SSL Key Size options?
LawsHosting
London UK
What are these? And why is it defaulted to one of the NIST gobble-de-gook ones?
What did I miss? How come all these options? How do they work?
Thanks for the report. I've made a change to limit those ECC certs to just the 3 important variants, and simplified their naming:
They're related to this change in 1.61.0:
where DA gets the list from:
openssl ecparam -list_curves
where it looks like your openssl has far more options that I've seen before :)
Pre-release binaries are now available.
I only noticed this (I should actually read versions changelog) because a client mucked up their LE certificate...... I recreated it with the default key size and the browser complained about something (can't remember what).... So I chose 4096 and recreated it.
Do we need to do anything for these keys to work with browsers?
No, nothing special :) Was it some outdated browser/OS (like windows xp?).
Can we please get the ability to select the default. Most users just click and have no clue which is the best option.
Yes, ecc_certificates=1 is directadmin.conf option :) Set it to 0 if you want RSA.
I want a user to be able to have access to ECC and RSA. What I want is the ability to set the default as an example to 2048 RSA.
