Could it be https://forum.directadmin.com/threads/netdata-install-not-complete.61395/#post-314892 this time? If not, try runningok, but all Netdata crash each day for this /etc/con.daily/netdata-update
Why? i test retart this but not work... i remove nd reinstall each time
and then check if /opt/netdata/etc/netdata/netdata.conf
has /var/run/netdata/netdata.sock
listed inside?exe:/opt/netdata/usr/libexec/netdata/plugins.d/go.d.plugin
exe:/opt/netdata/bin/srv/netdata
exe:/opt/netdata/usr/libexec/netdata/plugins.d/apps.plugin
exe:/opt/netdata/bin/bash
user:netdata
exe:/usr/bin/python2.7
Would it be possible to get access to the system? The check would be free of charge.After (cron update) the: netdata.conf reset and only this in this file:
# netdata can generate its own config which is available at 'http://<netdata_ip>/netdata.conf'
# You can download it with command like: 'wget -O /opt/netdata/etc/netdata/netdata.conf http://localhost:19999/netdata.conf'
On CentOS 8, the link in the Evolution skin disappears each time after the nightly update, I need to reinstall Netdata each time to make the link visible again in the DirectAdmin menu but after the nightly update it always disappears (but Netdata itself is still running because it still shows up in the processes and keeps monitoring the server and even mails me when the backup is running and the disk backlog is in warning). Also, the nightly cron doesn't run the day after.
So in short: Build netdata, works for a day perfectly. after nightly update cron the link disappears in DA and isn't accessible directly, cron doesn't do the nightly update the day after but netdata still runs.
Looks like a bug which should be fixed pretty soon: https://github.com/netdata/netdata/issues/8531
2020-06-03 06:17:29: netdata INFO : ACLK_Main : Attempting to establish the agent cloud link
2020-06-03 06:17:29: netdata INFO : ACLK_Main : Retrieving challenge from cloud: app.netdata.cloud 443 /api/v1/auth/node/UUIDHERE/challenge
2020-06-03 06:17:29: netdata INFO : ACLK_Main : aclk_send_https_request GET
2020-06-03 06:17:29: netdata ERROR : ACLK_Main : Libwebsockets: SSL error: unable to get local issuer certificate (preverify_ok=0;err=20;depth=1)
(errno 2, No such file or directory)
2020-06-03 06:17:29: netdata ERROR : ACLK_Main : Challenge failed:
2020-06-03 06:17:29: netdata INFO : ACLK_Main : Retrying to establish the ACLK connection in 4.630 seconds
This part looks weird. Did you try creating a github issue to report it to netdata?No such file or directory
