\.rpmnew\|\.rpmorig\|\.rpmsave\)$/d'
+++ cat /proc/cmdline
++ strstr 'ro root=/dev/mapper/vg_localhost-lv_root rd_NO_LUKS LANG=en_US.UTF-8 rd_NO_MD rd_LVM_LV=vg_localhost/lv_swap SYSFONT=latarcyrheb-sun16 crashkernel=129M@48M rd_LVM_LV=vg_localhost/lv_root  KEYBOARDTYPE=pc KEYTABLE=us rd_NO_DM rhgb quiet' rc.debug
++ '[' 'ro root=/dev/mapper/vg_localhost-lv_root rd_NO_LUKS LANG=en_US.UTF-8 rd_NO_MD rd_LVM_LV=vg_localhost/lv_swap SYSFONT=latarcyrheb-sun16 crashkernel=129M@48M rd_LVM_LV=vg_localhost/lv_root  KEYBOARDTYPE=pc KEYTABLE=us rd_NO_DM rhgb quiet' = 'ro root=/dev/mapper/vg_localhost-lv_root rd_NO_LUKS LANG=en_US.UTF-8 rd_NO_MD rd_LVM_LV=vg_localhost/lv_swap SYSFONT=latarcyrheb-sun16 crashkernel=129M@48M rd_LVM_LV=vg_localhost/lv_root  KEYBOARDTYPE=pc KEYTABLE=us rd_NO_DM rhgb quiet' ']'
++ return 1
+ . /etc/sysconfig/network
++ NETWORKING=yes
++ HOSTNAME=server.uromnews.ir
++ GATEWAY=46.209.144.153
+ exec=/usr/bin/mysqld_safe
+ prog=mysqld
+ STARTTIMEOUT=120
+ STOPTIMEOUT=600
+ MYSQLD_OPTS=
+ '[' -e /etc/sysconfig/mysqld ']'
+ lockfile=/var/lock/subsys/mysqld
+ command=start
+ shift
+ extra_opts=
+ get_mysql_option datadir /var/lib/mysql mysqld
+ option=datadir
+ default=/var/lib/mysql
+ shift 2
++ /usr/bin/my_print_defaults mysqld
++ sed -n 's/^--datadir=//p'
++ tail -n 1
+ result=
+ '[' -z '' ']'
+ result=/var/lib/mysql
+ datadir=/var/lib/mysql
+ get_mysql_option socket /var/lib/mysql/mysql.sock mysqld
+ option=socket
+ default=/var/lib/mysql/mysql.sock
+ shift 2
++ sed -n 's/^--socket=//p'
++ tail -n 1
+ result=/var/lib/mysql/mysql.sock
+ '[' -z /var/lib/mysql/mysql.sock ']'
+ socketfile=/var/lib/mysql/mysql.sock
+ get_mysql_option log-error /var/log/mysqld.log mysqld mysqld_safe
+ option=log-error
+ default=/var/log/mysqld.log
+ shift 2
++ /usr/bin/my_print_defaults mysqld mysqld_safe
++ sed -n 's/^--log-error=//p'
++ tail -n 1
+ result=
+ '[' -z '' ']'
+ result=/var/log/mysqld.log
+ errlogfile=/var/log/mysqld.log
+ get_mysql_option pid-file /var/run/mysqld/mysqld.pid mysqld mysqld_safe
+ option=pid-file
+ default=/var/run/mysqld/mysqld.pid
+ shift 2
++ sed -n 's/^--pid-file=//p'
++ tail -n 1
+ result=
+ '[' -z '' ']'
+ result=/var/run/mysqld/mysqld.pid
+ mypidfile=/var/run/mysqld/mysqld.pid
+ case $socketfile in
+ adminsocket=/var/lib/mysql/mysql.sock
+ case "$command" in
+ start
+ '[' -x /usr/bin/mysqld_safe ']'
++ /usr/bin/mysqladmin --no-defaults --enable-cleartext-plugin --socket=/var/lib/mysql/mysql.sock --user=UNKNOWN_MYSQL_USER ping
+ RESPONSE='mysqladmin: connect to server at '\''localhost'\'' failed
error: '\''Can'\''t connect to local MySQL server through socket '\''/var/lib/mysql/mysql.sock'\'' (2)'\''
Check that mysqld is running and that the socket: '\''/var/lib/mysql/mysql.sock'\'' exists!'
+ '[' 1 = 0 ']'
+ echo 'mysqladmin: connect to server at '\''localhost'\'' failed
+ grep -q 'Access denied for user'
++ dirname /var/log/mysqld.log
+ '[' '!' -e /var/log/mysqld.log -a '!' -h /var/log/mysqld.log -a x/var/log = x/var/log ']'
+ '[' -x /sbin/restorecon ']'
+ /sbin/restorecon /var/log/mysqld.log
+ fix_mysql_upgrade_info
+ '[' -d /var/lib/mysql ']'
+ '[' -O /var/lib/mysql/mysql_upgrade_info ']'
+ '[' '!' -d /var/lib/mysql/mysql ']'
++ dirname /var/lib/mysql
+ '[' '!' -h /var/lib/mysql -a x/var/lib = x/var/lib ']'
+ chown mysql:mysql /var/lib/mysql
+ chmod 0751 /var/lib/mysql
+ safe_pid=29976
+ ret=0
+ TIMEOUT=120
+ '[' 120 -gt 0 ']'
+ /usr/bin/mysqld_safe --datadir=/var/lib/mysql --socket=/var/lib/mysql/mysql.sock --pid-file=/var/run/mysqld/mysqld.pid --basedir=/usr --user=mysql
+ /bin/kill -0 29976
+ sleep 1
+ let TIMEOUT=120-1
+ '[' 119 -gt 0 ']'
+ sleep 1
+ let TIMEOUT=119-1
+ '[' 118 -gt 0 ']'
+ sleep 1
+ let TIMEOUT=118-1
+ '[' 117 -gt 0 ']'
+ sleep 1
+ let TIMEOUT=117-1
+ '[' 116 -gt 0 ']'
+ sleep 1
+ let TIMEOUT=116-1
+ '[' 115 -gt 0 ']'
+ sleep 1
+ let TIMEOUT=115-1
+ '[' 114 -gt 0 ']'
+ sleep 1
+ let TIMEOUT=114-1
+ '[' 113 -gt 0 ']'
+ sleep 1
+ let TIMEOUT=113-1
+ '[' 112 -gt 0 ']'
+ sleep 1
+ let TIMEOUT=112-1
+ '[' 111 -gt 0 ']'
+ sleep 1
+ let TIMEOUT=111-1
+ '[' 110 -gt 0 ']'
+ sleep 1
+ let TIMEOUT=110-1
+ '[' 109 -gt 0 ']'
+ sleep 1
+ let TIMEOUT=109-1
+ '[' 108 -gt 0 ']'
+ sleep 1
+ let TIMEOUT=108-1
+ '[' 107 -gt 0 ']'
+ sleep 1
+ let TIMEOUT=107-1
+ '[' 106 -gt 0 ']'
+ sleep 1
+ let TIMEOUT=106-1
+ '[' 105 -gt 0 ']'
+ sleep 1
+ let TIMEOUT=105-1
+ '[' 104 -gt 0 ']'
+ sleep 1
+ let TIMEOUT=104-1
+ '[' 103 -gt 0 ']'
+ sleep 1
+ let TIMEOUT=103-1
+ '[' 102 -gt 0 ']'
+ sleep 1
+ let TIMEOUT=102-1
+ '[' 101 -gt 0 ']'
+ sleep 1
+ let TIMEOUT=101-1
+ '[' 100 -gt 0 ']'
+ sleep 1
+ let TIMEOUT=100-1
+ '[' 99 -gt 0 ']'
+ sleep 1
+ let TIMEOUT=99-1
+ '[' 98 -gt 0 ']'
+ sleep 1
+ let TIMEOUT=98-1
+ '[' 97 -gt 0 ']'
+ sleep 1
+ let TIMEOUT=97-1
+ '[' 96 -gt 0 ']'
+ sleep 1
+ let TIMEOUT=96-1
+ '[' 95 -gt 0 ']'
+ sleep 1
+ let TIMEOUT=95-1
+ '[' 94 -gt 0 ']'
+ sleep 1
+ let TIMEOUT=94-1
+ '[' 93 -gt 0 ']'
+ sleep 1
+ let TIMEOUT=93-1
+ '[' 92 -gt 0 ']'
+ sleep 1
+ let TIMEOUT=92-1
+ '[' 91 -gt 0 ']'
+ sleep 1
+ let TIMEOUT=91-1
+ '[' 90 -gt 0 ']'
+ sleep 1
+ let TIMEOUT=90-1
+ '[' 89 -gt 0 ']'
+ sleep 1
+ let TIMEOUT=89-1
+ '[' 88 -gt 0 ']'
+ echo 'MySQL Daemon failed to start.'
+ ret=1
+ break
+ '[' 88 -eq 0 ']'
+ '[' 1 -eq 0 ']'
+ action 'Starting mysqld: ' /bin/false
+ local STRING rc
+ STRING='Starting mysqld: '
+ echo -n 'Starting mysqld:  '
Starting mysqld:  + shift
+ /bin/false
+ failure 'Starting mysqld: '
+ local rc=1
+ '[' color '!=' verbose -a -z '' ']'
+ echo_failure
+ '[' color = color ']'
+ echo -en '\033[60G'
                                                           + echo -n '['
[+ '[' color = color ']'
+ echo -en '\033[0;31m'
+ echo -n FAILED
FAILED+ '[' color = color ']'
+ echo -en '\033[0;39m'
+ echo -n ']'
]+ echo -ne '\r'
+ return 1
+ '[' -x /bin/plymouth ']'
+ /bin/plymouth --details
+ return 1
+ rc=1
+ echo
+ return 1
+ return 1
+ exit 1
how do you run mysql upgrade?
what steps was
./build set mysql_inst mysql
./build set mysql 5.6
./build mysql
./build set mysql 5.7
./build mysql
./build set mysql 8.0
./build mysql
To use mysql_upgrade, you’ll first need to make sure that your server is up and running. Then, from within the terminal, enter the following command:
shell> mysql_upgrade
The way mysql_upgrade works, is by automatically executing the following commands:
mysqlcheck --check-upgrade --all-databases --auto-repair
mysql_fix_privilege_tables
