When you install DA on a fresh CENTOS7 server it auto installs CSF, when you do the same on a CENTOS8 server it doesn't?
Everything was saved in your terminal window, unless you 'redirected' the output to the file. It's first report on it, I haven't noticed any issues with CSF installation on the installation time, but if it's missing, it might be some missing pre-requisites of CSF..Yeah, I was using the auto mode....is there a way to see any errors after the setup?
I try in lan vps withYeah, I was using the auto mode....is there a way to see any errors after the setup?
